restarta comp.
restarta comp.
AnTiTeRoR ::
mene neki zanima.kaj bi lahko bilo narobe da mi restarta comp brez opozorila.
Največkrat mi restarta kadar igram računalnik.....:|
enkrat mi istisalo tole
a problem has been deteched and windows has been shut down to prevent damege to your computer.
if this is the first time you have seen this stop eror screen restart your computer.
if this screen appears again,follow these steps.run a system diagnostic utility supplied by your hardwere manufacture.in particular,run a memory check,and components,restart your computer,press F8 to select advanced startup options,and then select safe mode.
imam windows XP pro.
Beernarrd ::
smo mel ravno pred kakšnim tednom debate na ot temo. (glej arhiv)
Pri men je bil hardver. še vedno je. ko se bom mel čas ukvarjat s tem, bomo vidl kaj točno je narobe.
AnTiTeRoR ::
aja damn;(( ajd
fictionel ::
jz imam tut take probleme. in kako ugotoviti katera komponenta zaje6ava??? ram sm pregledov, prime95 laufa dokler se winsi ne sesujejo...
wot tu du?
najveckrat videni error pa je STOP: 0x0000008E
Kako ugotoviti kaj mi serje? Bluescreeni...
193363 (2754) Cold1
win 7 bsod - okvara matične ?
122403 (2232) vander
Problem z diskom : 0x0000007B error
82857 (1906) crayz43
Težave pri namestitvi XP
81155 (1086) brdavs
Instalacija windowsow - problem
Oddelek: Operacijski sistemi
121996 (1600) misek
