Sisoftware Sandra & WARNING!!!
Rokomah ::
V tem preglednem programu indentifikacije mi javlja:
"WARNING!!!Large memory sizes should be made of Registered/Buffered memory"
SiSoftware Sandra Help File
Tip T100 - Large memory systems (1GB or greater) should use Registered/Buffered memory, especially if more than 2 are installed on the same channel. This improves signal quality by reducing the load on the chipset channel. While these modules add an extra clock delay due to the on-board buffers (thus CL2 effectively becomes CL3), the stability will be worth it. Server chipsets with many memory slots generally require Registered memory.
Fix: If you plan on adding more memory, consider replacing the modules with Registered/Buffered modules. Do note that you cannot mix Unbuffered and Registered/Buffered modules on the same channel, but you may be able to if the chipset has multiple memory channels.
Pojma nimam kaj to pomeni in kako odpraviti ta artifect.
Kdo mi lahko pomaga?
Hvala
pviran3 ::
Ti vse piše
To pomeni samo to, da če boš dajal v svoje računalo več rama(1gb+), je bolje, da je ram registered/buffered. To pomeni da bi ti delalo hitreje itd...
Rokomah ::
Se opravičujem zaradi lastne nevednosti:\ vendar, kako naredim, da je ram registered/buffered ???
Moonman ::
Registered ram moraš kupiti.
Rabiš samo, če delaš kakšen server, ... Registred moduli imajo višje zakasnitve, zato so nekaj počasnejši od navadnih.
ECC RAM v "navadni" plati
334376 (3177) MrStein
Kako preveriš če je ram unbuffered?
51457 (1383) rovtarček
Program, ki pove katero matično ploščo imam?
Oddelek: Programska oprema
144177 (4079) Han
Kateri Windowsi?!
Oddelek: Operacijski sistemi
171675 (1457) Gandalfar
sisoft sandra-kaj pomeni to opozorilo??
61815 (1692) TESKAn
