Forum » Pomoč in nasveti » Povezava dveh mašin!W2k
HudPes ::
Imam dve mašini na katerih imam mrežne istega proizvajalca,in povezane s cross cablom!Ko pingam sosednjo mašino mi napiše reqest timed out!Nasatavitve za tcp/ip sem nastavil da jih samodejno zazna!Spodaj pri uri se mi pojavita dva ekrančka kot da bi bil na netu to je pa tut vse!
a obstaja kak progy da ti to vse naštima!
Prosim za pomoč!
l.P.
Prosim za pomoč!
l.P.
ToniT ::
Kako pa ti bo tcp-ip nastavitve zaznal, če nimaš DHCP serverja?? Vsaj na enem moraš nastaviti tcp-ip številko oz. ICS.
Najboljše bo, da izbereš na enem št. 192.168.0.1, na drugem pa 192.168.0.2 in subnet mask 255.255.255.0.
andrej ::
w2k imajo tako kot ostali MS OS-i zadevo imenovamo APIPA, ki vi primeru ko ni DHCP-ja sam izbere svoj IP.
Potem bi mogla zadeva delat. Res pa je, da je bolje uporabit ICS in je...
Automatic private address configuration
You use Automatic Private IP Addressing (APIPA) to automate TCP/IP address configuration for single-subnet networks that do not contain a DHCP server.
By default, a computer running Windows 2000 first tries to contact a DHCP server on the network to dynamically obtain configuration for each installed network connection.
If a DHCP server is reached and the leased configuration is successful, TCP/IP configuration is completed.
If a DHCP server is not reached, the computer instead uses APIPA to automatically configure TCP/IP. When you use APIPA, Windows 2000 determines an address in the reserved IP address range from 169.254.0.1 through 169.254.255.254. This address is used as a temporary IP address configuration until a DHCP server is located. The subnet mask is set to 255.255.0.0.
The APIPA range of IP addresses is reserved by the Internet Assigned Numbers Authority (IANA). Any IP addresses within this range are not used on the Internet.
APIPA eliminates IP address configuration for single-network small office or home office networks that are not connected to the Internet.
ABX ::
ping ime_svojega_pca
if works
then
ping ime_sosednjega_pca
if works
then
HudPes ::
Jest pingam sosednjega pa mi napiše :
če pingam ip-reqest timed out
Če ime računalnika-Unknown host
Če pa svojo ip je pa kao vse ok!!!
Please help
L.P.
Please help
L.P.
Mercier ::
Desni klik na ikono My Computer, tam poišči kje se poimenujejo, pa lahko jih daš v domeno (tega ne počni). Izberi network brez domene. In si izmisli neko ime za Workgroup. Ponovi vajo na drugem računalniku.
Tole sicer ni čisto rešitev cele zadeve, pomagalo pa bo, slejkoprej.
- spremenil: Mercier ()
ToniT ::
Če ne moreš pingat drugega računalnika, potem tudi dajanje v grupo ne bo pomagalo. Če imaš oba računalnika na istem subnetu (vseeno ali na APIPA adresah ali 192.168.x.x, potem preveri kabel!!!
andrej ::
workgroupa pri pinganju nima nobene veze. Daj na obeh napisi ipconfig /all in potem postaj izpise sem...
ToniT ::
Cmd naj bo v okenskem načinu, nato klikni na ikonco v zgornjem levem kotu in dobil boš meni - tam vse piše.
HudPes ::
Microsoft Windows 2000 [Version 5.00.2195]
(C) Copyright 1985-2000 Microsoft Corp.
C:\>ipconfig/all
Windows 2000 IP Configuration
Host Name . . . . . . . . . . . . : gremlin
Primary DNS Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Broadcast
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : 3Com EtherLink III ISA (3C509b-Combo
Physical Address. . . . . . . . . : 00-A0-24-8F-F4-8C
DHCP Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 192.168.0.1
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . :
DNS Servers . . . . . . . . . . . :
C:\>ping 192.168.0.1
Pinging 192.168.0.1 with 32 bytes of data:
Reply from 192.168.0.1: bytes=32 time<10ms TTL=64
Ping statistics for 192.168.0.1:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
C:\>ping 192.168.0.2
Pinging 192.168.0.2 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 192.168.0.2:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
To je na prvi mašini na drugi se mi dogaja isto!
L.P.
C:\>ipconfig/all
Request timed out.
Request timed out.
Request timed out.
Request timed out.
L.P.
ToniT ::
Glede na kartico, ki jo imaš, predvidevam da se želi povezati na koaxu. Obstaja programček, s katerim lahko kartivo prisiliš, da bo imela default nastavljen medij UTP. Programčku se reče 3cxconfig ali nekaj takega. Pojdi na semkaj in potegni dol disk 2 in tam boš našel ta program (dela v dosu) in nastavi media type na RJ45.
HudPes ::
Ja takole ta programček napiše da ni mogoče
izvajati diagnostike v win nt pomoje da tut
u w2k ne!
Kaj pa če kupm 100mb kartico druzga proizvajalca
na pci vodilu ta ki jo mam zdej je še isa!
K mam pa drugo PCMCIA 3com 10mb COMBO !:(
Kaj mi svetuješ!
L.P.
u w2k ne!
Kaj mi svetuješ!
L.P.
ToniT ::
Sploh ni problema. Vzami sistemsko DOSovo disketo (tega verjetno ni problem dobiti) in zaženi ta programček, ker kartica sploh ni tako slaba.
Poskusi še eno butasto stvar. Najper vklopi drugo mašino in naj zalaufa z vsemi servisi, nato pa zaženi še to mašino. Mogoče bo kartica zaznala signal na RJ portu in bo celo delala.
Meni je program 3c90xcfg.exe delal v XP-jih.
- spremenil: ToniT ()
~Panter~ ::
Se mi dogaja isto. Mam en comp kt so gor win 95, pa notr 3Com EtherLink III ISA(3C509/3c509b), ta drug comp pa WinXP pa notr ena leva mrežna, pa se nočta vidt. Kabl je sposojen od soseda pa 100% deluje, ko pa probam pingat pa na vsakmu compu dobim odgovor sam od lastne kartice, ne pa tud od ta druge. Res ne vem, kaj bi lohka blo narobe.
| » | Gajba piva za rešitev mrežneag problema Vista-W2KOddelek: Omrežja in internet | 3635 (2759) | just_a_cook |
| » | Kako nastaviti LAN?Oddelek: Omrežja in internet | 12770 (8440) | Tomi |
| » | router+adslOddelek: Pomoč in nasveti | 2881 (2655) | TribesMan |
| » | Računalnik ne registrira DNS-a?Oddelek: Omrežja in internet | 2152 (1922) | Hojne |
| » | tcp/ip problemiOddelek: Pomoč in nasveti | 2853 (2542) | tac |
