Dejanska lestvica Super Pi 1M
2 3 4
zbogi ::
LESTVICA SUPER PI MOD 1.5 1M TOP 30
1 . zbogi | 18.985 s | Intel Yonah T2600 @ 3250 | DDR2@ 416 MHz 4-4-4-8 | SS kompresor | >:D
2 . Good Guy | 20.329 s | Intel Yonah T2600 @ 3075 | DDR2@ 333 MHz 4-4-4-12 | vodno | :D
3 . sharp | 21.922 s | Intel Dothan 730 @ 3500 | DDR@ 233 MHz 2-2-2-5 | kaskada | 8-)
4 . Moonman | 22.437 s | Intel Dothan 740 @ 3374 | DDR@ 260 MHz 2-2-2-5 | mach I modded |
5 . zbogi | 23.078 s | AMD FX-55 @ 3611 | DDR@ 278 MHz 2-2-2-0 | liquid N2 |
6 . Moonman | 23.281 s | AMD Opteron 146 @ 3546 | DDR@ 253 MHz 2-2-2-5 | mach I modded |
7 . GUFY | 23.343 s | AMD Opteron 146 @ 3576 | DDR@ 255 MHz 2-2-2-5 | SS kompresor |
8 . Shark-357 | 23.907 s | AMD Opteron 146 @ 3504 | DDR@ 250 MHz 2-2-2-5 | dry ice |
9 . LittleDevil | 24.282 s | AMD Opteron 146 @ 3480 | DDR@ 260 MHz 2-2-2-5 | SS kompresor |
10 . CYK | 24.750 s | AMD San Diego 3700+ @ 3355 | DDR@ 305 MHz 2.5-4-3-6 | mach II |
11 . mykeos | 25.907 s | AMD Opteron 146 @ 3368 | DDR@ 240 MHz 2-2-2-5 | SS kompresor |
12 . Primoz78 | 26.203 s | AMD Opteron 146 @ 3224 | DDR@ 322 MHz 2.5-4-3-6 | vodno |
13 . Legoless | 26.968 s | Intel Dothan 730 @ 2643 | DDR@ 264 MHz 2-2-2-5 | zracno |
14 . umax | 27.437 s | AMD Opteron 170 @ 3100 | DDR@ 258 MHz 3-3-2-5 | vodno |
15 . tiborrr | 28.062 s | AMD Opteron 144 @ 2962 | DDR@ 269MHz 3-4-3-8 | vodno |
16 . gfighter | 28.203 s | AMD Opteron 165 @ 3006 | DDR@ 234MHz 2-2-2-5 | zracno
17 . GaS | 28.297 s | AMD Opteron 146 @ 2884 | DDR@ 262 MHz 2-2-2-5 | zracno |
18 . mile | 28.453 s | AMD Opteron 146 @ 3022 | DDR@ 251 MHz 2-2-2-5 | vodno |
19 . Brvar | 29.516 s | AMD Opteron 148 @ 2816 | DDR@ 256 MHz 2.5-3-3-5 | zracno |
20 . Gajba | 29.516 s | AMD Venice 3000+ @ 2827 | DDR@ 257 MHz 1,5-2-2-5 | vodno |
21 . mitjaje | 29.672 s | AMD X2 4400+ @ 2805 | DDR@ 255 MHz 2-2-2-5 | vodno |
22 . Jenej01 | 29.750 s | AMD Venice 3000+ @ 2835 | DDR@ 258 MHz 2-2-2-5 | zracno |
23 . DominusSLO | 29.828 s | AMD Opteron 144 @ 2871 | DDR@ 205 MHz 2.5-3-3-6 | vodno |
24 . AndrewSmith | 29.844 s | AMD Venice 3200+ @ 2900 | DDR@ 241 MHz 2-2-2-5 | vodno |
25 . Type-R | 30.172 s | AMD Venice 3000+ @ 2925 | DDR@ 209 MHz 2-3-2-5 | zracno |
26 . KraP | 30.734 s | AMD Venice 3200+ @ 2891 | DDR@ 240 MHz 2.5-3-3-7 | zracno |
27 . sid911 | 30.906 s | AMD X2 3800+ @ 2888 | DDR@ 206 MHz 2.5-3-3-6 | zracno |
28 . >>><<< | 31.437 s | AMD San Diego 3700+ @ 2750 | DDR@ 230 MHz 2.5-3-3-6 | zracno |
29 . Malkec | 31.657 s | AMD Opteron 165 @ 2998 | DDR@ 214 MHz 2.5-3-3-7 | vodno |
30 . HyperGL | 32.281 s | AMD Venice 3200+ @ 2796 | DDR@ 233 MHz 2.5-3-3-6 | vodno |
31 . b0r1s | 32.640 s | AMD X2 3800+ @ 2601 | DDR@ 289 MHz 3-3-3-6 | vodno |
32 . Veron | 32.657 s | AMD X2 3800+ @ 2688 | DDR@ 224 MHz 2.5-3-3-5 | zracno |
33 . sid911 | 33.610 s | AMD Venice 3200+ @ 2651 | DDR@ 219 MHz 2.5-3-3-8 | zracno |
34 . Veron | 34.516 s | AMD Venice 3000+ @ 2457 | DDR@ 223 MHz 2.5-3-3-5 | zracno |
35 . Hammer | 35.000 s | AMD X2 3800+ @ 2607 | DDR@ 173 MHz 2.5-3-3-7 | zracno |
36 . Bidox14 | 37,453 s | AMD Venice 3500+ @ 2593 | DDR@ 235 MHz 2,5-3-3-6 | zracno |
37 . mare87 | 37.484 s | AMD Barton 2600+ @ 2806 | DDR@ 233 MHz 2-2-2-5 | zracno |
38 . Lotko | 37.891 s | AMD Venice 3200+ @ 2601 | DDR@ 186 MHz 3-4-4-8 | zracno |
Podkategorija Intel
Podkategorija AMD
1 . zbogi | 23.078 s | AMD FX-55 @ 3611 | DDR@ 278 MHz 2-2-2-0 | liquid N2 |
2 . Moonman | 23.281 s | AMD Opteron 146 @ 3546 | DDR@ 253 MHz 2-2-2-5 | mach I modded |
3 . GUFY | 23.343 s | AMD Opteron 146 @ 3576 | DDR@ 255 MHz 2-2-2-5 | SS kompresor |
Member of OC-Lab Team
http://www.oc-lab.si/
  • odklenil: gfighter ()
zbogi ::
če sem koga kje umes pozabil naj pove, pa naj kak moderator tole prevzame, lohk zrihta še linke do userjev, lohk združite z obstoječo temo, lohk nardite še naprej od 10., jst sem dal not tiste ko sem našel v temi od superpi rezultatov, vse pod 30s.
JIM22 ::
zbogi: dober si se tole spomno, da ima folk pregled nad rezultati, ne pa da pregleduje celo temo. Svaka čast!;)
Digitalni marketing, nastop na spletu v naročnikovem imenu.
Vsi na FB pridružite se itVision :)
zbogi ::
thx, sej je bil že čas, ej jim drugač pa tebe pogrešam med rezultati, a bo kej?
LittleDevil ::
En star rezultat samo vseeno boljši od tega na lestvici... Prosim za update...
CPU:Venice 3000+ @ 3324Mhz
Rami:Geil Ultra-X @ 246Mhz (2.2.2.5)
Hlajenje:single stage kompresor
superPI 1M rezultat 25.796
Jenej01 ::
Nisem si mislil da bom prisel med top 10. Juhu :D
Bom se tale vikend probal potrudit se za kaksen mhz.
lp jenej
P5Q PRO, E7300@3400Mhz, 4GB@... itd :D
JIM22 ::
zbogi: sej če bi pogledal dost nazaj bi videl moj rezultat z venice 3200+ navit mal čez 3ghz. Zdej imam sandiego ki se ne navija tako dober(moral bi se malo igrat), opteroni so pa pocrkal.;(.
Moonman ::
CPU: Opteron 146 @ 3474Mhz
Rami:Teamgroup BH-5 @ 248MHz
superPI 1M rezultat 24.078
Jenej01 ::
Cestitke, drugo mesto...
lp jenej
Moonman ::
Hvala.
Še malo tveakanja pa bo sub 24s.
JIM22 ::
Svaka čast!
Moonman ::
Še en update:
CPU: Opteron 146 @ 3496Mhz
Rami:Teamgroup BH-5 @ 250MHz
superPI 1M rezultat 23.984
sharp ::
CPU: Dothan 730(1.6)@3304mhz
Rami:Twinmos pc3200 bh-5@275 mhz cl 2.2.2.5
Hlajenje:Kaskada -105°c
Tole je samo na windowsih 2k ,zid pa zadanem pri 280fsb-ja,bo treba narediti vagp mod.
Drive fast as your guardian angel can fly.
zbogi ::
congrats sharp, i knew you can do it :D
sharp ::
Thx zbogi,moram inštalirat 2k3 in probat z tistim filetkom.;)
sharp ::
Ampak je tako mrzzzzzlo v garaži,da sem včeraj skor znoru k sem nalagu windowse.:D
fras ::
Čestitke tudi z moje strani sharp :D
sharp ::
Thx:D
Moonman ::
Dober dosežek, a vem, da ga lahko še izboljšaš ;)
A si torej le dobil heatspreader?
Good Guy ::
lol mrzlo
Čestitke!
http://goo.gl/7ItKpU
Naj računalnik dela za vas^^
sharp ::
Moonman:Thx:D bom še probal izboljšat,sej procesor gre z lahkoto na 3350mhz ampak potem me zabremza fsb,neglede na delilnik.
Ne sem dal kar direkt,brez heatspreaderja.:O
Rovtar:Thx
Good Guy ::
na kteri plati si to naviju?
poskusi zamenjat plato, mogoče bo šlo višje ? :D
PrimozR ::
I guess P4C800...
sharp ::
Jup,p4c800
mare87 ::
Same 64-tke, c c c ;). Rezultat je glede na FSB slab, ker laufam CPC 2T. Upam na kakšen test z 2x256 voltage loverji:D (ČIP 008! ;)
CPU: Barton 2600+M @ 2806 MHz
Rami: 2x512 TwinMOS SP 3500 (BH-5) @ 233 MHz (2,2,2,7)
Hlajenje: Zračno (zunaj -10°c, ohišje 6°c)
SuperPI 1M rezultat: 37.484 sekund
EDIT: Vidim, da je TOP 100:). Škoda.
  • spremenil: mare87 ()
PrimozR ::
Čak it maš BH-5ke, po možnostzi stare, hudo burn-inane, pa hoč 'voltage loverje'??? Mater, kaj čakaš, spust 3,5V skoz jih! :D
mare87 ::
Heh, ja saj ti grejo 244 MHz, 2, 2, 2 , x stabilno na 3.25v, ampak so 2x512 in treba dat CPC na 2T, če hočeš kam sploh prit (na nf 2);) . Z 2T pa zgubim malo manj kot 2 sekundi, zato bi rad sprobo 2x256, samo itak nima smisla, ker je lestvica preozka>:D.
PrimozR ::
Aja, ti bi 256tke...
Good Guy ::
offtopic
dejte tole pod STICKY
GUFY ::
CPU: Opteron 146
Rami: 2x512 Geil One BH-5
Hlajenje: Kompresor
SuperPI 1M rezultat: 23.953 sekund:D
  • zavaroval slike: GUFY ()
PrimozR ::
Pošteno tole GUFY. Dobr ti leti tale proc.
Shark-357 ::
Opteron on dryice @3504mhz
ram@250mhz
Žal nisem uspel zraven pripeti a64tweaker in cpu-z
ram je bil nastavljen takole ...
GUFY ::
Super rezultat bravo Shark!
GUFY ::
tiborrr ::
Cestitke tako tebi, GUFY, kakor tudi Sharku! 8-)
Good Guy ::
mater vam dobro letijo tejle proci:D
Good work, keep it on...8-) 8-)
mykeos ::
Bonus falus pax in domus!
X6800,P5W DH DELUXE,G.SKILL 2GB 6400,7800 GTX,Silverstone ZEUS 550W
  • spremenilo: mykeos ()
mykeos ::
Opteron 146@3368mhz,1.78V>:D
RAM OCZ EL Gold 3200
2x512MB
2-2-2-5
240mhz
fazno hlajenje
Rezultat:25.907
Shark-357 ::
Tole je kar slabo za phase change moj je šel 3315mhz z vodnim...
LittleDevil ::
Shark-357 če ima cold-bug in ne najboljši stepping, pomojem ni slabo...
mykeos ::
shark,tvoja izjava je podobna čudenju,zakaj 101ka s pirelijevimi
gumami ne preseže 110km/h...:P
tiborrr ::
Hehe, pravkar spravil moje Apacercke PC4000 512MB (jajcka) na 270 2.5-4-4-8 1T stabilno, 2.7Vdimm, 702-1 bios, trenutno 30.9s pri 300x9, 1.55v. :D
MEDENA ::
Lepa kinder jajčka :D
tiborrr ::
Zelo lepa, ja, ker na prejsnjih dveh platah nisem spravil 1T nad 240MHz. Se vidi, kaj pomeni dober BIOS support... :)
tiborrr ::
Evo se moj rezultat:
AMD Opteron 144 @ 312x9 = 2808MHz, vodno hlajen, 1.58Vcore (full load 35-36°c v S&M)
RAM: 2x512MB ApacerPC4000 @ 2.5-3-3-7 1T 255MHz, 2.7Vdimm v BIOSu (2.77V realno)
DFI LP UT nF4-UltraD (Vdd=1.6v)
  • zavaroval slike: OmegaBlue ()
tiborrr ::
OK, sem opazil, da vas vecina noce postat v to temo, zato vabim vse, da pricno tekmovati. Lestvica je raztegnjena na top 30! :)
Primoz78 ::
...window action rezultat...Rami so bli na 2,5-4-3-6. Ce bi mel BH/CH-5 rame bi verjetno blo pod 26s...;)
Lp Primoz
GAMING HTPC I5 2500k/ASUS P8P67/4GB CORSAIR XMS3/
VERTEX 3/ASUS 670 GTX OC/Antec TP-650 NEW/
zbogi ::
lahko bi tud mal updatal lestvico.
LittleDevil ::
tiborrr končno ti je potegnilo da se epox ne more primerjati z DFI... :D
AndrewSmith ::
1)Venice3200/DfiUltraD/2x512UltraX-BH5/X800Xl/LG DVDRW/Seagate320Gb
2)3xTechnics1210MK5/FinalScratch/DJM600/SennheiserHD25/
2xProel15A@250rms/1xB&C 15"@750rms
2 3 4
Slo-tech superpi team: intel core 2, i5, i7 &amp; amd am2, am3 lestvica (strani: 1 2 3 4 5 6 )
Oddelek: Navijanje
264309308 (69901) krneki0001
Slo-Tech 3D Team: 3D Mark 2003 (strani: 1 2 3 4 5 6 7 )
Oddelek: Navijanje
32998642 (50580) Shark-357
Slo-Tech 3D Team: 3D Mark 2001se (strani: 1 2 3 4 5 6 7 8 9 )
Oddelek: Navijanje
40078167 (31347) Shark-357
superPI lestvica (strani: 1 2 3 4 5 6 7 8 9 )
Oddelek: Navijanje
40136292 (21756) gfighter
TEST RAMA to na bi bil članek ampak......
Oddelek: Navijanje
184055 (3226) Primoz78
