Forum » Pomoč in nasveti » Ne morem zbrisat datotek
BattleMaster ::
Na disku mam ene 4 datoteke(midi melodije), ki jih ne morm zbrisat. Napiše mi da ne najde datoteke
Sm probal v dosu pa mi ni hotel, ja kar napisal da datoteka ne obstaja. Windowse mam pa xp. Upam da bo odgovor do treh, ker pol grem na morje
- spremenil: BattleMaster ()
apachee ::
Poskusi zagnat windowse v "safe mode with command prompt", mislim da je neki tazga in tam zbriši omenjene datoteke!
Upam da ti rata
In če greš ob treh na morje probi čimprej oz če maš še kako vprašanje ga posti! Nikoli ne veš mogoče ti bom znal pomagat
Upam da ti rata
You can't win without The Finn!
matrix2 ::
čeprav ne grem na morje danes, bi vseeno kar tukaj poleg postavil eno sorodno si vprašanje
In sicer, imam dva programa in eden film na D:\ particiji za pobrisati, ta particija ni systemska, vendar mi kljub temu ne pusti delete. Poskušal sem že vse mogoče, vendar? Kaj je lahko problem, ti fili mi zasedejo več kot 2gb prostora, to pa ni zanemarljivo?
Spajky ::
Battle_Master, ustvari z Notepadom fajle na desktopu z enakim imenom kot tisti neizbrisljivi in jim daj končnico .mid, nato jih kopiraj tja, kjer so tisti neizbrisljivi fajli in pol zbriši...
matrix2 evo:
"Well windows seem to have a REALLY big problem when it comes to reading
AVI files. It seems that when you click on an AVI file in explorer,
it'll try to read the entire AVI file to determine the width,height,
etc. of the AVI file (this is displayed in the Properties window). Now
the problem with Windows is that if you have a broken/not fully
downloaded AVI file that doesnt contain this info, Windows will scan the
entire AVI file trying to figure out all these properties which in the
process will probably cause 100% CPU usage and heavy memory usage.
To solve this problem all you have to do is the following:
1. Open up regedit
2. Goto HKEY_CLASSES_ROOT\SystemFileAssociations\.avi\shellex
\PropertyHandler
3. Delete the "Default" value which should be "{87D62D94-71B3-4b9a-9489-
5FE6850DC73E}"
matrix2 evo:
1. Open up regedit
\PropertyHandler
5FE6850DC73E}"
BattleMaster ::
Prišel z morja
Sem probal tisto z istim imenom, pa mi je kar še eno ustvaril, ki pa je imela POPOLNOMA isto ime
.Potem dal v beležnici shrani kot: in zbral tam kot vse datoteke, tko da sm shranu kot midi datoteko.Uspešno mi jo je prepisal, sam ko sm jo poskušal zbrisat, je pa isto napisal
Highlag ::
Ta trik sem uporabil tudi jaz. (Kopiranje datoteke z istim imenom)
Datoteka ni film ampak program za nalaganje nove slike bios-a. Ne vem kateri program se je zapičil v to datoeko. Ne zasede prostora samo kazi mi namizje
scenic ::
Zdaj ne morem zbrisat nobene????
Ne prvotne in tiste, ki sem jo ustvaril.
Prvotna je bla en star ARJ.
Scenic
Scenic
| » | Ne da se zbrisat filmaOddelek: Pomoč in nasveti | 1825 (1612) | andper |
| » | Problem z brisanjem pokvarjene AVI datoteke!!!Oddelek: Pomoč in nasveti | 3719 (3455) | smolep |
| » | Datoteke ne gre izbrisatOddelek: Pomoč in nasveti | 1375 (1266) | Zdravko |
| » | Ne gre mi zbrisat avi file!Oddelek: Pomoč in nasveti | 1467 (1357) | david |
| » | Premikanje avi datotek v explorerjuOddelek: Pomoč in nasveti | 1542 (1291) | Jose |
