irc...
irc...
hmmm ::
a kdo ve kak je una komanda da če en napiše tvoj nick de pol teb avtomatičn neki napiše...:\
Ibex ::
To so vse komande:
/ Recalls the previous line entered in the current window.
/! Recalls the last command typed in any window.
/action {action text} Sends the specifed action to the active channel or query window.
/ame {action text} Sends the specifed action to all channels which you are currently on.
/amsg {text} Sends the specifed message to all channels which you are currently on.
/auser {level} {nick|address} Adds a user with the specified access level to the remote users list.
/auto [on|off|nickname|address] Toggles auto-opping of a nick or address or sets it on or off totally.
/away {away message} Sets you away leave a message explaining that you are not currently paying attention to IRC.
/away A plain away sets you being back.
/ban [#channel] {nickname} [type] Bans the specified nick from the curent or given channel.
/beep {number} {delay} Locally beeps 'number' times with 'delay' inbetween the beeps. /channel Pops up the channel central window (only works in a channel).
/clear Clears the entire scrollback buffer of the current window.
/clearall Clears all text in all open windows.
/ctcp {nickname} {ping|finger|version|time|userinfo|clientinfo} Does the given ctcp request on nickname.
/ctcps [on|off] Sets the Tools/Remote/ section (not) to listen to CTCP commands. Or checks its status.
/closemsg {nickname} Closes the query window you have open to the specified nick.
/creq [ask | auto | ignore] Sets your DCC 'On Chat request' settings in DCC/Options.
/dcc send {nickname} {file1} {file2} {file3} ... {fileN} Sends the specified files to nick.
/dcc chat {nickname} Opens a dcc window and sends a dcc chat request to nickname.
/dde [-r] {service} {topic} {item} [data] Allows DDE control between mIRC and other applications.
/ddeserver [[on [service name] | off] To turn on the DDE server mode, eventually with a givem service name.
/describe {#channel} {action text} Sends the specifed action to the specified channel window.
/disable {#groupname} De-activates a group of commands or events.
/disconnect Forces a hard and immediate disconnect from your IRC server. Use it with care.
/dlevel {level} Changes the default user level in the remote section.
/dns {nickname | IP address | IP name} Uses your providers DNS to resolve an IP address.
/echo [nickname|#channel|status] {text} Displays the given text only to YOU on the given place in color N.
/enable {#groupname} Activates a group of commands or events.
/events [on|off] Sets the Tools/Remote/ section (not) to listen to ON .. Events. Or checks its status.
/exit Forces mIRC to closedown and exit.
/finger {nick|address} Does a finger on a users address.
/flood [{numberoflines} {seconds} {pausetime}] Sets a crude flood control method.
/flush [levels] Clears all nicknames from the Remote/users list that are currently not on your channels.
/font Activates the font selection dialog.
/fsend [on|off] Shows fsends status and allows you to turn dcc fast send on or off.
/fserve {nickname} {maxgets} {homedirectory} [welcome text file] Opens a fileserver.
/groups [-e|d] Shows all (enabled or disabled) groups defined in the remote sections.
/guser {level} {nick} [type] Adds the user to the user list with the specified level and address type.
/help {keyword} Brings up the Basic IRC Commands section in the mIRC help file.
/ignore [on|off|nickname|address] Toggles ignoring of a nick or address or sets it on or off totally.
/invite {nickname} {#channel} Invites another user to a channel.
/join {#channel} Makes you join the specified channel.
/kick {#channel} {nickname} Kicks nickname off a given channel.
/list [#string] [-min #] [-max #] Lists all currently available channels, evt. filtering for parameters.
/load {-apuce} {filename.ini} Loads Aliases, Popups or Remote items into mIRC.
/log [on|off] Shows the logging status or sets it on or off for the current window.
/me {action text} Sends the specifed action to the active channel or query window. Also see /describe and /ctcp action.
/mode {#channel|nickname} [[+|-]modechars [parameters]] Sets channel or user modes.
/msg {nickname} {message} Send a private message to this user without opening a query window.
/names {#channel} Shows the nicks of all people on the given channel.
/nick {new nickname} Changes your nickname to whatever you like.
/notice {nick} {message} Send the specified notice message to the nick.
/notify [on|off|nickname] Toggles notifying you of a nick on IRC or sets it on or off totally.
/onotice [#channel] {message} Send the specified notice message to all channel ops.
/omsg [#channel] {message} Send the specified message to all ops on a channel.
/part [#channel] [message] Makes you leave the specified channel.
/partall Makes you leave all channels you are on.
/ping {server address} Pings the given server. NOT a nickname.
/play [-cpqmrlt] [channel/nick] {filename} [delay/linenumber] Allows you to play text files.
/pop {delay} [#channel] {nickname} Performs a randomly delayed +o on a not already opped nick.
/protect [on|off|nickname|address] Toggles protection of a nick or address or sets it on or off totally.
/query {nickname} {message} Open a query window to this user and send them the private message.
/quit [reason] Disconnect you from IRC with the optional byebye message.
/raw [on|off] Sets the Tools/Remote/ section (not) to listen to Raw commands. Or checks its status.
/raw {raw command} Sends any raw command you supply directly to the server. Use with care!
/remote [on|off] Sets the Tools/Remote/ section (not) to listen to CTCP or Raw remote commands and Events. Or checks its status.
/rlevel {access level} Removes all users from the remote users list with the specified access level.
/run {c:\path\program.exe} [parameters] Runs the specified program, evt. with parameters. Also try /run http://www.mirc.com etc.
/ruser {nick[!]|address} [type] Removes the user from the remote users list.
/save [-apuce] {filename.ini} Saves remote sections into a specified INI file.
/say {text} Says whatever you want to the active window.
/server [server address [port] [password]] Reconnects to the previous server or a newly specified one.
/sound [nickname|#channel] {filename.wav} {action text} Sends an action and a fitting sound request.
/speak {text} Uses the external text to speech program Monologue to speak up the text. Better use /gtalk with mIRC's Agent support.
/sreq [ask | auto | ignore] Sets your DCC 'On Send request' settings in DCC/Options.
/time Tells you the time on the server you use.
/timer[N] {repetitions} {interval in seconds} {command} [| {more commands}] Activates a timer.
/timestamp [on | off] Sets timestamping on or off for all your conversations.
/topic {#channel} {newtopic} Changes the topic for the specified channel.
/ulist {level} Lists all users in the remote list with the specified access levels.
/url [on|off|show|hide] [address] Opens the URL window that allows you to surf the www parallel to IRC.
/uwho [nick] Pops up the user central with information about the specified user.
/splay {c:\path\sound.file} Locally plays the specified sound file.
/who {#channel} Shows the nicks of all people on the given channel.
/who {*part.of.address*} Shows all people on IRC with a matching address.
/whois {nickname} Shows information about someone in the status window. Also try /uwho.
/whowas {nickname} Shows information about someone who -just- left IRC.
/write [-cidl] {filename} [text] To write the specified text to a .txt file.
hmmm ::
ammm...no ja se jest sm drgač mislna neki ka u remote napišeš naprimer de mam nick aaaaa pa pol ka en napiše aaaaa de men samo avtomatično napiše naprimer ja? al pa karkoli...[:)] najbrž sm se narobe izrazla...
wiiii
Jakka ::
on *:text:hmmm:#:/msg $chan ja?
Kdorkoli bo na kateremkoli kanalu, kjer si gor, napisal besedo "hmmm", bo skripta avtomatsko na ta kanal napisala "ja?".
Si to želela? :)
hmmm ::
Wi thxxx hvala zlat si! :)
hmmm ::
no ja a mogoče kdo ve tud tak de deopa če kdo napiše tvoj nick....in pa še če en npr. pride na kanal pa da ga avtomatično pozdrav...:\
OmegaBlue ::
Za Deop (navem zakaj bi to delala)
on 1:text:TvojNick:#:/mode $chan -o $nick
pa za pozdrav
on 1:join:#:/msg $chan Pozdravljen $nick
Gluposti skriptiranja :D
ahac ::
hmmm.. drugič napiši še kater klient uporabljaš..
sej je res, da je večina na mircu, ampak vseeno je bolje napisat.. da ti ne bo kdo brezveze razlagal kako to v nastavitvah xchata vklopiš.. :O
OmegaBlue ::
ahac se ti resno zdi da je uporabnica drugega klienta kot mIRC?
ahac ::
Ne. Ravno zato je pa treba opozorit na izbiro. ;)
MilkoSan ::
tisto prvo si mislna ˝highlight˝?
[C#] mysql povezava
Oddelek: Programiranje
132972 (2713) Miko55
Apache - localhost JA, IP naslov NE
Oddelek: Omrežja in internet
187284 (7143) ManDriver
ipv6 for g33k`s (strani: 1 2 )
7715202 (11758) Kami
Trojan W32.IRCBot.F
Oddelek: Operacijski sistemi
61685 (1584) Tear_DR0P
mIRC
252879 (2213) Sims
