sisoft sandra-kaj pomeni to opozorilo??
WiseBear ::
v Sisoft Sandri 2003 mi pod Mainboard information na koncu(performance tips) pokaže tole opozorilo:
Warning 2545
Tip T2545 - Large memory modules (256MB or greater) should be Registered/Buffered, especially if more than 2 are installed on the same channel. This improves signal quality by reducing the load on the chipset channel. While these modules add an extra clock delay due to the on-board buffers (thus CL2 effectively becomes CL3), the stability will be worth it. Server chipsets with many memory slots generally require Registered memory.
Fix: If you plan on adding more memory, consider replacing the modules with Registered/Buffered modules. Do note that you cannot mix Unbuffered and Registered/Buffered modules on the same channel, but you may be able to if the chipset has multiple memory channel
Kaj pomeni to opzorilo oz. kakšna je razlika med registered in buffered ramom?
Pred kratkim sem namreč skušal nadgradit ram pa se je sistem vedno znova sesuval.
WiseBear ::
Te podatke o plošči sem malo bolj natančno pregledal in našel še en zelo čuden podatek-Maximum installable memory: 256mb8-O 8-O . Kaj je narobe? Ta plata(qdi kudoz 7e333) naj bi podpirala mnogo več rama- klik.
SiSoftware Sandra
System Mainboard
Manufacturer : Legend QDI
MP Support : No
Model : KuDoz 7
Version : V1.XX
BIOS ID : 08/30/2002- KT333-8233-6A6LVQ19C-00
System Chipset : VIA KT266/A,KT333 Chipset
Flash Memory Controller
Error Correction Capability : None
Number of Memory Slots : 3
Maximum Installable Memory : 256MB
Bank0/1 - A0 : DIMM 256MB @ 133Mt/s
Bank2/3 - A1 : Empty
Bank4/5 - A2 : Empty
System Chipset
Model : VIA Technologies Inc VT8366/A,VT8367 Apollo KT266/A,KT333 CPU to PCI Bridge
Bus(es) : ISA AGP PCI USB SMBus/i2c
Front Side Bus Speed : 2x 133MHz (266MHz data rate)
Max FSB Speed / Max Memory Speed : 2x 166MHz / 2x 166MHz
In Order Queue Depth : 4 req(s)
Memory Module(s)
Memory Module 1 : Kingston KVR266X64C25256 0417C307 256MB 8x(32Mx8) DDR-SDRAM PC2100U-2533-750 (CL2.5 upto 133MHz) (CL2 upto 100MHz)
Mi lahko eden razloži kaj bi lahko bilo narobe ?
Hvala, LP
ReSpEcT ::
:O težko bom malo pobrskal! se slišimo
R33D3M33R ::
Si pomislil da se morda sandra moti glede tvoje plate? Včasih je prav grozno kaj vse ti programi zamešajo in napačno razberejo.
WiseBear ::
Mogoče se res moti, mislim pa da je nekaj na tem, ker mi nikakor noče delat s 512 ram-a. Pri prodajalcu sem zamenjal že 2 modula pa ne dela in ne dela. Čudno je tudi to, da mi nov ram(hynix) ki sem ga kupil dela, pod pogojem da ni v dim režah nobenega drugega. Ko pa k temu dodam še kingstona pa se začnejo blue sreeni:| -
Dusko ::
Ja to je itak normalno da se rama dveh različnih proizvajalcev tepeta med sabo.Oziroma neke komplicirata.Po mojem je rešitev ram istega proizvajalca.
Po mojem mnenju ta maximum installable memory pomeni to, da lahko v eno režo spraviš ploščico z največ 256 MB RAMa. To bi razložilo tvoj problem z 512 MB ploščicami, če sem te prav razumel.
DDR-SDRAM
101945 (1855) Čmrlj
Procesor AMD 2500+ Barton
142119 (1934) jest10
Program, ki pove katero matično ploščo imam?
Oddelek: Programska oprema
144191 (4093) Han
BIOS upgrade
102058 (1888) Dead_Eye
kako zvedeti katera verzija NF7-S in kateri radeon9500 pro
51354 (1291) raptor1
