Forum » Programiranje » Potrebujem MySQL ukaz
zvmk ::
Živjo,
Imam tabelo
Potrebujem MySQL ukaz, ki bi prebral iz tabele "poraba" trenutni (zadnji zapis) in zapis iz prejšnega mesca jih odštel ter vpisal v tabelo "usage_per_month"
Se pravi npr.:
voda_mrzla (mar) - voda_mrzla (feb) = difference_cold
voda_topla (mar) - voda_topla (feb) = difference_hot
primer trenutnega vpisa je
Mogoče bi bilo lažje s tako tabelo, da lahko naredim select from previous id_poraba
V Naprej hvala.
Imam tabelo
mysql> DESCRIBE poraba; +------------+------------+------+-----+-------------------+-----------------------------+ | Field | Type | Null | Key | Default | Extra | +------------+------------+------+-----+-------------------+-----------------------------+ | mesec | timestamp | NO | | CURRENT_TIMESTAMP | on update CURRENT_TIMESTAMP | | voda_mrzla | varchar(5) | NO | | NULL | | | voda_topla | varchar(5) | NO | | NULL | | +------------+------------+------+-----+-------------------+-----------------------------+
Se pravi npr.:
mysql> DESCRIBE usage_per_month; +-----------------+-------------+------+-----+---------+-------+ | Field | Type | Null | Key | Default | Extra | +-----------------+-------------+------+-----+---------+-------+ | difference_cold | varchar(10) | NO | | NULL | | | difference_hot | varchar(10) | NO | | NULL | | +-----------------+-------------+------+-----+---------+-------+
mysql> SELECT * FROM poraba; +---------------------+------------+------------+ | mesec | voda_mrzla | voda_topla | +---------------------+------------+------------+ | 2014-03-03 16:19:08 | 5985 | 3417 | | 2014-04-03 19:48:35 | 5986 | 3418 | +---------------------+------------+------------+
mysql> SELECT * FROM poraba; +---------------------+------------+------------+-----------+ | mesec | voda_mrzla | voda_topla | id_poraba | +---------------------+------------+------------+-----------+ | 2014-03-03 16:19:08 | 5985 | 3417 | 1 | | 2014-04-03 20:57:51 | 5978 | 3412 | 2 | +---------------------+------------+------------+-----------+
V Naprej hvala.
- spremenilo: zvmk ()
phong ::
SELECT voda_mrzla FROM poraba ORDER BY timestamp DESC LIMIT 2;
(z zgornjim ukazom prikažeš le zadnji 2 vrstici).
Lahko pa tudi nekaj takega (če želiš določen časovni range):
SELECT voda_mrzla FROM poraba WHERE timestamp > '2014-03-20 00:00:00' AND timestamp < '2014-04-01 00:00:00';
pridobljene vrstice obdeluj po mili volji. Rezultat shraniš z SQL stavkom (seveda s svojimi vrednostmi:
INSERT INTO usage_per_month VALUES(2014-04-01 00:00:00', 300, 250, 1);
carota ::
Kaj če bi začel s tabelami in jih konsistentno poimenoval, npr. vse v angleški ali vse v slovenski jezik ("poraba", "usage_per_month" ...), ime pojla "mesec" in tip "timestamp" ne gresta skupaj (mesec je interval, timestamp pa točna sekunda), vsaka tabela naj bi imela primary key, in nenazadnje, zakaj imaš porabo tipa VARCHAR in ne INT?
Če nimaš temeljev postavljenih, ne se lotit gradit hiše.
Mesar ::
V praksi lahko primerja datetime in timestamp http://stackoverflow.com/questions/1048...
Your turn to burn!
zvmk ::
@catora. ja tabele so res malce zmešane ang/slo ampak to bom na koncu tako ali tako spremenil vse v isti jezik kar pa je čisto vseeno lahko bi polja poimenoval xxsdfkjaflkdssdf pa bi delovalo enako. Polje mesec je tam, ker bo zapis narejen samo 1x na mesec. Vse kar pa sem v tvojem odgovoru videl je kritiziranje mojega vprašanja na mesto, da bi mi dejansko pomagal z nekim konkretnim odgovorm!
@Mesar Hvala za info ampak datuma/ure niti ne bom uporabljal, dodal sem ga samo za referenco oz. za pomoč pri izračunu (trenutni mesec - prejšni mesec). Ampak to mislm, da bi bilo tako ali tako najžje narediti kar z id_poraba.
Najbližje, ki mislim, da bi lahko naredil je z primerom tukaj
http://stackoverflow.com/questions/1503...
Samo so tabele drugače postavljene pa se mi zadeva zatika.
BigWhale ::
Kritika je bila povsem na mestu. Zaradi tega, ker imas stolpca, s stanji stevcev, tipa VARCHAR namesto INT, se tega, po cemur ti sprasujes sploh ne da narediti. Oziroma celotno stvar samo zakomplicira. Poleg tega imas ime enega stolpca `timestamp`, kar vse skupaj se malo bolj zakomplicira, ker je TIMESTAMP tudi funkcija v MySQLu.
SELECTa razlike dveh vrstic v nekem stolpcu ni tako zelo enostavno narediti, zato je precej pomembno, da so podatki prej pravilno strukturirani.
Tvoj SELECT bi v grobem zgledal nekako takole:
SELECT p1.voda_mrzla - p2.voda_mrzla AS poraba_mrzla, p1.voda_topla - p2.voda_topla AS poraba_topla FROM poraba p1
LEFT JOIN poraba p2 ON p2.`timestamp` = (
SELECT MAX(`timestamp`) FROM poraba p3 WHERE p3.`timestamp` < p1.`timestamp`
) ORDER BY p1.`timestamp` DESC LIMIT 1
Tale select naredi razliko med zadnjima dvema vrsticama. Z malo telovadbe v WHERE pogoju lahko stvar popravis tako, da bos izbral vrstico iz prejsnjega meseca.
carota ::
Verjamem, da sem ti dal konstruktivno kritiko, da najprej uredi osnove in konkretno sem ti napisal katere in zakaj. Če se ne potrudiš niti toliko, da bi to sam rešil, potem zaman pričakuješ, da bom trošil svoj čas in ti pomagal.
Glede na to, da sem si vzel čas za napisat post pomeni, da sem pripravljen pomagat.
carota ::
V praksi lahko primerja datetime in timestamp http://stackoverflow.com/questions/1048...![]()
Vem, da se ju lahko primerja, ampak pomensko "mesec" ne ustreza tipu "timestamp".
zvmk ::
@BW hvala za odgovor. Spremenil sem z VARCHAR v INT, glede timestamp pa ne vidim kje misliš, da ga imam poimenovanega v stolpcu. V tabeli poraba je samo type timestamp za mesec.
Z uporabo SELECT voda_mrzla, voda_topla FROM poraba ORDER BY id_poraba DESC LIMIT 2;
http://sqlfiddle.com/#!2/33206/3
dobim dva stolpca
pri tvoji kodi pa mi prikaže error na p2.timestamp
http://sqlfiddle.com/#!2/33206/2
Zadeve sem se lotil drugače. Sicer pravijo, da je tukaj nevarnost, če zbrišem kak id_poraba, ampak tega namena nimam. Aja uporabil sem sdeleče
http://sqlfiddle.com/#!2/9ae51/1
dobim dva stolpca
BigWhale ::
Ah, sem spregledal.
Vidis, zaradi taksnih napak je dobro, da se naucis nekaj osnov. Sedaj ti niti priblizno ni jasno kaj tale koda pocne oziroma zakaj pride do napake. V moji kodi zamenjaj `timestamp` z imenom stolpca v katerem imas timestamp.
zvmk ::
@BW hvala,se probal s spremembo timestamp z mesec in deluje enako kot sprememba s id_poraba. No malce sem se pa že naučil
@crota, da me ne boš razumel narobe. Hvala za pripombe oz. kritike na moje delo. Zmotilo me je samo (kar se mi dogaja večkrat, predvsem na slovenskih forumih), komentarji kot so
Nič narobe samo namesto takih komentarjev bi raje videl npr: jaz bi tabelo postavil tako, da bi ven vzel timestamp, dodaj novo tabelo, vrstico itd.
Da sem videl, da si mi pradlagal postaviti ID v vsako tabelo in spremembo iz VARCHAR v INT in tako sem tudi naredil
tnx!
No pa da se vrnem na problem, trenutno sem se ustavil tukaj
Eden izmed poizkusov, ki sem jih naredil je opisan tukaj. Brez uspeha seveda! http://stackoverflow.com/questions/1490...
rezultat poraba_mrzla1 bi rad vpisal v difference_cold in poraba_topla1 v difference_hot
Kakšna idea?
Če nimaš temeljev postavljenih, ne se lotit gradit hiše.![]()
SELECT p1.voda_mrzla - p2.voda_mrzla AS poraba_mrzla1, p1.voda_topla - p2.voda_topla AS poraba_topla1 FROM poraba p1
LEFT JOIN poraba p2 ON p2.`id_poraba` = (
SELECT MAX(`id_poraba`) FROM poraba p3 WHERE p3.`id_poraba` < p1.`id_poraba`
) ORDER BY p1.id_poraba DESC LIMIT 1
INSERT INTO usage_per_month (difference_cold, difference_hot)
SELECT voda_mrzla1,voda_topla1 FROM porabaEden izmed poizkusov, ki sem jih naredil je opisan tukaj. Brez uspeha seveda! http://stackoverflow.com/questions/1490...
Kakšna idea?
keworkian ::
Obscenities in B-Flat
| » | [SQL] Pohitritev izpisaOddelek: Programiranje | 4022 (2921) | kuall |
| » | oracle 12 identity (the old way)Oddelek: Programiranje | 1422 (1227) | detroit |
| » | Pomoč pri izdelavi Python skripte (strani: 1 2 )Oddelek: Programiranje | 7428 (6074) | BigWhale |
| » | MySQL procentiOddelek: Programiranje | 1488 (1154) | Malik12 |
| » | [SQL] - združitev glede na iste vrednostiOddelek: Programiranje | 1876 (1518) | tx-z |
