Forum » Omrežja in internet » Telemach in slab downlaod
nejcpirc ::
Zadnje nekaj dni je hitrost downloada padla, upload se mi zdi, da je tak kot ponavadi, na helpdesku pa pravijo, da imam slab signal tukaj v stanovanju, tako da bojo prisli precekirat kable...
Sicer imam 1024/256 paket....speedtest pa pravi:
Pritisnite START
Iskanje vmesnih naprav . . . . . . . . . . . . . . . . . . . . . . . OK
izvajam 10s upload test (v smeri k internetu) 239.48Kb/s
izvajam 10s download test (v smeri k vam) 471.90kb/s
Pritisni START za ponovno meritev
izvajam 10s upload test (v smeri k internetu) 236.20Kb/s
izvajam 10s download test (v smeri k vam) 148.42kb/s
izvajam 10s upload test (v smeri k internetu) 234.10Kb/s
izvajam 10s download test (v smeri k vam) 271.58kb/s
Ce PINGAM Telemach.net:
Pinging www.telemach.net [213.143.65.4] with 32 bytes of data:
Reply from 213.143.65.4: bytes=32 time=6ms TTL=61
Reply from 213.143.65.4: bytes=32 time=14ms TTL=61
Reply from 213.143.65.4: bytes=32 time=5ms TTL=61
Reply from 213.143.65.4: bytes=32 time=7ms TTL=61
Ping statistics for 213.143.65.4:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 5ms, Maximum = 14ms, Average = 8ms
SIOL.net
C:\Documents and Settings\nejc>ping www.siol.net
Pinging jupiter.siol.net [193.189.160.234] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 193.189.160.234:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss)
Pinging www.siol.si [213.250.3.44] with 32 bytes of data:
Reply from 213.250.3.44: bytes=32 time=6ms TTL=249
Request timed out.
Reply from 213.250.3.44: bytes=32 time=8ms TTL=249
Ping statistics for 213.250.3.44:
Packets: Sent = 4, Received = 3, Lost = 1 (25% loss),
Minimum = 6ms, Maximum = 8ms, Average = 6ms
Pa se modem diagnostika:
Forward Path: Return Path:
Signal Acquired at 490.000 MHz Connection: Acquired
SNR: 28.0 dB Frequency: 45.0 MHz
Received Signal Strength: N/A Power Level: 49.8 dBmV
Micro-Reflections: 28 dBc Channel ID: 2
Modulation: 256 QAM Modulation: QPSK
Kje je pol problem, v napeljavi pri meni ali pri njih? Ima zadnje dni se kdo podobne probleme pri telemachu?
lp, n.
Pritisnite START
SIOL.net
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
lp, n.
nejcpirc ::
Prsu je njihov tehnik, pa zamenjal "razdelilc", ki deli kabel na TV in net...in to je to...
| » | KKS > Triera > UPC > Telemach (strani: 1 2 3 4 … 372 373 374 375 )Oddelek: Omrežja in internet | 3627860 (464) | MrStein |
| » | speedtest.siOddelek: Omrežja in internet | 14220 (12608) | Pesimist |
| » | Hipkom.net internet povezava (strani: 1 2 3 4 5 6 )Oddelek: Omrežja in internet | 24173 (13281) | rontajzel |
| » | Slab ping - What to do?Oddelek: Omrežja in internet | 2979 (2580) | KoReNJe |
| » | Telemach slabo deluje?Oddelek: Omrežja in internet | 3242 (2246) | Xplicit |
