Forum » Pomoč in nasveti » Pioneer DVD RPC1 !
Pioneer DVD RPC1 !
whatson ::
MI lahko prosim kdo natancno razlozi kako instalirat RPC1 (1.27) region free crack za Pioneerja 115. Crack sem si downloadal, ampak poleg ni nobenih navodil.
Hvala!
Hvala!
matevzm ::
Zraven bi morala biti navodila. Ce jih ni, pojdi na stran Progress Ramsoft Network homepage.
whatson ::
Navodila sem prebral naredi tocno tako kot pise, a vendar mi, ko vstavim disketo napise, da ne more bootat iz diskete...
Problem se verjetno nahaja v config.sys datoteki, ya katero ne vem, ce sem jo dobro uredil (slabo zapisana navodila)...
Tudi to mi je cudno, da je ob kopiranju RPC1 datotek "povozil" autoexec.bat, ki sem ga moral ze prej posneti na disketo...
kaksen predlog?
lp, whatson
kaksen predlog?
lp, whatson
matevzm ::
Emmm. sistemska disketa mogoce?
Narediti moras bootable (zagonsko ali kako ze) disketo. V principu lahko tudi bootas Win9x in s F5 (hm, ali je F8?) preprecis nalaganje in pades v prompt. Gres tja, kjer imas te datoteke in pozenes autoexec.bat.
hanuman ::
ja tko je to. Ti samo naredi bootable disketo in nanjo skopiraj naslednje file
1.upg5a.exe
2.115f_127.hex
3.autoexec.bat
potem pejt v bios in preveri ce ti sistem boota z diskete, in ce ti restrtaj masino z vlozeno disketo in to je to. Nakar ti bo program sam vse naredil edino kar moras je da potrdis da si res zelis upgradeat firmware.
kle mas pa se edini txt ki je zraven prilozen:
*********** P L E A S E R E A D C A R E F U L L Y ! ! ! ***************
* PIONEER ATAPI DVD-115 TRAY RPC1 FIRMWARE UPGRADE 1.27F *
Do not turn OFF or RESET the PC while upgrade is executed or the firmware
upgrade will fail and your drive WILL BE IRREVERSIBLE DEAD !!!.
Continue this procedure only if your DVD drive is connected on SECONDARY MASTER
We suggest to disconnect any other CD or CDR devices connected on secondary IDE
port! DO NOT CONTINUE THIS PROCEDURE IF YOUR PC IS INSTABLE (TUNED UP),OR HANGS
UP. DO NOT ATTEMPT TO EXECUTE THIS UPGRADE WHEN WINDOWS SYSTEM IS RUNNING!!!
--- Differences between F/W 1.22 and F/W 1.27F RPC1 ---
1. Enable playing of any region encoded DVD discs
2. The drive name will be replaced with DVD-115F
3. Resolved audio cd playing problems (sometimes going in pause mode)
PLEASE REMEMBER THE FOLLOWING:
Any decreasing counter reported by Windows or Player software is not true
counter. This reported counter is handled by Windows or Player software, and is
NOT built-in counter of DVD-ROM drive!. This firmware upgrade eliminate ONLY
the built-in region protection of DVD-ROM!!!
1.upg5a.exe
2.115f_127.hex
3.autoexec.bat
AlchemY ::
zadeva se cist lepo razbije tudi ce startas brez boot diskete ampak uporabis f8 in dos zagon, vsaj pri men je bilo tako. Ko bos zadevo naredil, instaliraj se dvd genie!
whatson ::
Problem je uspesno resen - fajle sem skopiral v eno mapo na disku, pognal autoexec.bat pa 2x pritisnil enter.
Hvala vsem, ki ste mi pomagali!!
ircnet: whatson (#ms, #sobota)
matevzm ::
Pri zadevak kot je flashanje DVDja se jaz niti ne bi igral. Ce gre kaj narobe, lahko drive samo se vrzes stran.
Navodila so narejena tako, da dela. Vcasih dela tudi drugace, a ni zanesljivo.
Sicer, ce si bypassal config in autoexec, mora rudi iz diska delati v redu.
| » | seatoolsOddelek: Pomoč in nasveti | 2389 (2234) | StratOS |
| » | Napačen bios :(Oddelek: Pomoč in nasveti | 1855 (1536) | Azrael |
| » | windows xp sovraži dosOddelek: Pomoč in nasveti | 3646 (3282) | SasoS |
| » | Šla plata ob updatu biosa?Oddelek: Pomoč in nasveti | 1854 (1507) | ru7 |
| » | Pioneer DVD in regijska zaščitaOddelek: Strojna oprema | 2545 (2089) | luni |
