Forum » Programiranje » [Visual studio .NET] Rabim pomoč
ml007 ::
Imam en problem in to da bi v Excelu Zapisal podatke vsakič ko jih shranim mi jih shrani v isto vrsto
Rad bi pa da jih shrani v naslednjo vrsto kjer so bili prejšnič shranjeni podatki.
Se vam že v naprej zahvaljujem
Lp Matevž [Visual studio .NET] Rabim pomoč
ml007 ::
Dim Excel As Object
Dim Book As Object
Dim Sheet As Object
'Start a nev workbook in Excel
Excel = CreateObject("Excel.Application")
Book = Excel.Workbooks.Add
'Add data to cells of the first worksheet in the new workbook
Sheet = Book.Worksheets(1)
Sheet.Range("C1").Value = "Datum"
Sheet.Range("D1").Value = "Destinacija"
Sheet.Range("B1:D1:E1:F1:G1:I1:J1:K1:L1:N1:O1:P1:Q1").Font.Bold = True
Sheet.Range("C2").Value = DateTimePicker1.Text
Sheet.Range("D2").Value = Destinacija.Text
' Save the sheet to c:Book1
Book.SaveAs("C:\Book1.xls")
Excel.Quit()
'Exit application
Application.Exit()
End Sub
End Class
To je ta koda katero uporabljam
Lp Matevž
Dim Book As Object
Dim Sheet As Object
Excel.Quit()
'Exit application
Application.Exit()
End Sub
End Class
Lp Matevž
darkolord ::
ja to je pa zato ker imaš v kodi točno določeno celico kamor naj te podatke zapiše
to lahko rešiš recimo tako, da najprej poiščeš prazno celico v stolpcu... približno nekaj v tem stilu:
Dim i As Integer
For i = 1 To Sheet.Rows.Count
If Len(Sheet.Range("C" & i).Value) = 0 Then
Exit For
End If
Next i
Sheet.Range("C" & i).Value = "Datum"
Sheet.Range("D" & i).Value = "Destinacija"
'tale replace ti pač te "1" nadomesti s številko vrstice
Sheet.Range(Replace("B1:D1:E1:F1:G1:I1:J1:K1:L1:N1:O1:P1:Q1","1",i)).Font.Bold = True
Sheet.Range("C" & i).Value = DateTimePicker1.Text
Sheet.Range("D" & i).Value = Destinacija.Text
Dim i As Integer
Exit For
End If
Next i
- spremenilo: darkolord ()
darkolord ::
Ja sej morš sam tisti vmesni del zamenjat
... tale:
ml007 ::
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
Dim Excel As Object
Dim Book As Object
Dim Sheet As Object
Dim i As Integer
Exit For
End If
Next i
Sheet.Range(Replace("B1:D1:E1:F1:G1:I1:J1:K1:L1:N1:O1:P1:Q1", "1", i)).Font.Bold = True
Sheet.Range("C" & i).Value = TextBox1.Text
Sheet.Range("D" & i).Value = TextBox2.Text
Excel.Quit()
'Exit application
Application.Exit()
End Sub
End Class
Tko sem naredil kot si rekel pa mi ne dela tako da bi vskič v novo vrstico napisal
Pa še sedaj mi noče napisati Datum in Destinacija
Tko da bi prosil če kdo ve kao bi se dalo naresti da bi vsakič
Ko bi vpisoval podatke da bi ji shranilo v nslednjo vrstico ki je prazna n+in ne v vrstico ki jr definerana
Tko da bi naslednjič ko bi shranil da bi jo zapisalv v C3 in D3 in ne v C2 inD2
Lepo bi prosil da mi pomagate se vam v naprej zahvaljujem
Lp Matevž
Dim Excel As Object
Dim Book As Object
Dim Sheet As Object
Dim i As Integer
Exit For
End If
Next i
Excel.Quit()
'Exit application
Application.Exit()
End Sub
End Class
Lp Matevž
darkolord ::
Aja sori en kos kode sm pozabu... tkole pa dela:
Dim Excel As Object
Dim Book As Object
Dim Sheet As Object
If Dir("C:\Book1.xls") = "" Then
Else
Book = Excel.Workbooks.Open("C:\Book1.xls")
End If
Dim i As Integer
Exit For
End If
Next i
Else
Book.Save
End If
Excel.Quit()
'Exit application
Application.Exit()
End Sub
Dim Excel As Object
Dim Book As Object
Dim Sheet As Object
Else
End If
Dim i As Integer
Exit For
End If
Next i
Else
Book.Save
End If
Excel.Quit()
'Exit application
Application.Exit()
End Sub
| » | Excel: tiskanje po vrsticahOddelek: Pomoč in nasveti | 1657 (1570) | luksorzi |
| » | [Excel]Kako izvleči vrednost?Oddelek: Programiranje | 4359 (4082) | Mobidick |
| » | [Excel]Vrednost celice = ime dokumentaOddelek: Programska oprema | 5259 (4681) | veteran |
| » | Prosim za pomoč pri VBAOddelek: Programiranje | 2518 (2321) | apachee |
| » | Visual Basic in ExcelOddelek: Programiranje | 3229 (2795) | Vesoljc |
