Hard Disk Fail?
Hard Disk Fail?
Gamez0r ::
Imam Seagate Baracudda 200GB ATA133 in glih včeraj mi je DriveSitter program javil tole napako:
09.08.2006 12:51:02
Device: 0 [4LJ2YZT7] on 1BCE273B0A2E453
Manufacturer: Seagate
Volumes: C,D
DriveSitter has detected dangerous conditions for a device:
S.M.A.R.T. T.E.C. test ESTIMATED T.E.C. DATE WARNINGS.
Details:
Attribute 1 (Raw Read Error Rate); Value=55; Worst=51; Threshold= 6
ESTIMATED T.E.C. DATE 24.01.2007 (r=-0,66; r˛=0,43)
Advisory:
SEVERITY: QUESTIONABLE CONDITION
The T.E.C. Date Forecast Test calculated a date when device 0 [4LJ2YZT7] is
likely to fail.
Remember that T.E.C. dates are forecasts only that estimate the date when a
T.E.C. condition is likely to occur. This forecast is based upon the
development of S.M.A.R.T. values in the past, telling that, if the trend stays
as it is quite at the moment, the value will exceed the threshold on the
forecasted date.
Although we did everything to prevent false alarms, the detected trend might
change and the predicted unhealthy condition might never actually occur.
We recommend to inspect and observe the trend of the attribute values
carefully! You might also want to setup a T.E.C. alert threshold for certain
attributes to suppress false T.E.C. warnings until the attribute value falls
below a user-defined threshold. You can setup alert thresholds in the options
manager, "Device 0 [4LJ2YZT7]" - "T.E.C. Dates".
If you want to read more about T.E.C. forecasting, refer to the program help,
section "Articles - T.E.C. Forecasting" or search for "T.E.C." in the program
help index.
Jaz sem bil samo WTF?8-O in nisem pol nič več ugotavljal
Potem naslednji dan prižgem komp in tam na začetku ko preverja komponente mi napiše "Hard Disk Fail" nevem kaj je to. Imam disk še pod garancijo, svetujete da ga odnesem nazaj?
WTF!
amigo_no1 ::
Verjetno je disk šel v deŽelo večnega počitka
Odnesi nazaj če imaš garancijo.
Gamez0r ::
Ja evo zdaj mi dela normalno presneta reč blesava :)
Bom probal zagnati DriveSitter da vidim če mi bo spet javil to napako.
EDIT: HAHAHAAHA Zdaj mi pa nič ne javi, pa mislim kake ma tole čudne trike svoje jaz res nevem :D
WTF!
  • spremenil: Gamez0r ()
Napajalnik za TEC element
454351 (3609) Pyr0Beast
Povratek Peltierjevih elementov?
Oddelek: Novice / Procesorji
113157 (3157) TribesMan
thermo-electric cooling by Thermaltake
111228 (993) SoNgOkO
Novi vodni blok !
302062 (1575) morphling1
Kaj pravite na tole !
383173 (2386) element
