Forum » Izdelava spletišč » Kaj pomeni ASCII
Kaj pomeni ASCII
Elemen_T ::
To je elektronski zapis, v bistvu kodna tabela zapisana samo s številkami
http://www2.arnes.si/~ssptvogl/ascii.htm
AlBundy ::
Ok, forum to od mene zahteva,...kako ga lahko uveljavim. No tukaj so navodila, pa jih delno razumem.
Uploading the ikonboard CGI directory files
Upload the contents of the INSTALL_DATA directory from the un-zipped zip file on your computer into the newly created INSTALL_DATA directory on your server. All of these files should be uploaded in ASCII.
Navigate into the INSTALL_DATA directory on the server. CHMOD all the files [ board_rules.dat, cgi_path.html, cgi_url.html, email_template.dat, index.html, mem_groups.dat, non-cgi_path.html, non_cgi_url.html ] to '0777' (See Figure B).
Upload the contents of the install_modules directory from the un-zipped zip file on your computer into the newly created install_modules directory on your server. All of these files should be uploaded in ASCII.
Navigate into the install_modules directory on the server. CHMOD all the files and directories to '0777' (See Figure B).
Navigate back to your ikonboard CGI directory.
Now upload all the *.tar files [Data.tar, Database.tar, Languages.tar, non-cgi.tar, Skin.tar, Sources.tar ] in BINARY. CHMOD these files to '0777' (See Figure B).
You should still be in your ikonboard CGI directory.
Upload ikonboard.cgi and installer.cgi (or ikonboard.pl and installer.pl if you've changed the suffix). in ASCII. CHMOD these files to '0755' (See Figure A).
NOTE: Your webhost may use a different set of permissions to execute perl scripts. Please double check with your webhost if you are unsure.
Upload ikonboard.conf in ASCII. CHMOD this file to '0777' (See Figure A).
> Uploading: Step 3
Creating a directory in the 'public_html' part of your webspace
Navigate into the public_html directory on your server. You should see all the webpages from your webiste in this directory.
Create a directory called iB_html.
CHMOD this new directory to '0777' (see Figure B)
Create a directory called uploads inside the iB_html directory and CHMOD to 0777.
Create a directory called non-cgi inside the iB_html directory and CHMOD to 0777.
You have now completed all the file uploads needed to install Ikonboard.
> Uploading: Step 3
Elemen_T ::
Razne slike (.jpg,.gif,.png,...) in HTML fajle moraš na strežnik naložit v načinu BINARY (to določiš pri nastavitvah za konekt na ftp server), naprimer .cgi,.pl,.sql, itd pa moraš dat na server v načinu ASCII.
Tisti chmod pa določaš naknadno (desni klik na datoteko, tam noter maš ukaz CHMOD ali pa permissions.
rc-car ::
CuteFTP ti sam izbere pravilen način prenosa, tako da tebi ni treba nič spreminjat.
Ti samo uploadej in CHMODaj :)
Nothings gonna stop me now, I'm breaking the rules, I'm gonna do it if its not allowed
| » | Apache - localhost JA, IP naslov NEOddelek: Omrežja in internet | 7284 (7143) | ManDriver |
| » | VsftpOddelek: Operacijski sistemi | 1778 (1685) | trnvpeti |
| » | php galery samo za adminaOddelek: Izdelava spletišč | 1303 (1208) | Tody |
| » | Iščem alternativo vudujuOddelek: Kaj kupiti | 2450 (2214) | Arthur |
| » | Narediti svoj FORUM (strani: 1 2 )Oddelek: Programiranje | 6470 (5887) | bzagozen |
