Forum » Pomoč in nasveti » Cd in dvd se ne odzivata
keyser77 ::
Lep pozdrav!
Mogoce mi bo kdo znal svetovati. Cd rw in dvd rw sta mi cez noc prenehala delovati. Probal sem ze z odstranitvijo in ponovno zaznavo pa nic. Tudi skatlo sem odprl in pogledal, ce so kabli ok, pa nic.
Kaj bi lahko bilo?
Hvala za odgovor
Kaj bi lahko bilo?
Hvala za odgovor
- polepsal: Primoz ()
keyser77 ::
ja hvala ampak jaz nisem ravno vešč računalništva....v bios se ne razumem. odprl sem ga, malo pregledal, oba sta zapisana v biosu, chipseta pa ne znam naloziti..... brez cd sem mrzel.....
ni mi jasno kaj se je zgodilo.....naprave kao delujejo pravilno .......
Pšenični ::
Ne šari po biosu, če ne veš kaj delaš.Vzemi cd ,ki si ga dobil zraven računalnika in z njega instaliraj driverje na novo.Če sta pogona v biosu zaznana potem je napaka softwarske narave -programska.
Pšenični ::
Pardon ,sem pozabu da ne moreš do cd romov. Dobi gonilnike z interneta.....,probej pa poročaj..
Sharkb1te ::
Probi tole. Men je s tem uspelo.
*Control Panel*
*MISSING CD-ROM/RW OR DVD DRIVE
This problem and its resolution is described in the following Microsoft
Knowledge Base article:
http://support.microsoft.com/default.as...
CD-ROM Access Is Missing and Messages Cite Error Code 31, Code 32, Code
19, or Code 39 After You Remove Easy CD Creator in Windows XP
A missing CD-ROM, CD-RW, or DVD-ROM drive in Windows Explorer seems to
be a fairly common problem in Windows XP. Sometimes this happens after a
Windows upgrade, sometimes after a new program installation, and
sometimes suddenly for no apparent reason at all. If you look in Device
Manager, you might see one of these errors:
The device is not working properly because Windows cannot load the
drivers required for this device (Code 31).
A driver for this device was not required, and has been disabled (Code
32 or Code 31).
Your registry might be corrupted. (Code 19)
The driver is corrupted. (Code 39)
Windows successfully loaded the device driver for this hardware but
cannot find the hardware device. (Code 41)
The method for correcting any of these problems is to delete certain
keys in the Registry. Click on the Start button, select Run, type in
REGEDIT and click OK. Locate and click on the following key in the left
pane of the Regedit window:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\
{4D36E965-E325-11CE-BFC1-08002BE10318}
In the right pane, there will be two values called Lowerfilters and
Upperfilters. Right click on each and select Delete from the Context
Menu. Then close Regedit and re-boot. You might need to reinstall any CD
recording software on your computer if there is lost functionality.
It is dangerous to use the Registry Editor, as a mistake may cause your
computer to be unbootable. If you prefer, you can download a script to
perform the Registry edit; it can be found at:
http://www.dougknox.com/xp/scripts_desc...
Restore CD/DVD Drives to Explorer
*Control Panel*
32 or Code 31).
| » | Dvd Enota Izginila Iz Sistema!?!Oddelek: Strojna oprema | 2079 (1486) | Xserces |
| » | Nujno! Pomoc pri zaznavi CD-roma!!!Oddelek: Pomoč in nasveti | 1996 (1815) | pale |
| » | CD/DVD drajvi so me zapustili.Oddelek: Strojna oprema | 1470 (1405) | G3GANT1C |
| » | Logitech MouseWare bug (?)Oddelek: Pomoč in nasveti | 2611 (2207) | Swiwer |
| » | Ne morem dostopat do CD roma !Oddelek: Pomoč in nasveti | 1165 (1046) | Turbina |
