Mozilla - začasne internetne datoteke?
kihc ::
Čisto preprosto vprašanje - kam Mozilla shranjuje začasne internetne datoteke?
MilkyWay ::
X:\Documents and Setting\User\Application Data\Mozilla... in tako naprej, da prideš do direktorija Cache.
Kakšne posebne razlage tukaj ni potrebne, treba je samo nastaviti, da ti explorer pokaže skrite direktorije.
kihc ::
WOW, tukaj notri so sami čudni fajli brez končnice. Hočeš reči, da mozilla shranjuje te stvari v "svojem formatu" ?
CCfly ::
Ta "poseben format" so preimenovane datoteke. Zakaj, zato ker ima vsaka stran kakasno sliko z imenom email.gif ali pa kaj podobnega.
kihc ::
Ok, da ne bom nekaj brezveze teoriziral...
Tukaj je filmček v .mov obliki, ki ga browser pred predvajanjem zloada v cache, in potem predvaja.
Če bi jaz rad ta filmček shranil na disk, ga moram potegnit od tam kamor ga je browser shranil.
IE lepo shranjuje te filmčke (in druge datoteke, slike ipd...), v mapo temporaraly internet files, od kjer potem filmček preprosto skopiraš kamor hočeš.
V mozilli tega ne morem narediti, torej, ali obstaja kaka druga pot kot ta, da odprem isto stran v IE?
Hvala
CCfly ::
Tole bo pravo:
> Here`s my wish before the source release tomorrow to make offline browsing
> more convenience:
> 1) Store the actual filename in cache directory - only rename the files
> if there are duplicates and we have run out of cache subdirectories. The
> way MSIE4 handle the cache (Temporary Internet Files) is very easy for
> users to search and copy the cache if needed.
We don`t do this for security reasons. If, for example, someone could guess
the name of your cache directory, then they could create web content that
directly references documents on your disk. If the cache contained
information from a financial institution, private messages in your mail, or
even the URLs that you`d visited, this would be a violation of privacy. MSIE
actually had a privacy violation in an earlier version exactly because they
stored filenames in plaintext in the cache (and because files coming out of
the cache were executed as local files and therefore with local permissions).
If you as a user want to look at what`s in your cache, type "about:cache" in
the URL bar.
kihc ::
To sem rabil, hvala ti CCfly!
Chrome Cache or something..?
5819 (758) shadeX
Opera 9 (strani: 1 2 3 4 5 )
Oddelek: Novice / Brskalniki
23625947 (17695) R33D3M33R
Primerjava hitrosti med Opero in FFjem
Oddelek: Omrežja in internet
223082 (2533) Bakunin
Težave Xgroznik-a pri izdelavi strani!
Oddelek: Izdelava spletišč
252338 (1794) OwcA
Windows švicarski sir z luknjo GDI32 (strani: 1 2 )
Oddelek: Novice / Varnost
5313419 (10972) denial
