Forum » Pomoč in nasveti » NT Kernel problem pri zagonu...
zvery1 ::
Vedno ko se mi zaženejo vindowsi (XP) mi sygate firewall javi tole:
Kaj je to in zakaj se mi to pojavlja ob vsakem zagonu.
Racunalnik sem pregledal z ad-aware, TDS-3, antivirusnim in nic.
AMD X6 1090T, 16GB DDR3, GF 750Ti, Gigabyte 890XA-UD3,
1 x SSD, 4 x HDD, running Ubuntu 14.04 x64
nAVID ::
A si že probal z "obnovitvijo" ntoskrnl.exe ??
Insert and boot from your WindowsXP CD.
At the first R=Repair option, press the R key
Press the number that corresponds to the correct location for the installation of Windows you want to repair.
Typically this will be #1
Change to the drive that has the CD ROM.
CD i386
expand ntkrnlmp.ex_ C:\Windows\System32\ntoskrnl.exe
If WindowsXP is installed in a different location, just make the necessary change to C:\Windows
Take out the CD ROM and type exit
CD i386
nAVID do konca....
| » | prosim za pomoč- kako odpraviti tole napako...Oddelek: Pomoč in nasveti | 5102 (4611) | Mavrik |
| » | Windows XP Black screenOddelek: Pomoč in nasveti | 4814 (4554) | Twix |
| » | Win 7 blue screen in restartOddelek: Operacijski sistemi | 2926 (2665) | Duhec |
| » | win 7 bsod - okvara matične ?Oddelek: Pomoč in nasveti | 2403 (2232) | vander |
| » | Varen zagon v xpOddelek: Operacijski sistemi | 3252 (3144) | SkIDiver |
