Forum » Strojna oprema » Kako preveriš če je ram unbuffered?
Agetis ::
Imam 2x512 MB RAM ECC in me zanima, kje in kako preveriš,
če je ram buffered ali unbuffered!?
Kaj je sploh razlika?!
Hvala
ago
Hvala
ago
- premaknilo iz Pomoč in nasveti: bastadu ()
rovtarček ::
kako da potem obstajajo unbuffered ECC rami???
p.s. ne obstajajo pa buffered nonECC rami :D
- spremenilo: rovtarček ()
Agetis ::
Hey wind!
Na strani sem nasel:
One common misconception is that if a stick of memory is capable of ECC it must also be registered (this is certainly a common combination). This is incorrect as you can find unbuffered, ECC modules if you look hard enough.
Hmmm...kako se torej to preveri? :)
agetis
rovtarček ::
A term used to describe a memory module that contains buffers. The buffers re-drive the signals through the memory chips and allow the module to be built with a greater number of memory chips. Buffered and unbuffered RAM cannot be mixed. The design of the computer's memory controller dictates which type of RAM must be used.
| » | ECC RAM v "navadni" platiOddelek: Strojna oprema | 4376 (3177) | MrStein |
| » | Non-ECC ram v ECC matično?Oddelek: Pomoč in nasveti | 1968 (1602) | d4vid |
| » | RAM na računalniku ne delujeOddelek: Strojna oprema | 1909 (1736) | Pina |
| » | Koliko je res pomemben ECC pri 16GB in več rama ?Oddelek: Strojna oprema | 4722 (4107) | Isotropic |
| » | sisoft sandra-kaj pomeni to opozorilo??Oddelek: Pomoč in nasveti | 1815 (1692) | TESKAn |
