Prime 95 in error
Prime 95 in error
ganzi ::
Athlona 2400+ sem navil na 220x10 na 1.8V. ---> 2.2GHz
2x 256 DDR400 v sinhronem načinu na 2,8V. (11/3/3/2,5)
Abit Nf7-s 2.0 (bios je tist zmodan verzija 10)
Vulcano 7+ (low)
PSU 300W NoName
Prime 95 mi je na Torture Test (Blend- tests some of everything, lots of ram) delu ene 3 ure pol pa javu error.Tkole je zgledal:
Wed Feb 05 16:55:32 2003]
Self-test 1024K passed!
[Wed Feb 05 17:10:42 2003]
Self-test 8K passed!
[Wed Feb 05 17:26:07 2003]
Self-test 10K passed!
[Wed Feb 05 17:42:07 2003]
Self-test 896K passed!
[Wed Feb 05 17:57:44 2003]
Self-test 768K passed!
[Wed Feb 05 18:16:43 2003]
Self-test 12K passed!
[Wed Feb 05 18:32:12 2003]
Self-test 14K passed!
[Wed Feb 05 18:48:50 2003]
Self-test 640K passed!
[Wed Feb 05 19:07:57 2003]
Self-test 512K passed!
[Wed Feb 05 19:23:25 2003]
Self-test 16K passed!
[Wed Feb 05 19:38:50 2003]
Self-test 20K passed!
FATAL ERROR: Rounding was 0.4999732971, expected less than 0.4
Hardware failure detected, consult stress.txt file.
Kaj bi lah blo narobe?
Zdi se mi pa da računalnik dela čist normalno, a pol nej sploh upoštevm te teste?
(npr. 3d Mark 01 pa PC Mark 02 pa F@H delajo brez problema.. Pa igre tut..)
Mam pa ful slab napajalnik..
12+ mi niha med 11,09V pa tm do 11,6V.. ( to je slabo a ne?)
A je možno da zarad napajalca nardi napako?
Eru ::
Hmm, probi še z memtestom, čeprov kolikor imam jaz izkušenj, če prime ne dela comp ni stabilen...:\
OZZY ::
ja uporabi mem test.
Sicer pa je tvoje nihanje 12V napetosti preveliko in prav lahko je to posledica. Ja kako pa kaj druge napetosti nihajo. bi blo dobr vedt.
Go with the flow.
ganzi ::
Sej sm ga kr nazaj na 200x11dal pa na 1,775V ker ta napajalnik je čist na koncu.. +12V mam tm okol 10,9V do 11, 4V
Vedno slabši je.
Ostale napetosti pa tut kr neki nihajo tko, da bo treba prvo en dobr napajalnik dobit.
Pol ga bom pa še bol navil.
Freelancer ::
S stromom se pri compu ni kaj prevec za hecat. Raje znizaj frekvenco in pocakaj do takrat, ko bos kupil boljsi napajalnik. Ce nisi prevec zahteven se danes dobi 400W napajalnik ze za ~7k.
Kar pa se tice prime... Zgleda da stvat pac ni stabilna. 100% stabilna masina mora dat skoz 24 ur torture testa brez kakrsnih koli napak ;).
krucymucy ::
glede 400W za 7K ... sem ga kupil in nanj navesil, proc 2200+ palomino, dva diska 120+30GB, dve CD enote in FX5900 ... ne dela, docim na chiefteku 360W deluje res pa je da je cena chiefteka 12K, 400 watnika pa 7k
Lith ::
sem pa videl Mercury 400W za ene 5,500 SIT se mi zdi Techtrade, ki imajo 3.3V linijo ene 25A
¤ black holes rule; I like the speed, speed kills ¤
Freelancer ::
Jaz sem pa glih zadnjic videl v eni masini Macron napajalnik, ki ima 3.3V linijo 22A, pa nastavljiv ventilator glede na temperaturo... precej tiha zadeva za dobrih 6k.
ganzi ::
Kaj pa gre lah narobe če je na +12V prenizka voltaža?
krucymucy ::
sej na mojmu tud pise +3,3V 28A; +5V 40A; +12V 17A ... sam kaj je tega res ... ker chieftek 360W ima vse enake, razen +5V je 35A pa dela vse tako kot more ... spet se potrjuje tisto k radi pravimo "malo denarja, malo muzike!"
boštjan ::
ganzi,pride do nestabilnosti,še posebej je +12V linija obremenjena pri nForce2 platah
Freelancer ::
Ena lepa slikca:
ganzi ::
Kva vse se pa napaja z 12+?
Upam da nism kako neumnost vprašu zdele>:D
Bo treba nov napajalc nabavt!
boštjan ::
ja plata,pri nForcu2
Procesor se napaja med drugim tudi z +12 linije
krucymucy ::
ja tole so +5V linije ki so zazgane na sliki ... se je meni pripetilo to isto :(
ganzi ::
procesor pa vrjetn tut ram pa grafa če se ne motim a ne?
Ja sej vrjetn je napajalnik tut problem pri mojmu navijanju..
Tko da razmišlam o tem :
HPC-360-302-DF - Chieftec 360W
+5 V / 35 A +3,3 V / 28 A +12 V / 17 A -5 V / 0,3 A -12 V / 0,8 A +5 Vsb / 2,0 A
Stane pa 9k. (več keša se mi ne daje..)
Edit: Pol pa upam da bo stabiln na 220x10 al pa celo na 220x11..:\
  • spremenil: ganzi ()
boštjan ::
tudi graf se napaja iz +12V linije,najbolj se pozna pri novih grafah,ki rabijo dodatno napajanje prek 4pin molexa
krucymucy ::
ne, nic ni slo ... le da sem moral odrezati napajalni kabel, ker nisem mogel niti sneti konektorja ven, s plate sem pa odlotal stran pine in jih nadomestil z novimi, dela ze dve leti, sam ne pr men . razlika je le v tem da moras mal pazit kako obrnes kabel ker ni vec une plastike ...
ganzi ::
ne sej nism mislu da ti je to šlo..:D
Pravm da js mislm da se tole napaja z 12+.
A pa to se zgodi k voltaže nihajo?
Vrjetno če grejo čez mejo ne pa če so prenizke?
K če se to lahk zgodi ob nizkih voltažah bom prec izklopu kompjutr dokler ne dobim novga napjalca.:D
krucymucy ::
to se je men zgodilo zato, ker gigabyte spara na pinih za priklop, stik je bil slab upornost zato vecja in posledicno padec napetosti ter povecanje toka ... bolj se greje vecja je upornost dokler se ne vname ... in kista je se kar delala ... :D
BSOD na win 7
111953 (1847) iloveboobz
Težave - s cpujem ?
71611 (1559) painfulwhite
Posodobitev računalnika
312265 (1696) igiwarcraft
Racunalnik vrze blue screen - overclock???
Oddelek: Navijanje
342045 (1750) Pyr0Beast
3500+ overclocking & neznan restart
231789 (1495) KrCbelca
