Unattended install for Windows - beginner
Klemenn ::
Torej...moj file ki je v i386 shranjen kot WINNT.SIF
;SetupMgrTag
[Data]
AutoPartition=0
MsDosInitiated="0"
UnattendedInstall="Yes"
AutomaticUpdates=yes
[Unattended]
UnattendMode=FullUnattended
OemSkipEula=Yes
OemPreinstall=No
TargetPath=\WINDOWS
FileSystem=*
UnattendSwitch="yes"
WaitForReboot="No"
KeyboardLayout="Slovenian"
[GuiUnattended]
AdminPassword=*
EncryptedAdminPassword=NO
AutoLogon=Yes
AutoLogonCount=1
OEMSkipRegional=1
TimeZone=95
OemSkipWelcome=1
[UserData]
ProductKey=*****-*****-*****-*****-*****
FullName="Name"
OrgName="Organization"
ComputerName=Racunalnik
[Display]
BitsPerPel=32
Xresolution=1024
YResolution=768
Vrefresh=85
[TapiLocation]
CountryCode=386
Dialing=Pulse
AreaCode=07
[RegionalSettings]
LanguageGroup=2
SystemLocale=00000424
UserLocale=00000424
InputLocale=0424:00000424
[Identification]
JoinWorkgroup=mshome
[Networking]
InstallDefaultComponents=Yes
[Components]
msmsgs=off
msnexplr=off
zonegames=off
AutoUpdate = On
stvar ne dela! še vedno sprašuje za serijsko...in ostalo..zakaj? :(
btw, kaj naj bi naredil z tistim unnatend.bat...? nikjer ne piše da bi ga moral kam dati..? jaz sem samo preimenoval un txt file v WINNT.SIF in skopiral v i386..torej kdo ve?
  • spremenil: Klemenn ()
TitanSLO ::
OemPreinstall=No mora biti yes
Evo moj winnt.sif od winxpsp2 še nekaj dodatkov
;SetupMgrTag
[Data]
AutoPartition=0
MsDosInitiated="0"
[Unattended]
OemSkipEula=Yes
OemPreinstall=Yes
TargetPath=WINXPSP2
WaitForReboot="No"
DriverSigningPolicy=Ignore
NonDriverSigningPolicy=Ignore
Hibernation=No
[GuiUnattended]
AdminPassword=*
OEMSkipRegional=1
TimeZone=95
OemSkipWelcome=1
[Display]
BitsPerPel=32
Xresolution=1024
Yresolution=768
AutoConfirm = 1
Vrefresh=75
[UserData]
FullName="ddSHADOW"
OrgName=""
ComputerName=en-pac
[TapiLocation]
CountryCode=386
AreaCode=03
Dialing=Tone
[RegionalSettings]
LanguageGroup=2
UserLocale=00000424
[Identification]
JoinWorkgroup=WORKGROUP
[Networking]
[Components]
msmsgs=off
msnexplr=off
zonegames=off
[WindowsFirewall]
Profiles = WindowsFirewall.TurnOffFirewall
[WindowsFirewall.TurnOffFirewall]
Mode = 0
[Shell]
CustomDefaultThemeFile="%WinDir%\Resources\Themes\VistaXP.theme"
[SetupData]
OsLoadOptions="/noexecute=alwaysoff /fastdetect"
Klemenn ::
OemPreinstall=Yes or No
This option is default to No but if you are using the $OEM$ Distribution folders then it needs to be set to Yes, so that Setup regards this installation as a distribution and copies these files over to the system drive. This occurs at the end of Text-mode Setup.
zakaj že? sej nimam nikjer nobenega $OEM$ folderja in pa noter karkoli..?
TitanSLO ::
Kdaj se ti vstavi pri vnosu kode al že pri začetku ko moraš prebrat licenco.
P.S. Poglej če ni slučajno datoteka WINNT.SIF.TXT klasicna napaka, ker ponavadi uporabniki nimajo vključeno prikaži končnice datotek v raziskovalcu.
LP dd
  • spremenil: TitanSLO ()
Klemenn ::
vnosu kode...licence ni treba prebrat..
sem probal na virtual pc
ko zaženem (naredu bootable) gre vse avtomatsko..izberem le particiji (kar hočem) in kaj naj naredi z particijo (format) in to je vse..potem pa w @windows instalaciji pokaže da bi rad serijsko..
ki pa je sigurno taprava ...saj je delala že na prejšnjih inštalacijah :\
Klemenn ::
nope! 8-)
TitanSLO ::
če je licenčna serijska ne bi smelo bit problemov, če pa ni pa moraš vedeti da je SP2 blokiral doti piratskih SN, stestirajo to serijsko številko, ki jo imaš na localni mašini, kjer imaš windowse, serijsko spremeniš lahko s tem programčkom DOWNLOAD
[Windows XP] Vaš račun je potekel (strani: 1 2 3 )
Oddelek: Operacijski sistemi
11916091 (12926) fosil
Dell OEM Win XP in izgubljen CD
112604 (2604) Paramedic
Ena Microsoftova finta
121787 (1348) denial
Tokrat varnost za ta konec tedna (strani: 1 2 )
739669 (7835) EjTi
XP-ISO-BUILDER
Oddelek: Programska oprema
91410 (1289) Primoz78
