OTP code
OTP code
globoko grlo ::
Torej, ze ene 2 tedna dobivam te 6 digit code po smsih iz razlicnih strani oz appov.
Kaj je s tem? Kako se resim tega?
yayo ::
https://www.kaspersky.com/blog/unexpect...
In an attempt to make you confirm a login, hackers may bombard you with codes. They try to log in to the account again and again, hoping that you’ll either make a mistake and click “Confirm”, or go to the service and disable 2FA out of annoyance.
  • spremenil: yayo ()
Žrtev PayPal vdora
4110072 (4328) HappyPills
Googlova phishing obramba na voljo tudi običajnim smrtnikom
Oddelek: Novice / Varnost
4315097 (12017) poweroff
Windows 8 pomoč
132277 (1895) krneki0001
Fedora 12 KDE auto login - ne dela?!?
Oddelek: Operacijski sistemi
161390 (1155) rejven
[DivXviD] filmi na Divx predvajalnikih brez problemov
Oddelek: Zvok in slika
2123741 (10742) bbbb
