Slo-Tech preseljen
Elemen_T ::
Občutno hitreje.
Super.
blabla ::
se kar pozna na hitrosti
weeeee
Thanatos ::
warp drive is online :D
ja mislim da se mi celo malce hitreje nalaga
luni ::
Mater siba :)
Artificial Intelligentia
darh ::
u iber hitr... :)
Pinging slo-tech.com [212.93.228.73] with 32 bytes of data:
Reply from 212.93.228.73: bytes=32 time=89ms TTL=247
Reply from 212.93.228.73: bytes=32 time=35ms TTL=247
Reply from 212.93.228.73: bytes=32 time=39ms TTL=247
Reply from 212.93.228.73: bytes=32 time=14ms TTL=247
Ping statistics for 212.93.228.73:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 14ms, Maximum = 89ms, Average = 44ms
Tracing route to slo-tech.com [212.93.228.73]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms morpheus [10.0.0.1]
2 9 ms 32 ms 72 ms 193.77.28.1
3 317 ms 129 ms 19 ms 212.30.64.53
4 75 ms 29 ms 109 ms didi.siol.net [193.189.161.203]
5 294 ms 26 ms 31 ms 193.2.141.41
6 57 ms 99 ms 104 ms weaver.softnet.si [212.103.129.1]
7 38 ms 31 ms 35 ms 212.103.129.58
8 22 ms 43 ms 67 ms moj.net-gw.netsi.net [212.72.97.66]
9 26 ms 31 ms 72 ms lovelace.moj.net [212.93.225.69]
10 93 ms 103 ms 104 ms slo-tech.com [212.93.228.73]
Trace complete.
Excuses are useless! Results are priceless!
|GrEgOr| ::
Men na 64/64 je pa isto... hehe :D
luni ::
Malo nestabilna je se cela zadeva, ampak bo boljse :)
msmiha ::
Saj je kar cool in pa dosti hitro za moj 56k modem:D
Sumo ::
Rula!
Dj-Prah ::
Stari trga.Nemres Belevied.8-)
Intel Celeron 1000Mhz@1400Mhz-Vulcano 9,Hercules 3D Prophet 8500LE 128MB DDR TV/DVI,512MB SDRAM,Asus CUSL2-C Black Pearl
Polde ::
8-O 8-O 8-O
Ni da ni!!!
Filo ::
ja res ne mores opisat z besedam:D
...samo 2 miliona nas živi,
na naši mali zemljici...
ja tud to bo kmal ...:D
me zanima če bo kašna nagrada padla...unmu k bo imel številko 2.000.000 dejte no vsaj za eno pive...hi hi
bbesic ::
Ok saj je že bil čas da se je nekaj zgodilo ker se je vse ful počasi odpiralo .Ok je zaj vse samo nekaj skinov bi še lahko blo!:D
R0K ::
na ADSLju se ne pozna kaj pride, ker je blo že prej vredu :>
Tomi ::
Tudi na 10Mbit ni razlike..
Bom pa videl, kako je doma.
metrodusa.blogspot.com
Luka Percic ::
Na oko 200% pohitritev! Na, jaz sem pa že obupal nad mojim modemom..
Paramedic ::
Še kr dober :D
End transmission.
Bakunin ::
tomi: bomo videli zvecer ko se "kablasi" vsujejo in zafilajo TM
Sergio ::
dela dobr. cestitke primozu, ker je res dobro ustimal.
se vedno pa gredo velike zahvale sledečim:
Essedi - plošča, oba procesorja, 1 GB pomnilnika. kapa vam dol.
Red Rat Store - 19" ohišje, kabli ter 400W Antec napajalnik. tudi vam kapa dol.
Mlacom - nosilci za diske. face :)
Brad3k: uradni Slo-Tech prevoznik, ki je na lastne stroške z mano šel prevzet novi strežnik v daljno Gorico. Aplavz tudi njemu.
Seveda si stoječo ovacijo zasluži tudi Moj.Net, saj so nam oni dobrodušno podarili pipico v širni svet. Najlepša vam hvala!
Nič, pa nam je ratalo, ane? :D
Tako grem jaz, tako gre vsak, kdor čuti cilj v daljavi:
če usoda ustavi mu korak,
on se ji zoperstavi.
DavidJ ::
muchos hitreje
"Do, or do not. There is no 'try'. "
- Yoda ('The Empire Strikes Back')
ChiefThunder ::
bravo, bravo... :D
... po liniji najmanjšega odpora. ;)
Klemenn ::
no zdej se vsaj primožu ne bo treba vozit...ko bo strežnik pokvarjen...aja kje pa stoji strežnik trenutno?
CaqKa ::
meni se tui ne pozna neke bistvene hitrosti :)
512/128... pa že prej na 256/64 ni blo nič kaj slabše :)
aja kje pa je te iskanje zdaj :)
enajstega al kaj?
whatson ::
Uh, res lepo.
s Softneta:
64 bytes from 212.93.228.73: icmp_seq=0 ttl=249 time=14.002 ms
64 bytes from 212.93.228.73: icmp_seq=1 ttl=249 time=14.203 ms
64 bytes from 212.93.228.73: icmp_seq=2 ttl=249 time=14.111 ms
64 bytes from 212.93.228.73: icmp_seq=3 ttl=249 time=27.996 ms
64 bytes from 212.93.228.73: icmp_seq=4 ttl=249 time=14.260 ms
--- www.slo-tech.com ping statistics ---
5 packets transmitted, 5 packets received, 0% packet loss
round-trip min/avg/max = 14.002/16.914/27.996 ms
s siola:
64 bytes from slo-tech.com (212.93.228.73): icmp_seq=4 ttl=249 time=23.4 ms
64 bytes from slo-tech.com (212.93.228.73): icmp_seq=5 ttl=249 time=25.6 ms
64 bytes from slo-tech.com (212.93.228.73): icmp_seq=6 ttl=249 time=24.2 ms
6 packets transmitted, 6 received, 0% loss, time 5044ms
rtt min/avg/max/mdev = 23.422/74.012/320.030/110.029 ms
Čas včlanitve v Slo-Tech - 6. nov 2000 ob 20:39
BigFoot ::
zelo lepo :D povprečen ping je 37ms
LG 77CX OLED TV; Marantz SR6010 7.2: 5x Focal Sib, 2x Focal Cub, 2x Focal
Little Bird; PS5, Xbox Series X, PS4 Pro, Xbox One, PS3, Vero 4K, Samsung
UBD K8500 4K UHD, Philips BDP2180/12
ChiefThunder ::
aja; a lahko pričakujemo kakšne novosti, spremembe, zdaj ko zadeva laufa bp?
Jeebs ::
Going in warp mode. :) U iber hudo dela! Go on like that boyz!
Press any key to continue... RESET. Didn't you say ANY key?!?!?!
Bakunin ::
traceroute ter ping NISTA verodostojna pokazatelja hitrosti streznika.
lahko da kaksen "router" vmes omejuje ICMP ali pa je traceroute enostavno zaprt.
Doloceni ISP v Sloveniji delajo to.
mmg: http je tcp port 80. Test that.
ps: hvala za izpiske ping/traceroute. Couldn't do it on my own. :)
tha_man ::
Letim, letim! :D
(c) 1982 Sinclair Research Ltd
AngelOfDeath ::
Warp online :D :D :D :D
Reycis ::
Jebe se men za to, ker je ping 10ms manjsi. Stran se se vedno preveckrat ne odpre in tudi sicer ni opazit kaksne pohitritve. Glede na obisk, ki ga ima slo-tech je bil stari server in pipica vec kot dovolj. Ampak recimo, da zdej mate pa za prihodnost zasiguran, ko boste prisli na 50000 obiskovalcev na dan. Kar pa se samo od sebe ne bo zgodilo v kratkem glede na to, da obisk raste zelo pocasi
blabla ::
Tole odpiranje je res malo čudno. V 50% se mi stran ne odpre im moram klikati reload, kar pa sux, ker modra črta izgine :|
Dodatek: V operi se v 50% ne odpre stran (ustavi se pri 28KB). IE dela normalno. hmm
Bane_ ::
Ta stran se zdej velik hitrej nalaga kot se je prej problem na tej strani so sam banerji ker se pocas nalagajo! To pa zato ker so te brskljalniki tolk glupi da vse ostalo ustavoj k se recimo en ta noce naloziT!
Pa da ga izradim sa čekičem za intel pa se to ne pomaga!
Bakunin ::
- lahko testiras tako da v brkljalniku nastavis da ti ne nalaga slikic
- lahko si instaliras kaksen "blokator reklam"
- kupis "gold" clanarino na s/t in se ti bannerji ne bodo vec prikazovali. Pa se majcko dobis. >:D
v Mozilli lahko lepo dolocis na katerih straneh naj ti nalozi slike, na katerih pa ne. Edit|Preferences|Privacy|Images
Primoz ::
2K SIT / leto.. pa grejo bannerji nekam.
There can be no real freedom without the freedom to fail.
Bane_ ::
2k sit pa se ni tko velik to bi pa jest se dal! A pa to lahko ustimate?
Primoz ::
Seveda... a misiš, da jaz gledam reklame?
