Forum » Operacijski sistemi » Problem z instalacijo fontconfig v Linux-u
Torej, nalozil sem fontconfig iz binary. ./configure je bil ok, make pa javi napako:
../src/.libs/libfontconfig.so: undefined reference to `MAX'
../src/.libs/libfontconfig.so: undefined reference to `ABS'
../src/.libs/libfontconfig.so: undefined reference to `MIN'
collect2: ld returned 1 exit status
make[2]: *** [fc-cache] Error 1
make[1]: *** [all-recursive] Error 1
make: *** [all] Error 2
Nato sem ga odstranil z make uninstall in si posnel rpm. A ta mi rece:
opozorilo: fontconfig-2.1-9.fdr.0.rh80.i386.rpm: V3 DSA signature: NOKEY, key ID ff6382fa
file /etc/fonts/fonts.conf from install of fontconfig-2.1-9.fdr.0.rh80 conflicts with file from package fontconfig-2.1-9
file /usr/bin/fc-cache from install of fontconfig-2.1-9.fdr.0.rh80 conflicts with file from package fontconfig-2.1-9
file /usr/bin/fc-list from install of fontconfig-2.1-9.fdr.0.rh80 conflicts with file from package fontconfig-2.1-9
file /usr/lib/libfontconfig.so.1.0 from install of fontconfig-2.1-9.fdr.0.rh80 conflicts with file from package fontconfig-2.1-9
file /usr/share/man/man3/fontconfig.3.gz from install of fontconfig-2.1-9.fdr.0.rh80 conflicts with file from package fontconfig-2.1-9
btw, to rabim zato, da dela pango, ki ga rabim da dela gtk, ki ga rabim za gtkam.
os: pingo 2.0r2 (v bistvu redhat)
za prvi error sem malo iskal po netu, a dobim same forume in na nobenem ni odgovora. sem prebral install in naredil configure s parametri, ki so notri, a vseeno ni efekta.
BigWhale ::
Isto verzijo fontconfiga ze imas na masini, kaj bi v resnici rad naredil?
In zakaj hudica se spravljas prevajat programe, ce imas RPMje?
Fontconfig se mi ne instalira do konca. Javi tisti error. In ker mu ne uspe, se Pango noce instalirat. V koncni fazi pa vse to rabim za digitalca (Canon a60).
binary sem pa uporabil, ker je bilo prvo kar sem nasel. A ni vseeno kaj se uporabi?
#rpm -qa | grep fontconfig
fontconfig-2.1-9
#rpm -i glib2-2.4.0-1.1.fc1.nr.i386.rpm
file /usr/lib/libglib-2.0.so.0 from install of glib2-2.4.0-1.1.fc1.nr conflicts with file from package glib2-2.2.1-1
file /usr/lib/libgmodule-2.0.so.0 from install of glib2-2.4.0-1.1.fc1.nr conflicts with file from package glib2-2.2.1-1
file /usr/lib/libgobject-2.0.so.0 from install of glib2-2.4.0-1.1.fc1.nr conflicts with file from package glib2-2.2.1-1
file /usr/lib/libgthread-2.0.so.0 from install of glib2-2.4.0-1.1.fc1.nr conflicts with file from package glib2-2.2.1-1
#rpm -i pago-1.4.0-1.1.fc1.nr.i386.rpm
napaka: Failed dependencies:
glib2 >= 2.4.0 is needed by pango-1.4.0-1.1.fc1.nr
#rpm -qa | grep glib
glibc-kernheaders-2.4-8.10
glib-1.2.10-10
glibc-devel-2.3.2-27.9.7
glibc-2.3.2-27.9.7
glib2-2.2.1-1
glibc-common-2.3.2-27.9.7
# rpm -qa | grep pango
pango-1.2.1-3
zdej, kako naj jaz stare verzije pobrisem, ker rabim novejse, ki pa se zaradi starih nocejo pobrati dol.
fontconfig-2.1-9
glib-1.2.10-10
glibc-2.3.2-27.9.7
glib2-2.2.1-1
pango-1.2.1-3
In kaj se bo zgodilo s programi, ki so od njih odvisni? A bodo pogruntal, da je zdej nova verzija?
In ali se lahko odstrani normalno z rpg, ce se ni z njim instaliralo?
Ker malo me moti, ker sem naredil make uninstall za par teh knjiznic, pa so izgleda se kar prisotne.
Problemi. Glib imam 6 verzij instaliranih, vsako potrebuje drugacen set programov, tako da se ne pustijo odinstalirati. Edina, ki disi na verzijo 2.4.x je glibc-kernheaders-2.4-8.10. Ko hocem instalirat glib 2.4.8 javi, da ima konflikt z file iz glib2-2.2.1-1, ki pa ga ne morem instalirat. A jo rabim, ker jo zahteva pango. Please help.
| » | Izšel GIMP 2.8 (strani: 1 2 )Oddelek: Novice / Pisarniški paketi | 21867 (17582) | LuiIII |
| » | Google Earth odslej tudi za Linux (strani: 1 2 )Oddelek: Novice / Ostala programska oprema | 9834 (8012) | der_Alte |
| » | [Suse 9.2] Prosim za pomoč pri inštalaciji GAIMOddelek: Operacijski sistemi | 1582 (1481) | Jst |
| » | Linux internet povezava problemOddelek: Operacijski sistemi | 2523 (2138) | dr.J |
| » | Zakaj v Linuxih tak vse počas gre?Oddelek: Pomoč in nasveti | 1165 (1008) | simon |
