Forum » Izdelava spletišč » oscommerce v slo
oscommerce v slo
haha ::
še ne problem :P
Pri namestitvi
The following error has occurred:
The configuration files do not exist, or permission levels are not set.
Please perform the following actions:
* cd /opt/lampp/htdocs/webshop/catalog/includes/
* touch configure.php
* chmod 706 configure.php
* cd /opt/lampp/htdocs/webshop/catalog/admin/includes/
If chmod 706 does not work, please try chmod 777.
If you are running this installation procedure under a Microsoft Windows environment, try renaming the existing configuration file so a new file can be created.
Pa sem že vse probal pa vseeno ne dela
Pri namestitvi
CCfly ::
configure.php mora biti uporabniku na voljo za pisanje. Če si v Linuxu morajo biti vse datoteke in direktoriji v lasti uporabnika od strežnika Apache (verjetno www-data, apache, ...).
Za Windows pa ne bi vedel, vendar nasvet ti pravi, da configure.php preimenuj.
"My goodness, we forgot generics!" -- Danny Kalev
gregy ::
nobenega od nastetih problemov nisem imel, ker sem dobil MYSQL bazo pri ISP-ju in je bila instalacija fertik v petih minutah!
haha ::
Zdaj ko sem prišel do konca konfiguracije, hočem odpreti administraton tool mi pa vn vrže tole
Fatal error: Cannot re-assign $this in /opt/lampp/htdocs/webshop/catalog/admin/includes/classes/upload.php on line 31
CCfly ::
Razlog je uporaba PHP 5:
http://forums.oscommerce.com/index.php?s=1bf971ae57c658b97e961d9a1c10acc8&showtopic=153006
haha ::
Sedaj ko sm v adminu namestil slovenski jezik pa spet ne morem v admina.
Vn mi vrže tole
Warning: main(includes/languages//webshop/catalog/includes/langua.php): failed to open stream: No such file or directory in /opt/lampp/htdocs/webshop/catalog/admin/includes/application_top.php on line 130
Fatal error: main(): Failed opening required 'includes/languages//webshop/catalog/includes/langua.php' (include_path='.:/opt/lampp/lib/php') in /opt/lampp/htdocs/webshop/catalog/admin/includes/application_top.php on line 130
Vn mi vrže tole
gregy ::
brez zamere ampak jaz ne vem kako ti uspe tako strikat ce je pa OSC "out of box" ...
poleg tega ne vem kaksen url je tole 'includes/languages//webshop/catalog/includes/langua.php'
razumem da bi bil inlcudes/languages/slovene .. poleg tega langua.php ni nobenga fajla v osc!
ti imas nastavitve popolnoma s**bane :) .. dej vse delete, pa dej se enkrat install .. je pa res, da teh errorjev ne bi sploh videl če bi zadevo deval na porihtan server .. IMHO
haha ::
Zato sem pa prosil, da mi jo kdo pošlje.
Sedaj ko sem zbrisal in ponovno poskušal namestiti mi spet n vrže tole
Ampak imam vsa dovoljenja za pisanje in branje datoteke.
haha ::
Končno mi je uspelo namestiti oscommerce, sedaj pa me zanima kako namestim svoj template in kaj moram narediti, da mi bodo delali šumniki
haha ::
Imam problem z jezikom. Ko sem naštimal slovenski jezik, ne morem v admina, vn mi vrže tole:
Warning: main(includes/languages/slovensko.php): failed to open stream: No such file or directory in /opt/lampp/htdocs/webshop/catalog/admin/includes/application_top.php on line 130
Fatal error: main(): Failed opening required 'includes/languages/slovensko.php' (include_path='.:/opt/lampp/lib/php') in /opt/lampp/htdocs/webshop/catalog/admin/includes/application_top.php on line 130
gregy ::
na hitro receno .. manjka ti slovensko.php v languages direktoriju .. sumnike bos pa nastimal v slovensko.php .. tam imas vrstico charset
// charset for web pages and emails
define('CHARSET', 'windows-1250');
haha ::
Imam slovensko.php, tudi v adminu imam slovensko.php, ampak admin mi ne dela mi vn vrže tisto kar sem prej napisal.
Kako pa svoj template dam noter?
haha ::
charset imam naštiman
pa mi šumniki še vedno ne delajo
frenk ::
tole je moj problem, ki ga vn vrže če se hočeš registrirati
tle vidm da je problem v email-u, ampak kej več pa ne
edit:typo
Warning: mail() [function.mail]: SMTP server response: 530 5.7.0 Must issue a STARTTLS command first 66sm4608149wra in D:\Program Files\Apache Group\Apache2\htdocs\osc\catalog\includes\classes\email.php on line 502
Warning: Cannot modify header information - headers already sent by (output started at D:\Program Files\Apache Group\Apache2\htdocs\osc\catalog\includes\classes\email.php:502) in D:\Program Files\Apache Group\Apache2\htdocs\osc\catalog\includes\functions\general.php on line 29
edit:typo
- spremenil: frenk ()
Tody ::
Očitno server uporablja TLS povezavo in moreš najprej to zagnat (oz jo more skripta) drugi erorr sporoča da je ena funkcij tole že izvedla.
frenk ::
aha torej je najboljša varianta uporabit server ki ne uporablja tls...še najraje bi uporabil lokalen server
mogoče kdo pozna kakšen opensource ali pa freeware lokalen server?
Tic ::
A ima kdo to dobr porihtan, da bi ga uprašal za par nasvetov, najraje preko MSNja...
(poinštalirano imam, vse dela, govorim o konfiguracijah in zunanji podobi)
persona civitas ;>
- spremenil: Tic ()
gregy ::
poglej si naso stacuno, ki jo nasi programerji dnevno prerihtavajo v detajle ..
dela u nulo .. msn info@vstopnice.com
| » | OSCommerce nastavitve (strani: 1 2 3 4 … 10 11 12 13 )Oddelek: Izdelava spletišč | 57678 (24829) | Skarabej |
| » | eCommerce online trgovinaOddelek: Izdelava spletišč | 2392 (1895) | JanezekNovak |
| » | zen-cart: slovenski prevod / monetaOddelek: Izdelava spletišč | 4409 (3859) | mrezna |
| » | Ne kaže mi pravilno flash bannerjaOddelek: Izdelava spletišč | 1614 (1578) | #000000 |
| ⊘ | OSCommerceOddelek: Izdelava spletišč | 2669 (2641) | Tody |
