Adobe Express Photos napaka 0X80070005
buick ::
Imam eno prošnjo. Dolga leta že za hitro in preprosto urejanje fotografij uporabljam brezplačni program Adobe Express Photos (prej se je imenoval Photoshop Express), ki se ga dobi v Microsoft Store.
Pred dnevi ga je bilo treba preko te trgovine posodobit na to novo verzijo.
Ampak poskusil sem že ničkolikokrat pa mi ne deluje. Namesti mi ga, odprem ga ampak ko naložim eno fotografijo se program takoj zapre.
Napiše mi kodo napake 0X80070005.
Poskusil sem že par rešitev, ki se jih najde na spletu pa zaenkrat brez uspeha.
Bi prosil, če lahko nekdo poskusi namestiti ta program na svoj računalnik, da vidim ali je napaka pri meni ali je kaj s programom, ki je v Microsoft Store.
Najlepša hvala.
Na hitro google:
The Adobe Express 0X80070005 error, often encountered on Windows, is an "Access Denied" code indicating that the app lacks the necessary permissions or file access to update, install, or download assets. This issue often arises when using the Microsoft Store version of Adobe Express.
Here are the most effective solutions to resolve this error:
1. Fix Microsoft Store Permissions (Most Common Fix)
If the error occurs while installing or updating:
Sign out and Sign in: Log out of the Microsoft Store, restart the computer, and sign back in.
Reset MS Store Cache: Press Windows Key + R, type wsreset.exe, and hit Enter. A command prompt window will open and close automatically.
Remove Duplicate Accounts: Go to Settings > Accounts > Email & accounts. If your Microsoft account is listed twice, remove the secondary instance.
2. Repair or Reinstall Adobe Express
If the app is installed but crashing or failing to update:
Repair/Reset the App: Go to Settings > Apps > Apps & features (or Installed Apps). Locate Adobe Express, click the options (three dots), select Advanced options, and click Repair or Reset.
Reinstall the App: Uninstall Adobe Express, restart your computer, and reinstall it from the Microsoft Store.
3. Clear Download Cache (SoftwareDistribution)
If the error is related to Windows Update interference:
Stop Update Services: Open Command Prompt as Administrator, type net stop wuauserv, then net stop bits and hit Enter after each.
Delete Temporary Files: Navigate to C:\Windows\SoftwareDistribution\Download and delete all files inside the folder.
Restart Services: In Command Prompt, type net start wuauserv, then net start bits and restart your computer.
4. Check Antivirus/Firewall
Third-party security software can interfere with Adobe's access to files.
Temporarily Disable: Turn off your antivirus or firewall temporarily to see if it resolves the installation/download issue. If it does, create an exclusion rule for Adobe Express.
5. Check System Files
Run SFC Scan: Open PowerShell as Administrator, type sfc /scannow, and hit Enter to repair corrupted system files.
If the error persists, ensure you are running Windows as an administrator and that your system time and date are set automatically.
buick ::
Hvala bom poskusil kar še nisem..sem bil zdaj na chatu z enim iz Adobe pa bom poskusil njegovo varianto, ko pridem domov na svoj računalnik..
Ok, če pa ne bo šlo pa javi..bomo že nekako rešili:)
buick ::
Uspelo, kako ne vem, ker sem včeraj poskusil 20X, danes pa je uspelo takoj...
Nadomestilo za Adobe Creative Cloud (strani: 1 2 3 )
Oddelek: Programska oprema
12945896 (639) opeter
težave s ponastavitvijo w11
5540 (438) mirator
Windows update težave
131864 (595) jedateruk
Adobe ne bo prevzel Figme
84649 (3276) opeter
Win 10 vedno update-a in fail-a ob restartu
73152 (2983) crniangeo
