Forum » Pomoč in nasveti » nastavitev afiniteta CPU-jev
StratOS ::
Imam problem z aplikacijo, ki ni narejena za multi core CPU.
Do problema prihaja takoj pri izmenjavi procesa na različnih CPU.
Aplikacija trenutno nima updatea, ki bi popravil to oziroma kakšnega fix-a.
Zanima me, če obstaja kakšna skripta, command line ki bi to takoj opb zagonu popravila, da mi ni potrebno vedno nastaviti Afiniteto preko Task Managerja ( seveda na samo en procesor ).
Govorim za XP-je za multi core CPU.
Primer :
Ali obstaja kakšen API za nastavitev takšnih pogojev zagona (symmetric multiprocessing affinity) ?
lp in hvala
Primer :
lp in hvala
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
StratOS ::
Lahko bi prebral:
Task Manager/ Processes /Property "Set Affinity" ( Desni klik na proces )
StratOS ::
OK, rešil :
Beyondlogic
Change the affinity of processes . . .
The affinity is a mask which indicates on which processors (CPUs) a process can run. This is only useful on multiprocessor systems. When the -a option is used in conjunction with a process name or PID, the utility will show the System Affinity Mask and the Process Affinity Mask. The System Affinity Mask shows how many configured processors are currently available in a system. The Process Affinity Mask indicates on what processor(s) the specified process can run on.
C:\>process -a wordpad.exe
To set the affinity mask, simply append the binary mask after the PID/Image Name. Any leading zeros are ignored, so there is no requirement to enter the full 32 bit mask.
C:\>process -a wordpad.exe 01
Download process.exe
možno je tudi več rešitev preko aplikacij :
http://www.informit.com/articles/articl...
Ali pa da spremeniš delovanje celotnega multiprocesorskega sistema le na enega ali več v enviromental spremenljivki z "set".
Dobil sem idealno zamisel
Beyondlogic
Command Line Process Viewer/Killer/Suspender for Windows NT/2000/XP V2.01
Copyright© 2002-2003 Craig.Peacock@beyondlogic.org
Getting Affinity Mask for PID 1084 'wordpad.exe'
System : 0x0001 0b00000000000000000000000000000011 [2 Installed Processor(s)]
Process : 0x0001 0b00000000000000000000000000000011
Setting Affinity Mask for PID 1084 'wordpad.exe'
Affinity Mask Successfully Set to 00000000000000000000000000000001
- spremenila: StratOS ()
| » | Nadomestilo za Adobe Creative Cloud (strani: 1 2 3 )Oddelek: Programska oprema | 45877 (620) | opeter |
| » | tezava amd phenom 2 x6 1055tOddelek: Navijanje | 3714 (2912) | x45 |
| » | Iz USB vtičnice bi rad samo elektriko dobil (za napajanje 2 diod)Oddelek: Elektrotehnika in elektronika | 1548 (1329) | ql000 |
| » | [C++] parallel porti na PCOddelek: Programiranje | 1978 (1741) | snow |
| » | Kak dodelit procesorsko moc programom?Oddelek: Programska oprema | 1918 (1684) | Gh0st |
