3500+ overclocking & neznan restart
KrCbelca ::
Hi.
Čez noč sm z prime95 testiral komp. Zutri k sm pržgav ekran sm ugtovu d se je komp restartiru zarad neznanega razloga.
Preveru sm results.txt v prime95 pa piše:
[Fri Sep 30 19:27:13 2005]
Self-test 8K passed!
[Fri Sep 30 22:05:41 2005]
[Fri Sep 30 22:22:01 2005]
Self-test 10K passed!
[Fri Sep 30 22:37:10 2005]
Self-test 12K passed!
[Fri Sep 30 22:53:19 2005]
Self-test 14K passed!
[Fri Sep 30 23:11:15 2005]
Self-test 16K passed!
[Fri Sep 30 23:27:23 2005]
Self-test 20K passed!
[Fri Sep 30 23:45:22 2005]
Self-test 24K passed!
[Sat Oct 01 00:00:44 2005]
Self-test 28K passed!
[Sat Oct 01 00:17:43 2005]
Self-test 32K passed!
[Sat Oct 01 00:35:39 2005]
[Sat Oct 01 00:54:43 2005]
[Sat Oct 01 01:12:49 2005]
[Sat Oct 01 01:30:49 2005]
[Sat Oct 01 01:45:59 2005]
[Sat Oct 01 02:04:22 2005]
[Sat Oct 01 02:22:31 2005]
[Sat Oct 01 02:40:07 2005]
[Sat Oct 01 02:57:50 2005]
[Sat Oct 01 03:15:49 2005]
[Sat Oct 01 03:32:50 2005]
[Sat Oct 01 03:50:38 2005]
[Sat Oct 01 04:08:12 2005]
[Sat Oct 01 04:24:48 2005]
[Sat Oct 01 04:43:20 2005]
[Sat Oct 01 05:01:10 2005]
In tukaj se fajl konča, brez razloga restarta. Ker je Prime95 laufal 9 ur in pol z SmalFFT je CPU vrjetn stabiln ane?
CPU voltaža: 1.650V
RAM voltaža: 2.800V
druge napetosti sm pustu kot so, ...
Zakaj se mi komp restartira, kaj nej probam, kje nej ugotovim več podatkov zakaj se je resetiru, ....
Anyone?
C2Q Q6600, P5W DH Deluxe,6GB 800MHz Rama
GF 8600gt, 2xSataII WD 250GB, LC Power 550W Green Power
----watter in my vains----
fahrenGONE ::
Tezko je vedet za kaj se gre. Lahko je RAM error ali pa se mu je od vrocine sfuzlalo.( to je moja stokovna razlaga )
Poizkusi s SpeedFan, ce ima loge...
KrCbelca ::
od temperature dvomm. K je imu po ene 4 urah max 45°C
bolj sumim ram. Kak bi ugotovu če je res ram? K ko sm mu še 2.6 V na ramih mi je preden je pršlo v vindowse restartiralo, brez d bi kr kol navijal. Zdj pa k je 2.8 pa use normaln dela, razn to k se restartira kr enkt ponoč pa tko, ...
Al lohk dam ram na 2.9V, d se nau slučajn skuru, ...
PS: Al lohk moderator prestav temo v navijanje? k sm pomotoma dau sm.
  • spremenil: KrCbelca ()
fahrenGONE ::
Daj ga skozi memtest86 za ene par ur. Ce je mozno 8 ali vec. Ta program je res zakon. Morda dobis se kaj podobnega na ultimatebootcd.com.
igor0203 ::
Ker napajalnik pa maš? Mogoče napajalnik ni več zdržu.
Drgač pa kokr ti je fahrenheit reku, stestiraj rame z memtestom, čeprav naj bi ti ta test ki si ti ga ti pognal mučil proc in ne ram... :|
  • spremenil: igor0203 ()
KrCbelca ::
Ja, laufu sm za cpu, k sm ga navil, pa zgleda d je cpu stabiln, ... Za napajalnik d neb zdržou pa dost dvomm, ... k so linije dost stabilne, pa so mal več kokr pa naj bi bile (3.3 je 3.31) tko d dvomm d je napajalnik) mam pa LC550W Silent Giant k ma 14cm vent.
če zalaufam memtest, ga lohk u matični uklopm k mam možnost tm? Pa pol č najde error, al se restartira pa nam vedu kaki error jav al sam ugasne test pa izpiše napšako, d zutrej pl pogledam kwa je blo?
fahrenGONE ::
Mas isti napajalnik kot jaz. :D
Memtest ti izpise napake in potem lahko zjutraj pogledas, bp. Starta pa se z boot diskete ali CDja.
KrCbelca ::
mam lanparty nF4 tko da lohka v biosu nastavm d zažene memtest
če dam rame na 2.9, se boj obrez hlajenja kej pregreval? kolk je kej nevarna temperatura za twinmos rame?
fahrenGONE ::
Ne vem kako je s temperaturo ampak v ekstremnih primerih se vse skupaj prej sesuje kot da ti ram odpove. Ti v BIOS nastavi vse potrebno in potem samo bootas na floppy ali cd/dvd in memtest86 bo zacel delat sam od sebe.
KrCbelca ::
Ok, še en Q:
Stock je bil proc 11 x 200, ram divider je biu 1:1, tko d je imu ram frekvenco 200MHz
Zdj jest dam 10 x 265, ram divider pa ČE dam tko d je frekvenca rama 200MHz, al pol ram isto dela kokr pr stock nastavitvah al slabš?
igor0203 ::
isto ti dela. a si ti furu rame 1:1? Pa na kok si naviu proc? Ker če si mel 10 x 265 pol ni čudn da se ti je komp restartu. Ker če maš gor bh-5 čipe in 2-2-2-5 latence rabš 3.6-3.7V da bi jih na tok gonu.
Če bi mel gor kšn heatspreader ti ne bi nč škodl, vent čez se pa da tam pri. 3.1+V
fahrenGONE ::
Jep, 1:1 je sicer ok nastavitev ampak ne zdrzijo rami. Tukaj je ena uporabna stran za izracun: http://math.gogar.com/athlon64.cgi
JIM22 ::
Če si res ram furo 1:1 pol še dober da si v win pršo. Te twinmos SP so novi BH5 čipi ki rabjo velikV da delajo dober. Ti jim kar daj 3,4V pa en vent preko in testiraj z memtestom86. Na tej plati ko jo imaš ti vklopi v biosu memtest in ti bo sam začel delat, ko boš restarto. Potem ga moraš spet izklopit če hočeš v win. Tam ti bo vrgl errorje ven če bodo. Če bo prehudo se bo restarto in lahko veš da si še daleč od stabilnosti.
Digitalni marketing, nastop na spletu v naročnikovem imenu.
Vsi na FB pridružite se itVision :)
  • spremenil: JIM22 ()
KrCbelca ::
Hehe, nism na 1:1 furu ramov :D
sam tko me zanima, d vem an :D
mam pa twinmose SP pc3500+ k sm jih pr mlacomu kupu, tko da pomoje niso bh-5 čipi - na kolk napetosti priporočate da te dam?
igor0203 ::
poglej na rame če ti piše bh-5 al maš hynixove čipe.
če so bh-5 ti taki rami zaživijo šele pri 3.2+V(250MHZ 2-2-2-5), če pa hynix pa tam od 2.7-2.9
KrCbelca ::
takle zgleda, ...
na čipu pa piše:
TwinMOS
0534M
TMD7608F8E44F
igor0203 ::
Pol maš hynix čipe gor... Baje da so te tud kr v redu, da grejo 250MHz 2,5-3-3-x. Te rami ne marajo visokih voltaž, zato jim dej od 2.6-.2.9V. Kok pa rabjo za določeno frekvenco pa sam ugotov
KrCbelca ::
Ok, sm zdej divider zvečov, tko d je frekvenca rama 193, proca pa 2700, pa bom še 1x laufou čez noč prime, pa bomo vidl č bo se sesul komp, če se bom probal z memtestom, čeprav mam občutek d ram matrajo velike frekvence ;(
Javim ju3
KrCbelca ::
Hehe, nebi bil jest če nebi že spet neki uprašou:
Mam 3500+ pa me zanima do kere voltaže nej grem z vodnmu hlajenjem d bo ok za 24/7. Do kolk nej bo idle/load temperatura?
igor0203 ::
hja odvisn kok rab za stabilno delovanje. Sicer kšni za 24/7 gonjo proc na 1.7V, sam osebno ne bi šel čez 1.65V
fahrenGONE ::
A je kaj uspeha? :)
KrCbelca ::
2700 not stable, 2650 zgleda stable po 4 urah, bom vidu kak bo vnaprej, k sm frekvenco spustu, pa d vidmo č bo še zezal
fahrenGONE ::
OK, sporoci ko dobis stable, ker me zanima kako se kaj o/c 3500+. :)
KrCbelca ::
Trenutno na 2600MHz, stable.
Temperatura proca je 39°C pod 100% obremenitvijo, voltaža pa je 1.53V
Bom zdj lepo počas zvišou mal voltažo, k je točn 2600 omejitev za tako voltažo pol pa po 10MHz navijou (mn ne morm k mam divider 10)
BSOD na win 7
111956 (1850) iloveboobz
Težave - s cpujem ?
71611 (1559) painfulwhite
Posodobitev računalnika
312268 (1699) igiwarcraft
AMD 2500+ & Abit NF7
Oddelek: Navijanje
352835 (2081) Wad@
Prime 95 in error
Oddelek: Navijanje
201638 (1448) krucymucy
