Forum » Operacijski sistemi » Kako dobiti znak @ na linuxu
arjad ::
Prenesel sem vinux - linux. Sedaj imam problem, ker ne najdem znaka @. Ali lahko kdo pomaga ?
Nastavi isto keaboard layout kot si ga imel v Windowsih...
Slovenski je podprt že od leta 1993
LiquidAI ::
Za permanentno delovanje z udev najdeš primer na gist
Na hitro takole
Ustvari novo datoteko v /etc/udev/rules.d/00-usb-keyboard.rules
chmod a+x /etc/udev/rules.d/00-usb-keyboard.rules
Ustvari datoteko /usr/local/bin/usb-keyboard-udev
chmod a+x /usr/local/bin/usb-keyboard*
Na hitro takole
ATTRS{idVendor}=="060b", ATTRS{idProduct}=="5252", OWNER="ubuntu"
ACTION=="add", RUN+="/usr/local/bin/usb-keyboard-udev in", OWNER="ubuntu"
ACTION=="remove", RUN+="/usr/local/bin/usb-keyboard-udev out", OWNER="ubuntu"
#!/bin/sh
LOG=/var/log/usb-keyboard.log
command=$(dirname $0)/usb-keyboard
echo $@ >> $LOG
[ -x "$command" ] && $command $1 >>$LOG 2>&1 &
#!/bin/bash
GSETTING=/usr/bin/gsettings
SETXKBMAP=/usr/bin/setxkbmap
XINPUT=/usr/bin/xinput
KBNAME="Logitech"
XKBMODEL="pc105"
XKBLAYOUT="sl"
XKBVARIANT="qwertz"
USERLIST=$(w -h | cut -d' ' -f1 | sort | uniq)
for CUR_USER in ${USERLIST}; do
CUR_USER_XAUTH="$(sudo -Hiu ${CUR_USER} env | grep -e "^HOME=" | cut -d'=' -f2)/.Xauthority"
CUR_USER_DISPL=":0"
export XAUTHORITY="${CUR_USER_XAUTH}"
export DISPLAY="${CUR_USER_DISPL}"
if [ -f "${CUR_USER_XAUTH}" ]; then
case $1 in
'in')
KEYBOARDS=$($XINPUT list --short | grep $KBNAME | grep keyboard | sed -e 's/^.*id=\([0-9]\+\).*/\1/g')
if [ -n "$KEYBOARDS" ]; then
[ -x $GSETTING ] && $GSETTING set org.gnome.settings-daemon.plugins.keyboard active false
for ID in $KEYBOARDS; do
[ -x $SETXKBMAP ] && $SETXKBMAP -device $ID -layout $XKBLAYOUT -model $XKBMODEL -variant $XKBVARIANT
done
notify-send "Changed $KBNAME layout to $XKBLAYOUT-$XKBVARIANT ($XKBMODEL)"
fi
echo "keyboards id(s) is (are) $KEYBOARDS"
'out')
# apparently nothing to do with TDE (trinity KDE)
[ -x $GSETTING ] && $GSETTING set org.gnome.settings-daemon.plugins.keyboard active true
printf "wrong parameter: $1\n"
exit 1
esac
fi
done
| » | Zaznavanje Arduina priklopljenega preko USB v LinuxuOddelek: Programiranje | 2042 (1536) | mojster_joni |
| » | Raspberry Pi grafična težava (strani: 1 2 )Oddelek: Programska oprema | 4931 (3948) | filips |
| » | Gentoo - problemi z framebuffer in ifconfig (strani: 1 2 )Oddelek: Operacijski sistemi | 6195 (5519) | Zaibatsu |
| » | Linux vprašanjaOddelek: Operacijski sistemi | 3218 (2451) | BigWhale |
| » | Linux / ATI Radeon / problem z driverjiOddelek: Operacijski sistemi | 2201 (2018) | ahac |
