Forum » Izdelava spletišč » problemcek pri nastavitvi dovoljenj direktorijem?
freeglobe ::
Se jest z manjsim problemckom. Vzel sm si en template iz neta kao digishop, problem se pojavi pri 9 koraku instalacije. Navajam:
STEP 9: Using your FTP program, upload the CONTENTS of your Secure
folder to this secure directory. Next, change the permissions for
following directories, to allow files to be saved inside these
directories. Try chmod 644 initially, if that doesn't work, try
chmod 777 (use with caution). This is also information WE CANNOT
provide you with. Ask your network administrator, if you need help.
secure/images/products
secure/images/categories
Iz tega sm razbrav, da morm nastavit username in pass, drugacn kot imam dostop do database? Uporabljam Xampp program.
Zanima me kaj morm nardit v tem koraku instalacije, pa ce je moja resitev pravilna, kje in kako nastavit dodaten user, pass , samo za določene objekte.???oz. dovoljenje do direktorijev. Nastavim to v phpmyadmin oz. kje? Hvala. LP
- zaklenil: OmegaBlue ()
OmegaBlue ::
Ne podvajaj tem.
| ! | Postavitev Apache serverja s podporo za PHP in MySQL (strani: 1 2 3 4 5 6 7 )Oddelek: Izdelava spletišč | 276340 (20241) | miko22 |
| » | Apache - localhost JA, IP naslov NEOddelek: Omrežja in internet | 7271 (7130) | ManDriver |
| » | GeForce 4 MX440 Linux gonilnikiOddelek: Pomoč in nasveti | 1242 (1218) | c0dehunter |
| » | Kaj pomeni ASCIIOddelek: Izdelava spletišč | 2087 (1996) | Enzo77 |
| » | Program za web server?Oddelek: Omrežja in internet | 2861 (2720) | Hojne |
