Forum » Pomoč in nasveti » Daljinec za PC
Daljinec za PC
Xplicit ::
Zanima me kako bi si lahko nastimal daljinec za pc, da bi lahko med ogledom filma/poslusanjem glasbe/... spreminjal glasnost, naxt/prew track, play/pouse, ... in vse ostale splosne funkcije daljinca?
a je dovolj ce kupim navaden IR sprejemnik za PC in uporabin kaksen program kot naprimer pcremotecontrol.com/
in pa seveda kaksen daljinec mi priporocate?
Pa ce si je to ze kdo omislu (kar ne dvomim) me zanima kako se obnese in katero programsko opremo priporocate.
hvala
hvala
- spremenil: ali3n ()
pivmik ::
Najboljši program za daljince je uICE:
http://www.mediatexx.com/download/
Podpira vse žive in mrtve daljince.
Sprogramiraš lahko katerokoli tipko daljinca, premikaš lahko kurzor od miške z daljincem, tipkaš, večaš in manjšaš volume, zaganjaš programe, karkoli!
LP, Gregor GRE^
ali3n ::
hm... tak daljinec tudi mene zanima - samo v FAQ piše tole:
Can uICE work with my computer's / laptop's internal IR port?
Can uICE work with IrDA?
Internal IR ports are usually IrDA network interfaces. This technology was not designed to work with handheld remote controls, and most models do not work at all.
Yes, IrDA is an infrared light based technology. But there are physical differences between IrDA infrared light and the light emitted by remote controls (wave length/frequency), and, even more important, remote controls and IrDA use protocols. These protocols are completely incompatible. Most IrDA receivers filter out all incoming signals that do not follow the IrDA protocol specification, so no matter how long you try, your hardware cannot work with remote controls. No, it doesn't make a difference whether it's a built-in, serial port or USB device. Because of all these troubles, uICE cannot and will not support IrDA.
Very (very) few models seem to be able to receive infrared signals from RCs. If you're using Win98, read this. No chance under ME, 2k or XP.
vaše izkušnje?
vaše izkušnje?
- "Rozi vidm." "S psom!"
sprejemnik si sam nardis (dobrih 5 minut dela)
za daljinca lohk pa uporabis kr od domacega televizorja, al pa kupis enga univerzalnega, ki ti je usec.
Xplicit ::
ok recimo da bi rad kupu sprejemnik (se mi ne da delat oz. se nimam cajta s tem zajebavat)
katerga priporocate oz. kje jih prodajajo
se to - kateri daljinci so ql (katera firma)?
5er--> ::
Xplicit ::
ne jest sprasujem za IR sprejemnik in daljinec (ker un ati-jev je en wirelles al neki), ker ce kupim en mal boljsi daljinec ga lahko uporabljam tud za tv, dvd, ...
torej kaksen IR sprejemnik kupit in KJE?
| » | Daljinec za računalnikOddelek: Strojna oprema | 4576 (4222) | roli |
| » | Cinergy 400Oddelek: Zvok in slika | 1265 (1175) | rap3r |
| » | IR daljinec ureja komp.Oddelek: Programska oprema | 1938 (1673) | thramos |
| » | IR sprejemnik!!!Oddelek: Strojna oprema | 2903 (2411) | msmiha |
| » | IR oddajnik za pc (vezje)Oddelek: Loža | 2005 (1728) | TheHijacker |
