Forum » Pomoč in nasveti » LSA Shell lsass.exe ?!
jaBo ::
Win XP, dial-up modem motorola sm56
Ko grem online, mi po nekaj minutah pojavi POP-UP System shutdown:
»System is going to shutdown. Please save all work in progress an log off. Any work changes will be lost. Shutdown was iniciated by NT Authority/system.
Time untill shutdown: 45sec«
Ko mi naredi restart in se ponovno logiram mi javi sledeče:
LSA (Local Security Authority) Shell (Export version) encountered a problem and needed to close....
lsass.exe
Poskusu sm tud z drugega account-a ni nč drgač ...
Če sm offline je vse OKey.....
lsass.exe
- preklical razglas: Gandalfar ()
delfinus ::
Ker je zadeva nova je vsekakor vredna svoje teme. Doletela je tudi mene danes. Resitev je opisana spodaj!
Your computer is infected with a new Sasser worm exploiting the LSASS Buffer
Overrun Vulnerability.
To clean your system:
NOTE: If your system keeps restarting, you can abort the system shut down
by:
Click Start, click Run and type "shutdown -a" (without quotations),
then click OK.
1. Download and install the critical update IMMEDIATELY from
http://www.microsoft.com/technet/securi...
2. Press Ctrl + Alt + Delete to bring up the Task Manager and terminate the
"avserve.exe" process, then delete the avserve.exe from C:\Windows and
restart your computer.
Pri meni je bil Avserve2.exe lociran v windows direktoriju. Prav tako se zadeva nahaja v registru HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
lp, D.
by:
then click OK.
lp, D.
- spremenil: delfinus ()
| » | Skype problemOddelek: Programska oprema | 1867 (1272) | tv6865 |
| » | Windows XP - lsass.exeOddelek: Operacijski sistemi | 3238 (2054) | Rauf |
| » | Ms blast ali zakaj se mi sistem ugaša po eni minuti? (strani: 1 2 3 4 5 6 )Oddelek: Pomoč in nasveti | 44353 (19335) | brainiac20 |
| » | Kako v Win2k premakniti mapo Documents and Settings?Oddelek: Operacijski sistemi | 2545 (2511) | Mercier |
| » | Logitech MouseWare bug (?)Oddelek: Pomoč in nasveti | 2614 (2210) | Swiwer |
