Azureus 2.2.0.0 zunaj
Source Forge - Dočakali smo novo večjo različico priljubljenega programa za izmenjavo datotek po torrent protokolu. Sedaj je to različica 2.2.0.0, ki prinaša marsikatero novost -- za naštevanje vseh bi porabil preveč prostora, oglejte si jih tukaj.
Še mesto za dolpoteg: Azureus 2.2.0.0 ( win32, linux x86, linux AMD64, OS X, source)
29 komentarjev
Exilian ::
Changes:
2004.10.31 | Azureus 2.2.0.0
FEATURE: Core | Disk cache [Parg]
FEATURE: Core | Ability to set IP type-of-service (TOS) field for outbound data [Nolar]
FEATURE: Core | Show current upload and download limits in status area [Parg]
FEATURE: Core | Locale selection - options to add in all defined encodings + show lax list [Parg]
FEATURE: Core | Change the incoming data port without restarting [Parg]
FEATURE: Core | Display "warning message" responses in announce replies [Parg]
FEATURE: Core | Added option for tracker to perform a connectability check to peers [Parg]
FEATURE: Core | Have message aggregation, for bandwidth savings/efficiency [Nolar]
FEATURE: Core | Torrent HTTP urls now accepted as program command line parameter [Nolar]
FEATURE: Core | Option added to disable system tray [Parg]
FEATURE: Core | Concurrent hashing for >1 CPU [Parg]
FEATURE: Core | Added ability to not outward connect to a defined set of port numbers [Parg]
FEATURE: Core | SOCKS V4, V4a and V5 (no auth/user+password methods) support for outgoing data connections [Parg]
FEATURE: Core | Torrents created by Azureus now include .utf-8 fields [Parg]
FEATURE: Core | Dynamic piece request queue scaling [Gudy]
FEATURE: Core | Added torrent name to authentication dialog [Parg]
FEATURE: Core | Per-torrent upload speed limits [Nolar,Gudy]
FEATURE: Core | Ability to change the sound played on torrent completion added [Parg]
FEATURE: Core | Added session uptime to stats [Nolar]
FEATURE: UI | 'Download' menu added with start/stop all + pause/resume options [Parg]
FEATURE: UI | Table col sort order default option added, thanks to Charnobo! [Parg]
FEATURE: UI | URL Downloader window now support to set-up referrer and saves last used referrers [Parg, Gudy]
FEATURE: UI | New Statistic page about the disk cache (yeah more CPU consuming graphs) [Gudy]
FEATURE: UI | Down/Up speed indicators in main view are now double-clickable to open the Stats View [Gudy]
FEATURE: UI | Added Path and # Remaining Pieces to Files view, Tracker Name to MyTorrents view [Nolar]
FEATURE: Plug | webui support for torrent encoding choice [Parg]
FEATURE: Plug | Tracker torrent stats available via xml/http interface [Parg]
CHANGE: Core | Show time to re-announce/scrape in general view using hh::mm::ss [Parg]
CHANGE: Core | Timeout tracker server operations [Parg]
CHANGE: Core | Torrent opener will now report errors opening torrents better [Parg]
CHANGE: Core | Complete core networking/messaging rewrite [Nolar]
CHANGE: Core | Stop scrape on UDP V2 torrents when download running [Parg]
CHANGE: Core | Refactor of DiskManager [Parg]
CHANGE: Core | Protocol tweaking for significantly reduced discard rates [Nolar]
CHANGE: Core | Tracker now treats port value of 0 as 'explicitly firewalled' [Parg]
CHANGE: Core | Tracker client will revert to "initialised" state after explicit failure from tracker [Parg]
CHANGE: Core | Locale selection changed to show more possible encodings [Parg]
CHANGE: Core | XML stats - downloads ordered by downloading/index then seeding/index [Parg]
CHANGE: Core | Reworked connection establishment to conform to new WinXP SP2 limits [Nolar]
CHANGE: Core | When restarting torrents are checked in smallest->largest size [Parg]
CHANGE: Core | Reworked the piece picking so that slow peers don't "block" pieces to be completed [Gudy]
CHANGE: Core | JAR signing for webui (etc) now based on "tools.jar" from Sun JDK due to changes with their 1.5 JRE [Parg]
CHANGE: Core | "Pause" command now greyed out if there is nothing to pause [Parg]
CHANGE: Core | Create-torrent wizard now remembers comment data on back button + defaults for open/save dirs [Parg]
CHANGE: Core | Reduced memory used of ipfilter list to help support large list sizes [Parg]
CHANGE: Core | Added "*.*" to list of selectable file types in open-torrent dialogs [Parg]
CHANGE: UI | Added a legend to the Pieces View [Gudy]
CHANGE: UI | Pieces View now display if the blocks are in the cache or not [Gudy]
CHANGE: UI | New Tools menu, Configuration --> Options, Plugins root menu, Language selection moved to config [Nolar,Gudy]
CHANGE: Plug | UPnP plugin now only uses plugin interfaces [Parg]
CHANGE: Plug | Differentiate UDP and TCP mappings in UPnP desc as some routers need this [Parg]
CHANGE: Plug | UpdateLanguagePlugin removed, as no longer maintained [Nolar]
BUGFIX: Core | Throw an error message if existing data file length is too large [Nolar]
BUGFIX: Core | Fix new bug with tracker announce every 10s when no peers were connected [Nolar]
BUGFIX: Core | Fix for renaming files across volumes [Parg]
BUGFIX: Core | Torrent auto-import now works with console UI [Nolar]
BUGFIX: Core | Bug when setting upload to unlimited (forced download to unlimited too) [Parg]
BUGFIX: Core | Set downloaded amount correctly when opening a torrent with existing download data [Parg]
BUGFIX: Core | Detect changed file sizes (smaller) when resuming torrents [Parg]
BUGFIX: Core | Random shuffling of multi-tracker torrent URLs fixed [Parg]
BUGFIX: Core | Fix occasional 60sec delay on initial tracker announce [Nolar]
BUGFIX: Core | Fix for reading piece data from a too-long file [Nolar/Parg]
BUGFIX: Core | Stop scraping all announce URLs in a torrent when removing torrent [Parg]
BUGFIX: Core | File handle closing [Parg/Nolar]
BUGFIX: UI | Labels with '&' displaying incorrectly [Parg]
BUGFIX: UI | Torrent Downloader Window : retry button now placed correctly [Gudy]
BUGFIX: UI | Fix for clicking the plugins directory and open the folder from the Configuration>Plugins view [Gudy]
BUGFIX: UI | Fix for animated message windows not being at the right place on dual monitors. [Gudy,Bluelive]
BUGFIX: Plug | Netgear WGT624 was crashing when processing UPnP requests [Parg]
BUGFIX: Plug | Webui 'view' mode wasn't working [Parg]
BUGFIX: Plug | Webui - excessively long status text messing up table [Parg]
BUGFIX: Plug | azplugins - web tracker pages wasn't picking up "show details" option [Parg]
BUGFIX: Plug | webui - fixed bug with re-ordering of columns [Parg]
It's not the opensource i hate.
It's the fanclub I cannot stand.
darkolord ::
Sicer je lep samo požre waaaaaaaay to much rama da bi bil uporaben
QuickShot ::
Hehe malo pozna novica, meni se je updejtal danes zjutraj :D
hruske ::
Neutemeljeno trdiš, da je pozna. Danes je namreč praznik, pa je bila novica še vedno objavljena.
MKrmec ::
FREE RAM IS WASTED RAM!!
A se nisi slisu tega!!
moj_nick ::
Wasted je, če bi ga lahko za kaj drugega bolje uporabil.
DjTonic ::
Ja res požere veliko RAM-a ter sredstev, vendar mi je še vseeno to najljubši torrent klient.
bono ::
no katerga odjemalca priporočate ?
a bittornado omogoča nadaljevanje prenosa, ko prekineš povezavo ?
Atos ::
meni za tak dober torrent klient ni škoda malce več rama :D
sgdjkdlsugi4 ::
BitComet pozere okoli 30mb rama, ne pa 100% CPU, kot se mi je to dogajalo z azureusom ...
Jaka83 ::
Azureus je pač baziran na Java in to pač požre mal več proca. Če pa imaš dober procesor, tega sploh ne opaziš. Jaz recimo brez problema igram zahtevne igre in še poganjam Azureus-a v ozadju, pa dela vse BP. 8-)
MKrmec ::
maddog
ubistvu BitComet pozre vec procesorja kot Azureus. Pri Azureusu je znan problem ce nimas najnovejse JAVE da ti CPU na 100% skoč. Pa da ne govorimi o problemih k jih ma BitComet pr uploudanju. JAO
bono
Odjemalec??? Misls client. Nehi mi s temi bednimi slovenskimi izrazi za take stvari. Misls ko gledas u Azureusu kok seedov ma en torrent ti u slovenscini pise "semena" jao to je bil smeh do konca da ne govorimo o Leecherjih "soležniki" :( cist mem ker kreten je to prevaju.
In ja u bittorrentu lahko nadaljujes prenos ce ga prekines ali da se prekine kakorkoli ze.
moj_nick
glej ce mas ti 1 GB rama potem se ti jebe za tiste 30-50 k ga azureus rab. 512 MB je isto. Ce misls da ce mas 300 MB od 512 MB frej dobr ni res ubistvu mors pustit nekak to da se samo uravnava. Brezveze ti bo pol 300 MB gonil se k bi lahko kje drugje bil uporabljen. Ce pa mas prevelko porabo pol je pa tut kriz ane. Sam Azureus mi krize.
darkolord ::
Pri mojih 512MB rama se to ZELO pozna, še posebej ko mam odprtih ene par IDE pa še kak photoshop zraven... v bistvu
WASTED RAM IS NOT FREE RAM
moj_nick ::
Nisi me prav razumel...
Če delaš z aplikacijo, ki ti npr. požre ves tvoj 1G RAM (kakšno 3d modeliranje, video editiranje, itd.), ti ne bo vseeno za tistih 30MB al kolk že, ki ti jih odžira azureus.
Drugače pa tvojo filozofijo uresničuje Linux, kjer imaš RAM vseskozi 99% zaseden in se tistega, ki bi drugače bil prost, uporabi za cache.
sgdjkdlsugi4 ::
MKrmec : Pred instalacijo azureusa sem downloadal in namestil najnovejso javo, ki je bila pac takrat na voljo ... imam pa samo 1ghz Thunderbirda ...
mnja, tega da bitcomet porabi se vec cpu moci, nekak v Task Managerju ne vidim ... me pa zanima kaksne probleme ima pri uploadanju ?
no sicer pa, vsakemu svoje, vsak naj poskusi, kateri programi mu na racunalniku bolje tecejo...
Kaboom ::
:'( sem glih danes skočil v vode torrent clientov ker me ABC malo zeza - namreč naključni torrent freezne in mi CPU skoči na 100% - v azareusu se mi je to zgodlo ko sem pogledal statistiko in potem vsakič ko sem ga zagnal - imam pa najnovejšo javo ... sicer pa piše nekaj o tem da je 1.4.2 najboljše delalo do sedaj (verzija nekje v tem stilu)
zato moram vseeno še malo dalje iskat pravega clienta zase
Če se zatakne - pritisni močneje. Če se zlomi - bil je skrajni čas za nakup novega.
Jux ::
jst osebno vsakemu priporočam bittornado, meni je hud, ker je majhen, stabilen in preprost za uporabo. In nima ogromega grafičnega vmesnika, ki bi samo še bolj obremenjeval računalnik. A kdo od vas resno potrebuje vse funkcije, ki jih ima azareus in podobni?
web&blog&etc: http://lukabirsa.com
jest10 ::
Še vedno visim na starem dobrem shadow's experimental. Rabim program za download in na še ene "risanke", ki bi mi odžirala sredstva.
sgdjkdlsugi4 ::
Kaboom : poskusi BitComet in porocaj...
Wox ::
Ja, sej. Uporabljajte pač tistega, ki vam paše. Tole je novica o Azureusu.
Men je fajn, da so končno vključil ročno nastavitev maksimalnega UL in DL za posamezni torrent. Na druge uporabne novosti zaenkrat še nisem naletel.
Commodore 64
CCfly ::
btdownloadcurses.py
"My goodness, we forgot generics!" -- Danny Kalev
ABC porab 2-8% procesorskega casa, redkokdaj skoc cez 10%. :)
Zheegec ::
@Kaboom; Sem imel isti problem z Bittornado. Ne vem zakaj se je dogajalo, sedaj imam fresh format in ABC, pa vse deluje dobro (knock, knock).
Janez Janša, 29.04.2014
frenk ::
glede potratnosti zadnjega azureusa in zadnje jave...
zgleda bo treba navit server>:D
Dami ::
Jaz pri azureusu pogrešam enostavno nastavitev kak dolg naj določen torrent seeda (tak ko pri abcju). 90% tistih nastavitev tam so tak komplicirano napisane da sploh ne vem zakaj so.
OldSkul ::
Do zdaj sem uporabljal ABC toda od včeraj BitComet in mi od vse bittorrent programov najmanj obremeni računalnik.Zdaj vsaj lahko normalno delam na njem če downloadam več stvari naenkrat.
jlpktnst ::
Očitno je neka specifična nora zadeva na tem (grozni obremenitvi), ker meni azureus deluje lepo. Je pa res, da sem zadnjič doživel nekaj podobnega pod linuxom-> mozilla je "požrla" skoraj ves ram in swap (skupaj preko 500 mb), vendar ne vem ali je bila java vpletena:)
frenk ::
evo zdej je šlo še več rama in računalnik res šteka tko kot se zagre:D...pomoje bo kmal dol letu
zile ::
A hočeš rečt da snemaš 1 torrent pa ti tolk rama požre. po moje tud ja...8-) Nehaj snemat 10 torrentov naenkrat, pa bo kul.
[P2P] BitTorrent - Naslednja generacija P2P (strani: 1 2 3 4 … 36 37 38 39 )
Oddelek: Omrežja in internet
1904540602 (1873) karafeka
Suse 10.0 - Kaj z njim? (strani: 1 2 )
Oddelek: Operacijski sistemi
537639 (5862) kriko1
295332 (5332) zile
Bit Torrent (kateri client je najboljši)?
Oddelek: Programska oprema
95185 (5039) Dr_M
bittorent client?
71637 (1532) Tr0n
