Forum » Izdelava spletišč » Ocena kode in napotki za izboljsanje
Rumko ::
na linku je koda od strani k jo nekaj poskusam narediti ... rabu bi pa ksno oceno pa ksne napotke v stilu ... ta pa ta del zgleda bedn, preber si to pa to knjigo kjer je razlozen kako to deluje da bos pol popravu na boljs in podobno
Ziga Dolhar ::
We're sorry, but this page is currently unavailable for viewing.
If this site belongs to you, please read this help page for more information and assistance.
Nekisizajebu.
Nekisizajebu.
https://dolhar.si/
frke ::
Za sam preizkus te kode manjkaja še ustrezna sql datoteka, ki naredi v mysql kar je potrebno.
Brez tega browser napiše samo "Could not select database". Ob napaki, bi bilo dobro napisati tudi v kateri vrstici kode se je zgodila, saj je iskanje drugače preveč mučno.
lp,frke
lp,frke
Rumko ::
uf ... sql datoteka ... ker jst kr dostkrat kej spremenim izgled tabel nimam narjene
drgac pa vse tabele k so trenutno so:
mysql> describe komentarji;
| Field | Type | Null | Key | Default | Extra |
| id | int(11) | | PRI | NULL | auto_increment |
| kdaj | datetime | | | 0000-00-00 00:00:00 | |
| vsebina | longtext | | | | |
| username | text | | | | |
| novica | int(11) | | | 0 | |
| ocena | int(1) | YES | | NULL | |
6 rows in set (0.05 sec)
mysql> describe login;
| id | smallint(5) unsigned | | PRI | 0 | |
| koda | varchar(255) | YES | | NULL | |
| ip | varchar(32) | YES | | NULL | |
| refer | varchar(254) | YES | | NULL | |
| agent | text | YES | | NULL | |
| time | datetime | YES | | NULL | |
| logined | tinyint(1) | YES | | NULL | |
| username | varchar(20) | YES | | NULL | |
8 rows in set (0.01 sec)
mysql> describe novice;
| id | int(11) | | | 0 | |
| naslov | text | | | | |
| vsebina | longtext | YES | | NULL | |
5 rows in set (0.00 sec)
mysql> describe users;
| id | int(11) | | PRI | 0 | |
| username | varchar(20) | | | | |
| pass | longtext | YES | | NULL | |
| registered | datetime | | | 0000-00-00 00:00:00 | |
| level | mediumint(9) | | | 0 | |
| cookie | longtext | | | | |
| style | longtext | YES | | NULL | |
| novice_limit | smallint(6) | YES | | NULL | |
| kom_limit | smallint(6) | YES | | NULL | |
9 rows in set (0.00 sec)
| » | Potrebujem MySQL ukazOddelek: Programiranje | 3790 (3398) | zvmk |
| » | Pomoč pri izdelavi Python skripte (strani: 1 2 )Oddelek: Programiranje | 7355 (6001) | BigWhale |
| » | MySQL RelacijeOddelek: Izdelava spletišč | 1512 (1278) | mkos2 |
| » | Brisanje posamezne vrstice v tabeli MYSQL bazeOddelek: Izdelava spletišč | 1476 (1388) | Tody |
| » | Malce zahtevnejši SQL stavek včasih narobe SELECT-aOddelek: Izdelava spletišč | 2585 (2254) | Brilko |
