Forum » Operacijski sistemi » Linux SuSe in nVidia 6600 GT AGP - Težave
JPUros ::
Nameščene imam Linux SuSe 9.1 pro, v kišti pa mi laufa nVidia GeForce 6600 GT na AGP-ju. Sem nekje na 80% poti do uspešne inštalacije grafičnega drivera. Do sem se mi je že parkrat zataknilo, vendar sem vse napake odpravil sam. Tokrat pa je napaka zahtevnejša
, no vsaj meni se zdi
. V začetku inštalacije v Text Modu, mi javi, da s kernelom neki ni v redu.
Log:
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Thu Feb 17 07:34:19 2005
option status:
license pre-accepted : false
update : false
force update : false
expert : false
uninstall : false
driver info : false
no precompiled interface: false
no ncurses color : false
query latest driver ver : false
OpenGL header files : false
no questions : false
silent : false
no backup : false
kernel module only : false
sanity : false
add this kernel : false
no runlevel check : false
no network : false
no ABI note : false
no RPMs : false
force tls : (not specified)
force compat32 tls : (not specified)
X install prefix : /usr/X11R6
OpenGL install prefix : /usr
compat32 install prefix : (not specified)
installer install prefix: /usr
utility install prefix : /usr
kernel name : (not specified)
kernel include path : (not specified)
kernel source path : (not specified)
kernel output path : (not specified)
kernel install path : (not specified)
proc mount point : /proc
ui : (not specified)
tmpdir : /tmp
ftp mirror : ftp://download.nvidia.com
RPM file list : (not specified)
Using: nvidia-installer ncurses user interface
-> License accepted.
-> There appears to already be a driver installed on your system (version: 1.0-
5336). As part of installing this driver (version: 1.0-6629), the existing
driver will be uninstalled. Are you sure you want to continue? ('no' will a
bort installation) (Answer: Yes)
-> No precompiled kernel interface was found to match your kernel; would you li
ke the installer to attempt to download a kernel interface for your kernel f
rom the NVIDIA ftp site (ftp://download.nvidia.com)? (Answer: Yes)
-> No matching precompiled kernel interface was found on the NVIDIA ftp site;
this means that the installer will need to compile a kernel interface for
your kernel.
ERROR: The kernel header file
'/lib/modules/2.6.5-7.145-default/build/include/linux/kernel.h' does not
exist. The most likely reason for this is that the kernel source path
'/lib/modules/2.6.5-7.145-default/build' is incorrect. Please
make sure
you have installed the kernel source files for your kernel; on Red Hat
Linux systems, for example, be sure you have the 'kernel-source' rpm
installed. If you know the correct kernel source files are installed,
you may specify the kernel source path with the '--kernel-source-path'
commandline option.
ERROR: Installation has failed. Please see the file
'/var/log/nvidia-installer.log' for details. You may find suggestions
on fixing installation problems in the README available on the Linux
driver download page at www.nvidia.com.
Tistim, ki se ze dlje časa ukvarjate z Linuxom, boste najverjetneje vedli za kaj gre
, pa tudi meni razložli
. Če potrebujete še kakšne podatke za rešitev težave samo postajte. Hvala
Log:
option status:
update : false
expert : false
uninstall : false
driver info : false
silent : false
no backup : false
sanity : false
no network : false
no ABI note : false
no RPMs : false
tmpdir : /tmp
your kernel.
commandline option.
- premaknil iz Pomoč in nasveti: ToniT ()
urosv ::
Ponavadi javi takšno napako ko nimaš inštaliranih development toolsov. Drugače pa si snemi iz neta Suse 9.2 DVD in presenecen bos koliko boljsi je (btw jaz po 9.2ki uporabljam FC3)...
Tvoja rešitev:
- Najprej zaženi yast in namesti vse popravke vkljucno z novim kernelom.
- potegni si dol nov nvidiin drajver 66.29 in ga namesti v tekstovnem nacinu (v Xu zazeni v konzoli ukaz: init 3)
-vstavi v pogon DVD ali CD medij os suseta in namesti vse development toolse preko yasta, ter seveda KERNEL SOURCE.
- namesti gonilnik in uredi XF86Config.
-to je to :)
Tvoja rešitev:
-to je to :)
Brez güje se še ćevelj več ne vbüje!
ql000 ::
@urosv: jaz pa ravno po FC2 prešaltal na Suse
@JPUros: Lepota Suseja je ravno v tem, da zalaufaš YAST, izbereš online upate, in med vsemi paketki, ki ti jih ponudi izbereš gonilnik NVidie, ki ga po defaultu nisi dobil zraven zaradi nekih pravniških tralalajev. To je to!
| » | Ubuntu 8.04 frekvenca osveževanja in resolucijaOddelek: Operacijski sistemi | 2826 (2459) | c0ck4m0u53 |
| » | Skoraj že obupal pri inštalaciji LinuxaOddelek: Operacijski sistemi | 1774 (1593) | Brane2 |
| » | NVIDIA gonilnik za LinixOddelek: Operacijski sistemi | 1723 (1594) | borchi |
| » | 2 linux vprašanji (strani: 1 2 )Oddelek: Operacijski sistemi | 4957 (4519) | ShowDown |
| » | Suse 9.0 (strani: 1 2 )Oddelek: Operacijski sistemi | 6359 (5645) | moj_nick |
