Forum » Pomoč in nasveti » neki čudnga svchost.exe
Fly.MaCh!nE ::
ko grem v task manager pod procese mi proces svchost.exe zaganja 6x
. Zdj ga pa 3x uporabla System, 2x Network service pa 1x Local service
dj pa nevem a je to ok, a je kj narobe in če je kj narobe kok se da poštimat
gkovac ::
Jest jih mam 8
lp,
____________________________________________
"Left to themselves, things tend to go from bad to worse."
gzibret ::
Jaz jih imam 6.
Sem pa se enkrat spravil eliminirati ta svchost iz diska (ne vem, kje sem staknil, da je to virus, je pa res, da se mi je ves čas disk nekam čudno prižigal?). Zanimivi efekti. Windowsi NT so se po 15 minutnem mletju po disku celo pobrali. Samo uporabniški umesnik je bil zeloooo okrnjen. V bistvu si lahko naredil vse, ampak le preko ikonice My Computer. Nič start menija, nič taskbara itd....
Vse je za neki dobr!
Fly.MaCh!nE ::
no pol pa ql
sj jst sm tut enga sam ugasnu pa mi muske ni predvajal, tk da je ta pojav čist ok
ssitcm ::
Pazite kaj delate:
svchost - svchost.exe - Process Information
Process File: svchost or svchost.exe
Process Name: Microsoft Service Host Process
Description:
svchost.exe is a system process belonging to the Microsoft Windows Operating System which handles processes executed from DLLs. This program is important for the stable and secure running of your computer and should not be terminated. Note: svchost.exe is a process which is registered as the W32.Welchia.Worm. It takes advantage of the Windows LSASS vulnerability, which creates a buffer overflow and instigates your computer to shut down.
Description:
hudica!
pol je pa pr men neki narobe ker mam samo 2
no ja, eni so mal brez veze zalaufani, ampak eni so pa nujno potrebni.
| » | [ Windows XP ] svchostOddelek: Operacijski sistemi | 3822 (2197) | OmegaBlue |
| » | Pocasen internet - vzrok svchost.exe??Oddelek: Omrežja in internet | 4837 (3868) | residual |
| » | procesiOddelek: Programska oprema | 1080 (1045) | cryptozaver |
| » | svxhost.exe in systemOddelek: Pomoč in nasveti | 2766 (2557) | Tugo |
| » | Neznani programi ?Oddelek: Pomoč in nasveti | 1611 (1411) | mihhec |
