WinXP limitacija pri 160 GB diskih
DanKick ::
Zanima me samo, če je potreben popravek le v primeru ATA diskov ali velja to tudi za diske priključene na SATA kontroler?
Problem
The full capacity of ATA drives larger than 137GB is not recognized by the operating system.
Solution
Currently, there are three options to remedy the 137 Gigabyte barrier. Failure to implement one of the following installation options will result in data loss when trying to access the hard disk beyond 137 Gigabytes.
Installation Option 1. Upgrade the operating system to either Windows 2000 with Service Pack 3 (or newer) or Windows XP with Service Pack 1 (or newer) and download the Maxtor Big Drive Enabler software patch. The Maxtor Big Drive Enabler, once executed, will update the Windows registry for large drive support.
jest10 ::
Ni važno kako je disk priklopljen. Važna je njegova velikost.
Seveda ga rabiš
Disk ni formatiran... pa je
112405 (1873) Matej_K
Težave s nameščanjem Windowsow xp
Oddelek: Operacijski sistemi
101519 (1397) DefSigma
HDD ne zazna celega ...
121525 (1395) Spike Edin
Nov PC za photoshopanje
81797 (1580) Jan987
trdi disk 160 G - javi da je 128 G
171673 (1482) K0K0
