Forum » Pomoč in nasveti » CD-RW ne dela pod WIN 2000 ?
EvilGod ::
Ja mam Nerota pa sm šol cdje snema ... in stvarca ne dela ...
napisu je error log:
EvilGod
Hell d.o.o.
150356-917114-082759-157466
Windows NT 5.0
WinAspi: -
ahead WinASPI: File 'C:\Program Files\ahead\Nero\Wnaspi32.dll': Ver=2.0.1.16, size=151619 bytes, created 15.4.2001 22:28:22
Nero Version: 5.0.4.8
Recorder: Version: 1.0Y - HA 1 TA 1 - 5.0.4.8
Adapter driver: HA 1
Drive buffer : 1280kB
CD-ROM: Version: 1.0q - HA 0 TA 1 - 5.0.4.8
Adapter driver: HA 0
SONY CD-ROM CDU701 1.0q viadsk Port 0 ID 1 DMA: ?
TEAC CD-W54E 1.0Y viadsk Port 1 ID 1 DMA: ?
AutoRun : 1
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 20971520 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 127MB (130544kB)
Free physical memory: 12MB (13112kB)
Memory in use : 89 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry: 1
Wizard: Off
CD-ROM (ISO)
18.4.2001
18:15:29 #1 Text 0 File Reader.cpp, Line 116
Reader running
18:15:29 #2 Text 0 File Writer.cpp, Line 108
Writer TEAC CD-W54E running
18:15:29 #3 ISO9660GEN -11 File geniso.cpp, Line 3245
First writeable address = 0 (0x00000000)
18:15:41 #4 Text 0 File ThreadedTransferInterface.cpp, Line 644
Setup items (original item values)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original CD pos #0 + 332289 (332289) = #332289/73:50.39
relocatable, CD pos for caching/writing not required/required, no patch infos
18:15:45 #5 Text 0 File Burncd.cpp, Line 1661
Recorder: TEAC CD-W54E;
CDR code: 00 97 32 00; OSJ entry from: TDK Corporation
ATIP Data:
Special Info [hex] 1: C0 00 98, 2: 61 20 00 (LI 97:32.00), 3: 4A 3B 00 (LO 74:59.00)
Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
18:15:45 #6 Text 0 File ThreadedTransferInterface.cpp, Line 778
Prepare recorder TEAC CD-W54E for write in TAO
DAO infos:
MCN:
TOCTYPE: 0x0 Close CD
Tracks 1 to 1:
TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 680835072
18:15:45 #7 Text 0 File ThreadedTransferInterface.cpp, Line 806
Removed 2 run-out blocks from end of track 1.
18:15:45 #8 Text 0 File ThreadedTransferInterface.cpp, Line 644
Setup items (after recorder preparation)
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 332287 blocks [TEAC CD-W54E]
18:15:46 #9 Phase 24 File dlgbrnst.cpp, Line 1193
Start of caching files
18:16:54 #10 Phase 25 File dlgbrnst.cpp, Line 1193
Caching files completed
18:16:54 #11 Phase 28 File dlgbrnst.cpp, Line 1193
Start of speed measurement
18:16:54 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1765
Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
18:18:59 #13 Text 0 File ThreadedTransfer.cpp, Line 216
all writers idle, stopping conversion
18:18:59 #14 Phase 29 File dlgbrnst.cpp, Line 1193
Speed measurement done: 29x (4396 KB/s)
18:18:59 #15 Phase 32 File dlgbrnst.cpp, Line 1193
Start of simulation at 4x (600 KB/s)
18:18:59 #16 Text 0 File ThreadedTransferInterface.cpp, Line 1765
18:19:05 #17 SCSI -26 File Cdrdrv.cpp, Line 1351
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x050300B0
Status: 0x82 (0x07, SCSI_NO_DEVICE)
HA-Status 0x00 (0x00, OK)
TA-Status 0x00 (0x00, OK)
Sense Key: 0x00 (KEY_NO_SENSE)
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0xAA 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x1E 0x00 0x00
Sense Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
18:19:05 #18 CDR -26 File Writer.cpp, Line 284
SCSI/ATAPI command timeout error
18:19:05 #19 Text 0 File ThreadedTransfer.cpp, Line 216
18:19:05 #20 Text 0 File ThreadedTransfer.cpp, Line 210
conversion idle, stopping reader
18:19:05 #21 CDR -201 File WriterStatus.cpp, Line 114
Invalid writestate
18:19:05 #22 TRANSFER -18 File WriterStatus.cpp, Line 114
Could not perform EndTrack
18:19:05 #23 Phase 34 File dlgbrnst.cpp, Line 1193
Simulation failed at 4x (600 KB/s)
18:19:06 #24 Text 0 File Scsicmd.cpp, Line 311
SCSI not using temporary buffers
20 out of 20 temporary buffers allocated
Existing drivers:
File 'Drivers\CDR4_2K.SYS': Ver=2.5 (089), size=52720 bytes, created 10.4.2000 7:10:56
File 'Drivers\CDRALW2K.SYS': Ver=1.00 (1030), size=22585 bytes, created 10.4.2000 7:10:56
ja to je napisu ... in ne vem točn zakaj ...
drgač mi pa u windowsih sam napiše d sta oba cd-roma scsi (kar nista) ampak tko je sam odkril in bereta uredu ...
Če se vm kj sanja prosm napište!
EvilGod
Hell d.o.o.
Windows NT 5.0
WinAspi: -
Recorder:
Adapter driver:
CD-ROM:
Adapter driver:
AutoRun : 1
CmdQueuing : 1
CmdNotification: 2
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Use Inquiry: 1
Wizard: Off
CD-ROM (ISO)
18.4.2001
Reader running
ATIP Data:
DAO infos:
MCN:
Tracks 1 to 1:
Sense Code: 0x00
Sense Qual: 0x00
Invalid writestate
Existing drivers:
To je to , CD-R ti je prepoznal kot SCSI. Probaj z Intlovimi ULTRA Ata gonilnik , da ti nastavi na IDE.
To seje meni zgodilo , ko sem imel v BIOS-u ACIP disablan.
Probaj ?
Probaj ?
| » | NEC ND-3540A problem...Oddelek: Pomoč in nasveti | 2785 (2076) | dean444 |
| » | LG GSA-4120B dela probleme pri pečenju DL DVD+RjevOddelek: Strojna oprema | 2195 (2004) | mtosev |
| » | Plextor writer 24/48/48 problem! (strani: 1 2 )Oddelek: Strojna oprema | 6229 (5738) | Hux |
| » | Težave s pekačemOddelek: Pomoč in nasveti | 2375 (2315) | boštjan |
| » | PLEXTOR BurfProof unicuje cdje - prosim pomagajte!Oddelek: Pomoč in nasveti | 2163 (1917) | krho |
