Forum » Programska oprema » Raspberry Pi grafična težava
filips ::
Imam Raspberry Pi 2 B+. Imam sistem Raspbian. Zaganjanje imam nastavljeno v grafičnem načinu. Ko sem ga enkrat ponovno zagnal, se mi zgornja menijska vrstica ne prikaže in nekaj utripa, kot je prikazano v videoposnetku na povezavi. Zanima me, kako to popraviti, brez da ponastavim sistem.
video: https://onedrive.live.com/redir?resid=9...!503&authkey=!AG4cZRQE0sH9Afo&ithint=video%2cmp4
- spremenil: filips ()
filips ::
To je pravi link:
94FD65D62BCC2864!503&
(v treh vrsticah je, ker drugače ne dela)
filips ::
SEm pogledal ta link in vpisal sudo usermod -aG video pi pa še vedno ne dela
AC_DC ::
Kaj piše v X server logu http://askubuntu.com/questions/26525/wh... http://unix.stackexchange.com/questions... ?
link na video v skrajšani obliki:
http://tinyurl.com/zwbgxuz
- spremenilo: AC_DC ()
filips ::
Vse logs datoteke so na
94FD65D62BCC2864!504&authkey=
!AJPVj29um_g1O8Q&ithint=folder%2clog
d4vid ::
filips ::
Ne vem. Kako to preverim?
Do včeraj je delalo normalno.
jukoz ::
A se ti X-i sploh zaženejo. Pa daj skopiraj par zadnjih vrstic iz xorg.log kar sem, tale onedrive ne dela lih najboljše - ne zloada nič.
filips ::
[ 41.856] (--) evdev: Logitech USB Receiver: Found keys
[ 41.856] (II) evdev: Logitech USB Receiver: Configuring as mouse
[ 41.857] (II) evdev: Logitech USB Receiver: Configuring as keyboard
[ 41.857] (II) evdev: Logitech USB Receiver: Adding scrollwheel support
[ 41.857] (**) evdev: Logitech USB Receiver: YAxisMapping: buttons 4 and 5
[ 41.857] (**) evdev: Logitech USB Receiver: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 41.858] (**) Option "config_info" "udev:/sys/devices/platform/soc/20980000.usb/usb1/1-1/1-1.4/1-1.4:1.1/0003:046D:C52B.0002/input/input1/event1"
[ 41.858] (II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: KEYBOARD, id 7)
[ 41.858] (**) Option "xkb_rules" "evdev"
[ 41.858] (**) Option "xkb_model" "logicda"
[ 41.858] (**) Option "xkb_layout" "si"
[ 41.859] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 41.871] (II) evdev: Logitech USB Receiver: initialized for relative axes.
[ 41.872] (WW) evdev: Logitech USB Receiver: ignoring absolute axes.
[ 41.874] (**) Logitech USB Receiver: (accel) keeping acceleration scheme 1
[ 41.874] (**) Logitech USB Receiver: (accel) acceleration profile 0
[ 41.874] (**) Logitech USB Receiver: (accel) acceleration factor: 2.000
[ 41.874] (**) Logitech USB Receiver: (accel) acceleration threshold: 4
[ 41.878] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/mouse0)
[ 41.878] (II) No input driver specified, ignoring this device.
[ 41.878] (II) This device may have been added with another device file.
filips ::
Še zadnjih par vrstic Xorg.1.log:
[ 200.379] (--) evdev: Logitech USB Receiver: Vendor 0x46d Product 0xc52b
[ 200.380] (--) evdev: Logitech USB Receiver: Found 20 mouse buttons
[ 200.380] (--) evdev: Logitech USB Receiver: Found scroll wheel(s)
[ 200.380] (--) evdev: Logitech USB Receiver: Found relative axes
[ 200.380] (--) evdev: Logitech USB Receiver: Found x and y relative axes
[ 200.380] (--) evdev: Logitech USB Receiver: Found absolute axes
[ 200.381] (II) evdev: Logitech USB Receiver: Forcing absolute x/y axes to exist.
[ 200.381] (--) evdev: Logitech USB Receiver: Found keys
[ 200.381] (II) evdev: Logitech USB Receiver: Configuring as mouse
[ 200.381] (II) evdev: Logitech USB Receiver: Configuring as keyboard
[ 200.381] (II) evdev: Logitech USB Receiver: Adding scrollwheel support
[ 200.382] (**) evdev: Logitech USB Receiver: YAxisMapping: buttons 4 and 5
[ 200.382] (**) evdev: Logitech USB Receiver: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 200.382] (**) Option "config_info" "udev:/sys/devices/platform/soc/20980000.usb/usb1/1-1/1-1.4/1-1.4:1.1/0003:046D:C52B.0002/input/input1/event1"
[ 200.382] (II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: KEYBOARD, id 7)
[ 200.382] (**) Option "xkb_rules" "evdev"
[ 200.383] (**) Option "xkb_model" "logicda"
[ 200.383] (**) Option "xkb_layout" "si"
[ 200.383] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 200.386] (II) evdev: Logitech USB Receiver: initialized for relative axes.
[ 200.386] (WW) evdev: Logitech USB Receiver: ignoring absolute axes.
[ 200.410] (**) Logitech USB Receiver: (accel) keeping acceleration scheme 1
[ 200.411] (**) Logitech USB Receiver: (accel) acceleration profile 0
[ 200.411] (**) Logitech USB Receiver: (accel) acceleration factor: 2.000
[ 200.411] (**) Logitech USB Receiver: (accel) acceleration threshold: 4
[ 200.415] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/mouse0)
[ 200.415] (II) No input driver specified, ignoring this device.
[ 200.415] (II) This device may have been added with another device file.
filips ::
Če vpišem sudo startx mi napiše:
X.Org X Server 1.12.4
Release Date: 2012-08-27
X Protocol Version 11, Revision 0
Build Operating System: Linux 3.2.0-2-mx5 armv7l Debian
Current Operating System: Linux raspberrypi 4.4.7+ #877 Sun Apr 17 12:45:04 BST 2016 armv6l
Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1232 bcm2708_fb.fbheight=992 bcm2708.boardrev=0x10 bcm2708.serial=0x7082120c smsc95xx.macaddr=B8:27:EB:82:12:0C bcm2708_fb.fbswap=1 bcm2708.uart_clock=3000000 bcm2708.disk_led_gpio=47 bcm2708.disk_led_active_low=0 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p6 rootfstype=ext4 elevator=deadline rootwait
Build Date: 11 February 2015 09:31:17PM
xorg-server 2:1.12.4-6+deb7u6 (Julien Cristau <jcristau@debian.org>)
Current version of pixman: 0.33.1
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.1.log", Time: Thu Apr 21 16:54:38 2016
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
FATAL: Module g2d_23 not found.
The XKEYBOARD keymap compiler (xkbcomp) reports:
> Warning: Type "ONE_LEVEL" has 1 levels, but <RALT> has 2 symbols
> Ignoring extra symbols
> Warning: Type "TWO_LEVEL" has 2 levels, but <TLDE> has 4 symbols
Errors from xkbcomp are not fatal to the X server
xinit: connection to X server lost
waiting for X server to shut down Server terminated successfully (0). Closing log file.
xinit: unexpected signal 2
filips ::
Še zadnjih par vrstic Xorg.2.log:
[ 414.705] (--) evdev: Logitech USB Receiver: Found x and y relative axes
[ 414.706] (--) evdev: Logitech USB Receiver: Found absolute axes
[ 414.706] (II) evdev: Logitech USB Receiver: Forcing absolute x/y axes to exist.
[ 414.706] (--) evdev: Logitech USB Receiver: Found keys
[ 414.706] (II) evdev: Logitech USB Receiver: Configuring as mouse
[ 414.706] (II) evdev: Logitech USB Receiver: Configuring as keyboard
[ 414.706] (II) evdev: Logitech USB Receiver: Adding scrollwheel support
[ 414.707] (**) evdev: Logitech USB Receiver: YAxisMapping: buttons 4 and 5
[ 414.707] (**) evdev: Logitech USB Receiver: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 414.707] (**) Option "config_info" "udev:/sys/devices/platform/soc/20980000.usb/usb1/1-1/1-1.4/1-1.4:1.1/0003:046D:C52B.0002/input/input1/event1"
[ 414.707] (II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: KEYBOARD, id 7)
[ 414.708] (**) Option "xkb_rules" "evdev"
[ 414.708] (**) Option "xkb_model" "logicda"
[ 414.708] (**) Option "xkb_layout" "si"
[ 414.708] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 414.731] (II) evdev: Logitech USB Receiver: initialized for relative axes.
[ 414.731] (WW) evdev: Logitech USB Receiver: ignoring absolute axes.
[ 414.733] (**) Logitech USB Receiver: (accel) keeping acceleration scheme 1
[ 414.733] (**) Logitech USB Receiver: (accel) acceleration profile 0
[ 414.733] (**) Logitech USB Receiver: (accel) acceleration factor: 2.000
[ 414.733] (**) Logitech USB Receiver: (accel) acceleration threshold: 4
[ 414.737] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/mouse0)
[ 414.737] (II) No input driver specified, ignoring this device.
[ 414.738] (II) This device may have been added with another device file.
[ 415.026] (II) evdev: Logitech USB Receiver: Close
[ 415.027] (II) UnloadModule: "evdev"
[ 415.027] (II) evdev: Logitech USB Receiver: Close
[ 415.028] (II) UnloadModule: "evdev"
[ 415.098] Server terminated successfully (0). Closing log file.
Highlag ::
Probleme dela kak program, ki se drugače pokaže v ukazni (start) vrstici. Če bi bilo z grafiko kaj narobe bi obvisel v konzoli. Poglej kaj se zgodi ob zagonu. (fstab in podobne konfiguracijske datoteke).
filips ::
Kako to preverim?
Mislim, da sem enkrat prej po nesreči ustvaril še eno ukazno (start) vrstico in zato ne dela. Kako bi jo odstranil?
jukoz ::
A ti X-i delajo al ne? A maš kakšno grafiko, okna in podobno?
"start vrstici" se reče "panel"
V terminal napiši
# ps fax | grep panel
In jih boš našel - potem jih pa lahko po vrsti ubijaš:
# kill -=pid_številka_panela=-
Na kakšen monitor pa to priklapljaš? Je to nek LCD? Al je kaj analognega?
V terminal napiši
filips ::
Startx se mi zažene. Imam okna in podobno. Samo panel mi ne dela. Sem pogledal z ps fax | grep panel in mi napiše:
5266 ? Rl 0:00 \_ lxpanel --profile LXDE-pi
5269 pts/0 S+ 0:00 \_ grep --color=auto panel
Kateri panel je tisti pravi, ki bi moral biti na začetku tukaj?
Monitor imam LCD. Vežem prek HDMI to VGA pretvornika saj monitor ne podpira HDMI. To mi ne dela, tudi če priključim na televizijo prek HDMI ali pa se povežem prek oddaljenega namizja.
d4vid ::
Čist tako, zakaj kompliciraš, naloži raspian na novo pa bo mir. Razen če imaš že kaj takega gor...
jukoz ::
To je ta panel, drugi je ukaz ki si ga ravnokar pognal.
V X-ih odpri konzolo in not napiši "xrandr". Izpisal ti bo možne resolucije. Če ti jih monitor ne podpira jih boš moral popraviti.
Drugače te pa konverter zeza. Poglej če ima monitor tudi DVI, v tem primeru HDMI-DVI konverterji delujejo odlično.
filips ::
Čevpišem xrandr mi napiše:
xrandr: Failed to get size of gamma for output default
Screen 0: minimum 1232 x 992, current 1232 x 992, maximum 1232 x 992
default connected 1232x992+0+0 0mm x 0mm
1232x992 0.0*
Mislim da z monitorjem ni nič narobe, saj na televiziji na katero sem vezal prek HDMI tudi ne dela. Če se povežem prek oddaljenega namizja mi tudi ne dela. Prej je delalo.
1232x992 0.0*
jukoz ::
Verjetno ti je tisti konverter poslal napačne podatke o možnih resolucijah RPi-ju, ta si jih je pa zapomnil in zapisal. Resolucija 1232 x 992 nikakor ni pravilna. Predvidevam da imaš monitor z 1280x1024?
Kakorkoli, xrandr je zelo uporabno orodje. Sam imam en 1680x1050 zaslon ki me občasno zeza, zato moram mojemu linux povedati kako dela.
Bom prilimal par ukazov, ti jih boš moral pa seveda prirediti za svoje potrebe:
Vsaka vrstica je svoj ukaz
# za dodajanje 1680x1050 resolucije na CRT1
xrandr
cvt 1680 1050 60
xrandr --newmode "1680x1050_60.00" 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync
xrandr --addmode CRT1 1680x1050_60.00
# za force željene resolucije na zaslonu
xrandr
xrandr --addmode VGA-0 1680x1050_60.00
xrandr --output VGA-0 --mode 1680x1050_60.00
xrandr
cvt 1680 1050 60
xrandr
filips ::
Imam samo hdmi to vsa koncertov. Monitor ima razmerje 4:3 televizijo pa 16:9 Ne vem zakaj mi to ne dela zdaj, prej pa mi je delalo. To z resolucijo mi tudi ni jasno, saj je prej delalo
filips ::
Kako bi lHko sistem nanov postavil, neda bi zbrisal stvari, ki so gor ali pa bi jih moral na novo naložiti?
seveda bi jih moral nanovo naložit. Ampak mislim da migracija nebi trajala 4 dni, kolker se že s tem problemom ukvarjaš
jukoz ::
Ne vem zakaj mi je to začelo delati težave šele zdaj.
Odgovor potrebujem čim prej.
A si pogledal kaj sem ti napisal?
z ukazom "cvt 1680 1050 60" dobiš info za resolucijo 1680x1050 pri 60Hz
kar ti vrne nato vpišeš v xrandr z:
xrandr --newmode ime_resolucije_ki_jo_želiš 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync
nato dodaš ta nov mode na poljuben zaslon
xrandr --addmode zaslon_na_katerem_jo_želiš ime_resolucije_ki_jo_želiš
da ga vklopiš pa:
xrandr --output zaslon_na_katerem_jo_želiš --mode ime_resolucije_ki_jo_želiš
filips ::
Kako izvem ime zaslona?
Prosim začimprejši odgovor
filips ::
Resolucijo sem ustvaril, ampak ne morem narediti xrandr --addmode zaslon_na_katerem_jo_želiš ime_resolucije_ki_jo_želiš in xrandr --output zaslon_na_katerem_jo_želiš --mode ime_resolucije_ki_jo_želiš
saj ne vem imena zaslona.Kako ga izvem?
jukoz ::
poglej izpis xrandr, tam ti lepo piše:
zaslon_na_katerem_je_sedaj connected neka_resolucuja (normal left inverted right x axis y axis)
????x???? 60.0*+ 50.0
RPi ima samo en izhod za zaslon in se verjetno imenuje HDMI, nisem pa prepričan. Zaslon se mora imenovati enako kot zaslon_na_katerem_je_sedaj
filips ::
Sem delal po navodilih pa mi je napisalo to:
ko sem vpisal cvt 1680 1050 60 mi je prišlo
# 1680x1050 59.95 Hz (CVT 1.76MA) hsync: 65.29 kHz; pclk: 146.25 MHz
Modeline "1680x1050_60.00" 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync
ko sem vpisal xrandr --newmode resolucija-dve 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync je prišlo
X Error of failed request: BadName (named color or font does not exist)
Major opcode of failed request: 149 (RANDR)
Minor opcode of failed request: 16 (RRCreateMode)
Serial number of failed request: 19
Current serial number in output stream: 19
ko sem vpisal xrandr --addmode default resolucija-dve je prišlo
ko pa sem vpisal xrandr --output default --mode resolucija-dve je pa prišlo
xrandr: Configure crtc 0 failed
Odgovor prosim čim prej
Hvala
Hvala
filips ::
Ali mislite da bi sudo rpi-update pomagal to rešiti?
filips ::
Sem probal tudi izklopiti konvertor, ga priključiti na elektriko in ga ko je bil prižgan priklopiti na monitor, pa ni delalo
dej flešni na drugo kartico frišn rapsbian, da vidiš če je sploh problem software.
filips ::
Sem namestil na drugo kartico in tam dela. Izgleda da je težava s sistemom. Kaj naj naredim?
Ali bi lahko posodobil sistem, brez da bi zbrisal stvari ki so gor?
filips ::
Težavo sem odpravil. Ali lahko posodobim sistem, brez da bi zbrisal stvari, ki so na kartici?
| » | Nekdo mi nekako vdira (strani: 1 2 )Oddelek: Informacijska varnost | 15969 (11228) | Mare2 |
| » | Linux Ubuntu - kako ustvarim bližnjico, kako naložim Flash?Oddelek: Operacijski sistemi | 1509 (1295) | SkyEye90 |
| » | Brezžična tipkovnica logitech k 400 in Lg TVOddelek: Zvok in slika | 3613 (2480) | Klemen12 |
| » | logitech mx 620 -izgubljen 2.4 GHz micro-receiverOddelek: Pomoč in nasveti | 1742 (1638) | gregor |
| » | [Linux]mousewheel in slo tipkovnicaOddelek: Operacijski sistemi | 1615 (1531) | Quikee |
