Forum » Pomoč in nasveti » Napaka pri zagonu...
Ozric ::
Ob zagonu XP-jev se prikažeta dve napaki - "Can't open kernel driver asLM75.sys" in "Can't load AsmiHwIo.dll".Menda gre za bug na Asusovih mat.ploščah? Any idea,kako to odpravit? Thanx..
- spremenil: Ozric ()
Izi ::
Če bi malo pogooglal tudi nebi škodilo.
Here is the best possible fix to the boot-up error: can't open kernal driver aslm75.sys and can't load asmiHWIO.dll
It is caused by the bios of ASUS motherboards in its attempt to autoexecute ASUS Probe upon bootup. Note that this has nothing to do with the normal functioning of ASUS Probe--only the startup auto execution mode.
The solution:
Open up ASUS Probe
Click on SETTINGS
Uncheck the box at the lower left corner that says "Auto-Execute ASUS Probe on startup."
Exit ASUS Probe.
Restart your computer and the error messages will not occur.
The solution:
Open up ASUS Probe
Click on SETTINGS
Exit ASUS Probe.
| » | Asus RT-N16 DD-WRT print serverOddelek: Omrežja in internet | 1636 (1526) | errhec |
| » | Ubuntu 9.04->10.04 = Mail ne dela večOddelek: Operacijski sistemi | 1379 (1296) | Icematxyz |
| » | [Debian] Po dveh dneh uporabe sem ga sesul :SOddelek: Operacijski sistemi | 2444 (2191) | Ice-Heki |
| » | connecting own dialling router to siol adslOddelek: Omrežja in internet | 2764 (2660) | enis |
| » | FreeBSD - nekaj newbie vprašanjOddelek: Operacijski sistemi | 1599 (1461) | ghaefb |
