Forum » Kaj kupiti » Kaj kupiti!!??? Svetujte
BaToCarx ::
maticna plosca:
GIGABYTE GA-7KNXP NFORCE2ultra FSB400/DDR/SB/USB2/LAN/RAID/SATA------------48,300
ABIT AN7 NFORCE2ultra FSB400/333MHZ/DDR/RAID/SATA/SI/ATX/ RETAIL-----------30,700
ASUS A7N8X GL/FW/RDE-------------------------------------------------------33,000
GIGABYTE 7N 400 PRO2 NFORCE2 DUAL-DDR/RAID/SATA/LAN------------------------32,000
procesor:
AMD Athlon XP 2600+ Barton 512K (Socket A)---------------------------------31,700(26,800-ITALY)
AMD Athlon XP 2800+ Barton 512K (Socket A)---------------------------------33,900-ITALY
ram:
(2X)DDR 256MB PC3.200/400MHZ-----------------------------------------------9,120(2X-18,000)
disketnik:
DISKETNIK------------------------------------------------------------------2,500
hdd:
MAXTOR S-ATA 120GB 7.200RPM 8MB CACHE--------------------------------------28,500
graficna:
ATI RADEON 9600 XT 128MB---------------------------------------------------43,800-ITALY
ATI RADEON 9600 PRO 128MB--------------------------------------------------51,800
ATI RADEON 9800 SE 128MB---------------------------------------------------52,400-ITALY
ATI RADEON 9600 XT 256MB---------------------------------------------------51,000
ohisje+napajalnik:
KING PLUS ATX MIDI TOWER 400W----------------------------------------------13,700
miska:
LOGITECH OPTICAL-----------------------------------------------------------3,000
cd-rw:
LITEON 32X 52X 32X-BURN PROOF----------------------------------------------11,300
hladilnik:
VOLKANO 12-----------------------------------------------------------------6,300
mrezna kartica:
NO-NAME 10/100-------------------------------------------------------------2,500
monitor:
CTR 21"IIJAMA VISON 500(RABLJEN)-------------------------------------------60,000
CTR SAMSUNG 959NF----------------------------------------------------------75,000
CTR PHILIPS BRILLIANCE 109 19"---------------------------------------------92,500-ITALY
LCD ACER723 17"------------------------------------------------------------132,000
CTR NEC M-SINC PROFLAT 19"-------------------------------------------------81,000-ITALY
LCD ACER AL1721 17"--------------------------------------------------------118,200-ITALY
Svetujte predvesem kako plato,kak proc&najvaznejse katero GRAFICNO.....
Seveda svetujte tud druge komponente ki niso na listi........;)
Rabim za spilanje:),pa mal za autocad........
HAVALA
procesor:
ram:
disketnik:
hdd:
graficna:
ohisje+napajalnik:
miska:
cd-rw:
hladilnik:
mrezna kartica:
monitor:
HAVALA
boštjan ::
Plata->AN7 ali nf7-s ali 8rda+ ali asus a7n8x-deluxe,1.gigabytka je predraga. Mrežne ne rabiš,je na plati
grafa->poglej za kakšno 5900LX verzijo,kis o boljše od 9600XT,drugač pa 9600XT 128MB
za cooler vzemi volcano silentboost
glede monitorja pa je stvar okusa,samo tvoje oči vedo kaj se jim najbolj dopade.
pazduha ::
Plata: Definitivno Asus-ka Deluxe A7n8x E Deluxe (najbolj zato, ker imajo vsi ostali proizvajalci glasne ventilatorje na north bridge-ih). ABIT-i so zadnje case precej tezavni, ne poznam pa cisto novih modelov, tako da ... drugace je pa ASUS a7n8x-e Deluxe zakon.
Procesor: zaenkrat 2600XP, ker ima najboljse razmerje med ceno in performancami.
Grafika? Sem definitivno za ATI-ja, ce se pa le da poskusi nabaviti kaj s pasivnim hlajenjem. Cisto subjektivno mnenje seveda:)
Ohišje: Priporocam Chieftec Dragon series z 360W napajalnikom (veliko prostora, kvaliteten napajalnik)
Procesorski hladilnik:Zalman 7000AlCu (predvsem zato ker zna biti tiho, ce mu znizas vrtljaje).
Mrezna kartica: on-board. Na navedenem ASUS-u imas dve: Gigabitno in eno navadno 100/10 Mbit.
Disk: Ce vprasas mene je S-ATA zaenkrat marketinski nateg. Pa se probleme bos imel pri instalaciji Winsov. Fizicno so diski se vedno enaki kot so bili, samo teoreticno ima novo vodilo vecjo prepustnost. Fino je da ima 8M cache-a, ni pa tako hudo vazno ali je S-ATA ali navaden P-ATA.
koyotee ::
Grafo kup Ati 9800 SE All in wonder k ga u izi spravš na 9800 pro!
Rear DVD collector!
JTD power!
JTD power!
boštjan ::
če ti je sreča naklonjena
laibachnsk ::
Če boš imel srečo boš super profitiral.Jst tudi razmišljam o tej kartici ampak bilo je veliko govora o tem,če nekaj zajeb...pol si zaklenjen na 9800se po možnosti z artefakti...Če vse uspe pol imaš 9800pro skupaj z tv tunerjem.Razmisli o tem.Pa proizvajalcev je veliko od herculesa ,sapphirea ,excalibura...Meni se zdi da je najvec navitih bilo od herculesa in da se da dobiti za ceno 65.000 .pozdrav
boštjan ::
če se že spravljaš v nakup 9800SE,te pazi,da je na PCB-ju od 9800(hercules) in ne od 9500pro(sapphire).
Gost ::
BTW: Monitor samsung 959nf se dobi za veliko ceneje (65.000 SIT, če ne ceneje). Drgač pa kr pogumno na LCD!
| » | Kakšen računalnik imate pa vi? (strani: 1 2 3 4 )Oddelek: Strojna oprema | 27365 (19404) | Vlad Tepeš |
| » | Katero graficno kartico uporabljate? (strani: 1 2 3 4 )Oddelek: Strojna oprema | 14037 (10573) | mtosev |
| » | grafične kartice, ponovnoOddelek: Kaj kupiti | 1960 (1385) | Caligula |
| » | Komentirajte konfiguracijo računalnika!!Oddelek: Kaj kupiti | 1684 (1362) | rene100 |
| » | ATI Radeon 9800 SE ali 9600XT (strani: 1 2 3 4 5 )Oddelek: Kaj kupiti | 13808 (10300) | flisko |
