problemcek pri nastavitvi dovoljenj direktorijem?
freeglobe ::
Se jest z manjsim problemckom. Vzel sm si en template iz neta kao digishop, problem se pojavi pri 9 koraku instalacije. Navajam:
STEP 9: Using your FTP program, upload the CONTENTS of your Secure
folder to this secure directory. Next, change the permissions for
following directories, to allow files to be saved inside these
directories. Try chmod 644 initially, if that doesn't work, try
chmod 777 (use with caution). This is also information WE CANNOT
provide you with. Ask your network administrator, if you need help.
secure/images/products
secure/images/categories
Iz tega sm razbrav, da morm nastavit username in pass, drugacn kot imam dostop do database? Uporabljam Xampp program.
Zanima me kaj morm nardit v tem koraku instalacije, pa ce je moja resitev pravilna, kje in kako nastavit dodaten user, pass , samo za določene objekte.???oz. dovoljenje do direktorijev. Nastavim to v phpmyadmin oz. kje? Hvala. LP
Ziga Dolhar ::
https://dolhar.si/
OmegaBlue ::
Ne podvajaj tem.
Postavitev Apache serverja s podporo za PHP in MySQL (strani: 1 2 3 4 5 6 7 )
Oddelek: Izdelava spletišč
322275697 (19598) miko22
Apache - localhost JA, IP naslov NE
Oddelek: Omrežja in internet
187243 (7102) ManDriver
GeForce 4 MX440 Linux gonilniki
51226 (1202) c0dehunter
Kaj pomeni ASCII
62073 (1982) Enzo77
Program za web server?
92845 (2704) Hojne
