Forum » Navijanje » DFI NF3 in BH5
DFI NF3 in BH5
Tic ::
Zivjo,
na enemu racunalniku imam to konfiguracijo;
Athlon 64 3000+ NewCastle oz Sempron 2600 Paris (bomo vidl kater je boljsi OCer)
DFI Lanparty NF3 250gb
2x256 HyperX BH5
Antec TP 430W
Voodoo 3 2000 16mb PCI :)
Zanima me, kako je kaj z biosi za dfijev NF3, kakšna stran, kjer imajo to vse zbrano za BH5? Je še kakšna fora za bolj optimizirane nastavitve? Naj se ocjanje pricne :P
Tic
2x256 HyperX BH5
Antec TP 430W
Tic
persona civitas ;>
Shark-357 ::
Jaz ko sem še imel DFI NF3 se najbolje obnesel 515 bios..
malo poglej po DFI-street.com v bios factory ...
tam se bo ziher našlo kaj
klik..
klik..
KraP ::
Shark-357 ::
copy from XS...
find a max stable speed at 3.2V then loop memtest 5 or 8 overnight.then try increase by 1MHz and do same next night.when not burning in(during the day) run them at say 200MHz 3-3.1V so they are taking a break. after a couple of nights up to 3.3V and do same.once you reach the 3.5V mark and highest speed then loop them overnight @3.5V and max speed. next day drop to 3.2V and run them in windows as normal with relaxed speed(less than their 3.2V max). then that night try to drop the volts as little as poss and try to run at the max speed they did at 3.5V.dont use memtest but use something like sandra bandwidth burn-in on a constant loop.repeat this method overnight using different mem stressors that dont halt on errors.hopefully you will reach the previous max clock on slightly lower volts giving a higher max clock at 3.5V.be patient and try this over a few weekssettings, well start with these in order in BIOS.
1.5
2
5
2
8
15
3
3
2
2
3120
auto
en
auto
0
auto
level8
level2
8ns
6ns
16
en
16x
7x
dis
then you can maybe tighten some of:trc,trfc,twr,twtr,trtw,trrd,max async,read preamble once you find the highest stable clock.
e.g. trc=7 might be stable but may not. also I can run trfc14,max async 6ns,read preamble 4ns while others cant etc. so just experiment after finding highest speed poss after burn-in.
also try the 510-2 as i can clock about 10MHz higher than with 618-2 but may be different for you so find highest on 618-2 after burnin then try 510-2.
1.5
2
5
2
8
15
3
3
2
2
3120
auto
en
auto
0
auto
level8
level2
8ns
6ns
16
en
16x
7x
dis
Tic ::
Sam tole ne razumem čist dobr burnanje. Mi lahko poveš v slovenčini, ker nisem prepričan za par zadev.
Tic
Tic
persona civitas ;>
Shark-357 ::
Ej sry ne odpre mi Dfi-street.com ... tako da ti težko pomagam...
ko zrihtajo site malo pobrskaj po forumu ker tam je polno nekih biosov sam sem že malo ven padel iz 754 ker sem že lep cajt na 939...
Shark-357 ::
Ja sej tako kot piše najdi najvišjo frkvenco na kateri ti delajo rami @3.2V pol loopaj memtest test 5# čez noč (kakih 10h) potem dvigni za 1mhz in spet isto...tako pač postopoma dviguješ fsb in voltažo...včasih čez dan pa spusti fsb in voltažo da se kao ram spočije...
- spremenil: Shark-357 ()
Tic ::
Hvala.
Ta bios... ne najdem ga? A je to kak modan bios al offical? Do kolk gre vmem, jaz bi rad na 3.5v poganjal, če je to sploh še varno za NewCastle? Vem da nova jedra furajo zelo visoko, za stara pa vem, da so se bali...
Tic
Tic
persona civitas ;>
KraP ::
Z 4.5 biosom mas 4V max ampak mors met modan napajlnik.
Jaz 3000+ @ 2700 poganjam z 1.82V , ram pa z 3V
LP KraP
LP KraP
- spremenil: KraP ()
KraP ::
original dobis na pagu od maticne, modane pa imas v linku ko sem ga dal (3. post)
( se opravicujem bios je 5.4 in ne 4.5)
evo tukaj si cukni 5.4 spila ko raketa BIOS BIOS
Tic ::
Uuuuu hudo... a je kšn bolši od tega prejšnga?
Tic
ps: danes začnem burnat bh5 rame pa pol lah vidmo razliko...
Tic
persona civitas ;>
Tic ::
A lahko s prime95, nastimam obremenitev ramov in pol burnam? Oz neki druzga k mem test pa da je za v win okolje?
persona civitas ;>
Tic ::
239 stable v sisoft sandra na 3.1v (kr en napajalc, antec je na modanju, tko da je blo mn k 3.1) BIOS ne dopušča več??? Ce sem sel na 240 je sandra nardila blue screen, memtest pa je ene par minut tudi na 245 delal brez errorjev (več časa nisem probal)
persona civitas ;>
Tic ::
Ok, pridobil sem 1.5mhz (240.55). Kar znese cca 30mb/s.
Pri 241.5 mi sandra zmrzne, pri 242.5 pa blue screen.
persona civitas ;>
- spremenil: Tic ()
tiborrr ::
You're impatient!
Se enkrat precitaj zgornji sestavek v anglescini.
| » | DFI NF 4 & Twinmos Speed Premium novosti (strani: 1 2 3 4 … 13 14 15 16 )Oddelek: Navijanje | 49340 (25017) | sirotka |
| » | Geil UltraX PC 3200 (strani: 1 2 3 4 )Oddelek: Navijanje | 21428 (18352) | b0r1s |
| » | AMD 64 z Venice jedrom (strani: 1 2 3 4 … 12 13 14 15 )Oddelek: Strojna oprema | 57905 (40268) | Jaffa |
| » | OCZ VX 3200 (strani: 1 2 3 )Oddelek: Navijanje | 10220 (7174) | PrimozR |
| » | Kateri bios za max. OC DFI Nf4 Ultra-D?Oddelek: Navijanje | 1968 (1441) | Shark-357 |
