Samsung 913v in error na ekranu...
Poletnik ::
Sestrična ni prižigila računalnik več kot 2 tedna je rekla. In sedaj ko prižge računalnik se na ekranu pojavi naslednji error...
"Not Optimum Mode","Recommanded Mode 1280 x 1024 60Hz"
Po Samsungovih navodilih se to pojavi če je nastavljena prevelika resolucija ali frekvenca, ampak na računalniku je nastavljena pravilna frekvenca in resolucija. Monitor sem priklopil še na drug računalnik, enako z pravilno resolucijo in izpisuje enako opozorilo...
Kaj bi lahk še blo narobe?
Samsungov opis errora :
You can see this message when the signal from the video card exceeds the maximum resolution and frequency that the monitor can handle properly.
Adjust the maximum resolution and frequency that the monitor can handle properly.
If the display exceeds SXGA or 75Hz, a "Not Optimum Mode","Recommanded Mode 1280 x 1024 60Hz" message is displayed. If the display exceeds 85Hz, the display will work properly but the "Not Optimum Mode","Recommanded Mode 1280 x 1024 60Hz" message appears for one minute and then disappears.
Please change to the recommended mode during this one-minute period.
(The message is displayed again if the system is rebooted.)
http://www.norestrani.com
Not optimum mode
102876 (2350) MIHAc27
Slika zgine (narobna resolucija)
161976 (1574) bisernik
monitor - resolucija
101114 (986) e_boy
Samsung 971P - "Not Optimum Mode, Recommended Mode 1280 x 1024 60 Hz"
Oddelek: Zvok in slika
82635 (2491) nosk8fx
CATALYST 4.1 Has Arrived!
172433 (1838) tx-z
