typesense - queue write lag
HotBurek ::
Dobro jutro.
Evo, fantje in dekline, nov dan, nov izziv.
Nekaj časa (par dni) sem veselo vnašal (upsert-al) dokumente v typsense server, vse do danes, ko sem dobil error:
[Errno 503] Not Ready or Lagging
No, sedaj sem ustavil procese, ki vnašajo dokumente.
Naredil sem restart (service typesense-server restart) in sedaj gledam log file:
I20250328 15:43:06.512277 309416 raft_server.h:60] Peer refresh succeeded!
E20250328 15:43:11.512884 309371 raft_server.cpp:785] 101755 queued writes > healthy read lag of 1000
E20250328 15:43:11.513150 309371 raft_server.cpp:797] 101755 queued writes > healthy write lag of 500
I20250328 15:43:16.513839 309371 raft_server.cpp:706] Term: 12, pending_queue: 0, last_index: 5510929,
committed: 5510929, known_applied: 5510929, applying: 0, pending_writes: 0, queued_writes: 98519,
local_sequence: 25776203
I20250328 15:43:16.514184 309418 raft_server.h:60] Peer refresh succeeded!
E20250328 15:43:20.514441 309371 raft_server.cpp:785] 96727 queued writes > healthy read lag of 1000
E20250328 15:43:20.514570 309371 raft_server.cpp:797] 96727 queued writes > healthy write lag of 500
I20250328 15:43:26.515491 309371 raft_server.cpp:706] Term: 12, pending_queue: 0, last_index: 5510929,
committed: 5510929, known_applied: 5510929, applying: 0, pending_writes: 0, queued_writes: 94685,
local_sequence: 25791538
I20250328 15:43:26.515746 309416 raft_server.h:60] Peer refresh succeeded!
E20250328 15:43:29.516005 309371 raft_server.cpp:785] 93759 queued writes > healthy read lag of 1000
E20250328 15:43:29.516127 309371 raft_server.cpp:797] 93759 queued writes > healthy write lag of 500
I20250328 15:43:36.517094 309371 raft_server.cpp:706] Term: 12, pending_queue: 0, last_index: 5510929,
committed: 5510929, known_applied: 5510929, applying: 0, pending_writes: 0, queued_writes: 91951,
local_sequence: 25802475
In opazim, da je veliko teh "elementov/dokumentov", ki so v queued writes.
Zanima me, kako se da pohitrit write v typesense? Delam sicer upsert, vsak dokument posamično, ker jih sproti dobivam. Tu je sicer opcija, da bi jih nekaj časa nabirl, potem pa po 100 naenkrat.
Moteče je tudi, da vsakič po restartu so "elementi/dokumenti" v queued_writes:
I20250328 16:04:30.254947 310220 raft_server.cpp:706] Term: 15, pending_queue: 0, last_index: 5510932,
committed: 5510932, known_applied: 5510932, applying: 0, pending_writes: 0, queued_writes: 102125,
local_sequence: 25761780
Tisto, kar sem sicer sedaj spremenil je, da sem v config typesense-server.ini dal dve liniije:
healthy-read-lag = 1000000
healthy-write-lag = 1000000
Vir: https://typesense.org/docs/28.0/api/ser...
(nikjer sicer nisem zasledil, koliko so min/max vrednosti... tako, da sem dal na en miljon)
To sem nastavil v upanju, da takoj (v nekaj sekundah... npr. ~10) po restaru začne vračat rezultate, kljub temu, da (kot pravi server v log falju) ima "elemente/dokumente" v write queue-ju.
Zdej sem šel gledat v log file, in v prvem restartu (16:04:00) je bilo na začetku v queued_writes 117.404 elementov, v naslednjem restartu (16:19:42) pa jih je 116.840.
Se prav vi 15 minutah je šlo dol za 500. S tem da je/so po restartu spet notri, ne glede na to, da v log fajlu kaže, da je že prišlo na nulo.
Je pa to single node sistem. Zaenkrat. Ker, cluster kr ne more bit rešitev za vse probleme. Kvečjemu še novi pridejo.
Kak bi se lotil izboljšave tega "write queue lag" izziva?
root@debian:/# iptraf-ng
Please resize your window
  • spremenilo: HotBurek ()
HotBurek ::
Dober večer vsem skupaj.
Evo, danes se je spet ponovilo. Dvakrat.
In sem iz log fajlov videl čas, potem pa sem naredil korak, ki ga naredi vsak pravi moški, in šel gledat v syslog.
Tole je relevantni posnetek:
2025-03-29T05:49:21.036311+01:00 mirko1 kernel: [1020102.706459] one_connection invoked oom-killer:
gfp_mask=0x140cca(GFP_HIGHUSER_MOVABLE|__GFP_COMP), order=0, oom_score_adj=0
2025-03-29T05:49:21.036314+01:00 mirko1 kernel: [1020102.706501] CPU: 3 PID: 332560 Comm:
one_connection Not tainted 6.1.0-32-amd64 #1  Debian 6.1.129-1
2025-03-29T05:49:21.036315+01:00 mirko1 kernel: [1020102.706517] Hardware name:
QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.16.1-0-g3208b098f51a-prebuilt.qemu.org 04/01/2014
2025-03-29T05:49:21.036323+01:00 mirko1 kernel: [1020102.706528] Call Trace:
2025-03-29T05:49:21.036323+01:00 mirko1 kernel: [1020102.706577]  <TASK>
2025-03-29T05:49:21.036328+01:00 mirko1 kernel: [1020102.706618]  dump_stack_lvl+0x44/0x5c
2025-03-29T05:49:21.036329+01:00 mirko1 kernel: [1020102.706704]  dump_header+0x4a/0x211
2025-03-29T05:49:21.036330+01:00 mirko1 kernel: [1020102.706729]  oom_kill_process.cold+0xb/0x10
2025-03-29T05:49:21.036330+01:00 mirko1 kernel: [1020102.706733]  out_of_memory+0x1fd/0x4c0
2025-03-29T05:49:21.036331+01:00 mirko1 kernel: [1020102.706769]  __alloc_pages_slowpath.constprop.0+0xc83/0xe40
2025-03-29T05:49:21.036332+01:00 mirko1 kernel: [1020102.706795]  __alloc_pages+0x305/0x330
2025-03-29T05:49:21.036332+01:00 mirko1 kernel: [1020102.706798]  folio_alloc+0x17/0x50
2025-03-29T05:49:21.036333+01:00 mirko1 kernel: [1020102.706821]  __filemap_get_folio+0x155/0x340
2025-03-29T05:49:21.036333+01:00 mirko1 kernel: [1020102.706839]  filemap_fault+0x139/0x910
2025-03-29T05:49:21.036334+01:00 mirko1 kernel: [1020102.706842]  ? filemap_map_pages+0x153/0x700
2025-03-29T05:49:21.036345+01:00 mirko1 kernel: [1020102.706850]  __do_fault+0x33/0x110
2025-03-29T05:49:21.036345+01:00 mirko1 kernel: [1020102.706869]  do_fault+0x1b9/0x410
2025-03-29T05:49:21.036346+01:00 mirko1 kernel: [1020102.706872]  __handle_mm_fault+0x660/0xfa0
2025-03-29T05:49:21.036346+01:00 mirko1 kernel: [1020102.706877]  handle_mm_fault+0xdb/0x2d0
2025-03-29T05:49:21.036351+01:00 mirko1 kernel: [1020102.706881]  do_user_addr_fault+0x191/0x550
2025-03-29T05:49:21.036352+01:00 mirko1 kernel: [1020102.706914]  exc_page_fault+0x70/0x170
2025-03-29T05:49:21.036352+01:00 mirko1 kernel: [1020102.706929]  asm_exc_page_fault+0x22/0x30
2025-03-29T05:49:21.036353+01:00 mirko1 kernel: [1020102.706949] RIP: 0033:0x55c97d3c986c
2025-03-29T05:49:21.036362+01:00 mirko1 kernel: [1020102.706987] Code: Unable to access opcode bytes at 0x55c97d3c9842.
2025-03-29T05:49:21.036362+01:00 mirko1 kernel: [1020102.706989] RSP: 002b:00007fb54014c950 EFLAGS: 00010206
2025-03-29T05:49:21.036363+01:00 mirko1 kernel: [1020102.706996] RAX: 00007fb4fc0247a0 RBX: 00007fb4fc0247f8 RCX: 00007fb4fc025d38
2025-03-29T05:49:21.036363+01:00 mirko1 kernel: [1020102.706998] RDX: 000000000000001a RSI: 00007fb4fc016c72 RDI: 00007fb4fc0247a0
2025-03-29T05:49:21.036364+01:00 mirko1 kernel: [1020102.706999] RBP: 00007fb54014c960 R08: 000000000000001a R09: 00007fb5d9efda5d
2025-03-29T05:49:21.036364+01:00 mirko1 kernel: [1020102.707001] R10: 0000000000000000 R11: 00007fb5d9efda5c R12: 00007fb4fc0670e8
2025-03-29T05:49:21.036365+01:00 mirko1 kernel: [1020102.707002] R13: 00007fb4fc0247f0 R14: 00007fb4fc024500 R15: 00007fb4fc025d68
2025-03-29T05:49:21.036365+01:00 mirko1 kernel: [1020102.707023]  </TASK>
2025-03-29T05:49:21.036365+01:00 mirko1 kernel: [1020102.707024] Mem-Info:
2025-03-29T05:49:21.036366+01:00 mirko1 kernel: [1020102.707034] active_anon:94376 inactive_anon:1366227 isolated_anon:0
2025-03-29T05:49:21.036366+01:00 mirko1 kernel: [1020102.707034]  active_file:155 inactive_file:48 isolated_file:0
2025-03-29T05:49:21.036375+01:00 mirko1 kernel: [1020102.707034]  unevictable:0 dirty:0 writeback:0
2025-03-29T05:49:21.036376+01:00 mirko1 kernel: [1020102.707034]  slab_reclaimable:6769 slab_unreclaimable:8684
2025-03-29T05:49:21.036376+01:00 mirko1 kernel: [1020102.707034]  mapped:1440 shmem:15353 pagetables:6770
2025-03-29T05:49:21.036376+01:00 mirko1 kernel: [1020102.707034]  sec_pagetables:0 bounce:0
2025-03-29T05:49:21.036377+01:00 mirko1 kernel: [1020102.707034]  kernel_misc_reclaimable:0
2025-03-29T05:49:21.036377+01:00 mirko1 kernel: [1020102.707034]  free:23280 free_pcp:0 free_cma:0
2025-03-29T05:49:21.036378+01:00 mirko1 kernel: [1020102.707053] Node 0 active_anon:377504kB inactive_anon:5464908kB
active_file:620kB inactive_file:192kB unevictable:0kB isolated(anon):0kB isolated(file):0kB mapped:5760kB dirty:0kB
writeback:0kB shmem:61412kB shmem_thp: 0kB shmem_pmdmapped: 0kB anon_thp: 2469888kB writeback_tmp:0kB kernel_stack:5568kB
pagetables:27080kB sec_pagetables:0kB all_unreclaimable? yes
2025-03-29T05:49:21.036383+01:00 mirko1 kernel: [1020102.707058] Node 0 DMA free:14336kB boost:0kB min:172kB low:212kB
high:252kB reserved_highatomic:0KB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB
writepending:0kB present:15992kB managed:15360kB mlocked:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
2025-03-29T05:49:21.036385+01:00 mirko1 kernel: [1020102.707070] lowmem_reserve[]: 0 2952 5862 5862 5862
2025-03-29T05:49:21.036385+01:00 mirko1 kernel: [1020102.707074] Node 0 DMA32 free:45380kB boost:0kB min:33952kB
low:42440kB high:50928kB reserved_highatomic:0KB active_anon:222004kB inactive_anon:2777572kB active_file:0kB
inactive_file:448kB unevictable:0kB writepending:0kB present:3129192kB managed:3063656kB mlocked:0kB bounce:0kB
2025-03-29T05:49:21.036386+01:00 mirko1 kernel: [1020102.707078] lowmem_reserve[]: 0 0 2910 2910 2910
2025-03-29T05:49:21.036386+01:00 mirko1 kernel: [1020102.707081] Node 0 Normal free:33404kB boost:0kB min:33456kB
low:41820kB high:50184kB reserved_highatomic:0KB active_anon:155500kB inactive_anon:2687012kB active_file:664kB
inactive_file:0kB unevictable:0kB writepending:0kB present:3145728kB managed:2987900kB mlocked:0kB bounce:0kB
2025-03-29T05:49:21.036387+01:00 mirko1 kernel: [1020102.707085] lowmem_reserve[]: 0 0 0 0 0
2025-03-29T05:49:21.036401+01:00 mirko1 kernel: [1020102.707087] Node 0 DMA: 0*4kB 0*8kB 0*16kB 0*32kB 0*64kB
0*128kB 0*256kB 0*512kB 0*1024kB 1*2048kB (M) 3*4096kB (M) = 14336kB
2025-03-29T05:49:21.036401+01:00 mirko1 kernel: [1020102.707096] Node 0 DMA32: 138*4kB (UME) 157*8kB (UME)
144*16kB (UME) 149*32kB (UME) 97*64kB (UME) 62*128kB (UE) 39*256kB (UME) 19*512kB (UE) 3*1024kB (UME) 0*2048kB 0*4096kB = 45808kB
2025-03-29T05:49:21.036413+01:00 mirko1 kernel: [1020102.707108] Node 0 Normal: 565*4kB (UME) 351*8kB (UME)
262*16kB (UME) 94*32kB (UME) 80*64kB (UME) 47*128kB (UME) 17*256kB (UME) 9*512kB (UME) 0*1024kB 1*2048kB (M) 0*4096kB = 34412kB
2025-03-29T05:49:21.036415+01:00 mirko1 kernel: [1020102.707137] Node 0 hugepages_total=0 hugepages_free=0
hugepages_surp=0 hugepages_size=1048576kB
2025-03-29T05:49:21.036416+01:00 mirko1 kernel: [1020102.707165] Node 0 hugepages_total=0 hugepages_free=0
hugepages_surp=0 hugepages_size=2048kB
2025-03-29T05:49:21.036416+01:00 mirko1 kernel: [1020102.707167] 15583 total pagecache pages
2025-03-29T05:49:21.036417+01:00 mirko1 kernel: [1020102.707168] 0 pages in swap cache
2025-03-29T05:49:21.036417+01:00 mirko1 kernel: [1020102.707168] Free swap  = 0kB
2025-03-29T05:49:21.036417+01:00 mirko1 kernel: [1020102.707174] Total swap = 0kB
2025-03-29T05:49:21.036418+01:00 mirko1 kernel: [1020102.707175] 1572728 pages RAM
2025-03-29T05:49:21.036418+01:00 mirko1 kernel: [1020102.707175] 0 pages HighMem/MovableOnly
2025-03-29T05:49:21.036419+01:00 mirko1 kernel: [1020102.707176] 55999 pages reserved
2025-03-29T05:49:21.036419+01:00 mirko1 kernel: [1020102.707177] 0 pages hwpoisoned
2025-03-29T05:49:21.036420+01:00 mirko1 kernel: [1020102.707178] Tasks state (memory values in pages):
2025-03-29T05:49:21.036420+01:00 mirko1 kernel: [1020102.707178] [  pid  ]   uid  tgid total_vm      rss pgtables_bytes swapents oom_score_adj name
2025-03-29T05:49:21.036420+01:00 mirko1 kernel: [1020102.707183] [    241]     0   241    10029     1267    86016        0          -250 systemd-journal
2025-03-29T05:49:21.036421+01:00 mirko1 kernel: [1020102.707191] [    261]     0   261     6600      341    73728        0         -1000 systemd-udevd
2025-03-29T05:49:21.036423+01:00 mirko1 kernel: [1020102.707198] [    461]   997   461    22523      236    73728        0             0 systemd-timesyn
2025-03-29T05:49:21.036424+01:00 mirko1 kernel: [1020102.707200] [    485]     0   485     1653       62    49152        0             0 cron
2025-03-29T05:49:21.036424+01:00 mirko1 kernel: [1020102.707203] [    486]   100   486     2320      162    61440        0          -900 dbus-daemon
2025-03-29T05:49:21.036424+01:00 mirko1 kernel: [1020102.707205] [    488]     0   488    55454      478    77824        0             0 rsyslogd
2025-03-29T05:49:21.036425+01:00 mirko1 kernel: [1020102.707211] [    489]     0   489     4307      286    77824        0             0 systemd-logind
2025-03-29T05:49:21.036425+01:00 mirko1 kernel: [1020102.707213] [    564]     0   564     3860      329    69632        0         -1000 sshd
2025-03-29T05:49:21.036426+01:00 mirko1 kernel: [1020102.707215] [    652]   102   652  1731888   430214  5935104        0             0 mariadbd
2025-03-29T05:49:21.036426+01:00 mirko1 kernel: [1020102.707222] [   3886]     0  3886     1469       23    53248        0             0 agetty
2025-03-29T05:49:21.036426+01:00 mirko1 kernel: [1020102.707224] [   4686]   103  4686    54409    19499   286720        0             0 named
2025-03-29T05:49:21.036427+01:00 mirko1 kernel: [1020102.707227] [   5143]    33  5143    12049      378    77824        0             0 uwsgi
2025-03-29T05:49:21.036428+01:00 mirko1 kernel: [1020102.707229] [   5146]    33  5146    12083      286    69632        0             0 uwsgi
2025-03-29T05:49:21.036428+01:00 mirko1 kernel: [1020102.707230] [   5147]    33  5147    12083      286    69632        0             0 uwsgi
2025-03-29T05:49:21.036429+01:00 mirko1 kernel: [1020102.707237] [   5229]    33  5229    12049      382    77824        0             0 uwsgi
2025-03-29T05:49:21.036429+01:00 mirko1 kernel: [1020102.707238] [   5233]    33  5233    12083      287    69632        0             0 uwsgi
2025-03-29T05:49:21.036431+01:00 mirko1 kernel: [1020102.707246] [   5234]    33  5234    12083      287    69632        0             0 uwsgi
2025-03-29T05:49:21.036431+01:00 mirko1 kernel: [1020102.707248] [   5315]    33  5315    12049      382    86016        0             0 uwsgi
2025-03-29T05:49:21.036431+01:00 mirko1 kernel: [1020102.707250] [   5318]    33  5318    12083      300    73728        0             0 uwsgi
2025-03-29T05:49:21.036432+01:00 mirko1 kernel: [1020102.707252] [   5319]    33  5319    12083      300    73728        0             0 uwsgi
2025-03-29T05:49:21.036432+01:00 mirko1 kernel: [1020102.707258] [  12969]     0 12969     2057      123    57344        0             0 dovecot
2025-03-29T05:49:21.036432+01:00 mirko1 kernel: [1020102.707265] [  12971]   105 12971     1187       60    49152        0             0 anvil
2025-03-29T05:49:21.036435+01:00 mirko1 kernel: [1020102.707271] [  12972]     0 12972     1221       90    53248        0             0 log
2025-03-29T05:49:21.036435+01:00 mirko1 kernel: [1020102.707273] [  12973]     0 12973     1745      346    65536        0             0 config
2025-03-29T05:49:21.036436+01:00 mirko1 kernel: [1020102.707275] [  13150]   105 13150     1455       79    53248        0             0 stats
2025-03-29T05:49:21.036436+01:00 mirko1 kernel: [1020102.707277] [  55416]     0 55416     4063      848    61440        0             0 nginx
2025-03-29T05:49:21.036436+01:00 mirko1 kernel: [1020102.707283] [  55417]   999 55417     4617     1303    77824        0             0 nginx
2025-03-29T05:49:21.036437+01:00 mirko1 kernel: [1020102.707290] [  55418]   999 55418     4568     1171    77824        0             0 nginx
2025-03-29T05:49:21.036437+01:00 mirko1 kernel: [1020102.707292] [  55419]   999 55419     4592     1212    77824        0             0 nginx
2025-03-29T05:49:21.036449+01:00 mirko1 kernel: [1020102.707293] [  55420]   999 55420     4659     1260    77824        0             0 nginx
2025-03-29T05:49:21.036450+01:00 mirko1 kernel: [1020102.707300] [  57728]  1000 57728     4725      419    77824        0           100 systemd
2025-03-29T05:49:21.036450+01:00 mirko1 kernel: [1020102.707306] [  57729]  1000 57729    42211      824    94208        0           100 (sd-pam)
2025-03-29T05:49:21.036451+01:00 mirko1 kernel: [1020102.707322] [ 192798]     0 192798    10667      161    81920        0             0 master
2025-03-29T05:49:21.036451+01:00 mirko1 kernel: [1020102.707324] [ 192800]   104 192800    10812      176    81920        0             0 qmgr
2025-03-29T05:49:21.036457+01:00 mirko1 kernel: [1020102.707331] [ 193068]   104 193068    12203      373    90112        0             0 tlsmgr
2025-03-29T05:49:21.036457+01:00 mirko1 kernel: [1020102.707337] [ 312882]     0 312882    29006    19706   270336        0             0 python3.11
2025-03-29T05:49:21.036459+01:00 mirko1 kernel: [1020102.707339] [ 312883]     0 312883    32103    22695   290816        0             0 python3.11
2025-03-29T05:49:21.036460+01:00 mirko1 kernel: [1020102.707342] [ 312887]     0 312887    26678    17625   253952        0             0 python3.11
2025-03-29T05:49:21.036460+01:00 mirko1 kernel: [1020102.707344] [ 312891]     0 312891    36820    27664   335872        0             0 python3.11
2025-03-29T05:49:21.036461+01:00 mirko1 kernel: [1020102.707346] [ 312899]     0 312899    40154    30986   364544        0             0 python3.11
2025-03-29T05:49:21.036461+01:00 mirko1 kernel: [1020102.707347] [ 312901]     0 312901    37917    28760   348160        0             0 python3.11
2025-03-29T05:49:21.036461+01:00 mirko1 kernel: [1020102.707349] [ 349212]     0 349212  3060613   820512 17211392        0             0 typesense-serve
2025-03-29T05:49:21.036463+01:00 mirko1 kernel: [1020102.707352] [ 370765]   104 370765    10765      167    73728        0             0 pickup
2025-03-29T05:49:21.036463+01:00 mirko1 kernel: [1020102.707355] [ 372697]     0 372697    14225     7802   151552        0             0 python3.11
2025-03-29T05:49:21.036464+01:00 mirko1 kernel: [1020102.707356] [ 372698]     0 372698    14225     7802   147456        0             0 python3.11
2025-03-29T05:49:21.036464+01:00 mirko1 kernel: [1020102.707358] [ 372699]     0 372699     4121      685    65536        0             0 python3.11
2025-03-29T05:49:21.036464+01:00 mirko1 kernel: [1020102.707364] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),
cpuset=/,mems_allowed=0,global_oom,task_memcg=/system.slice/typesense-server.service,task=typesense-serve,pid=349212,uid=0
2025-03-29T05:49:21.036465+01:00 mirko1 kernel: [1020102.707640] Out of memory: Killed process 349212 (typesense-serve)
total-vm:12242452kB, anon-rss:3282216kB, file-rss:0kB, shmem-rss:0kB, UID:0 pgtables:16808kB oom_score_adj:0
2025-03-29T05:49:21.285860+01:00 mirko1 systemd[1]: typesense-server.service: Main process exited, code=killed, status=9/KILL
2025-03-29T05:49:21.286617+01:00 mirko1 systemd[1]: typesense-server.service: Failed with result 'signal'.
2025-03-29T05:49:21.288718+01:00 mirko1 systemd[1]: typesense-server.service: Consumed 28min 1.535s CPU time.
2025-03-29T05:49:21.548319+01:00 mirko1 systemd[1]: typesense-server.service: Scheduled restart job, restart counter is at 2.
2025-03-29T05:49:21.549023+01:00 mirko1 systemd[1]: Stopped typesense-server.service - Typesense Server.
2025-03-29T05:49:21.549149+01:00 mirko1 systemd[1]: typesense-server.service: Consumed 28min 1.535s CPU time.
2025-03-29T05:49:21.575139+01:00 mirko1 systemd[1]: Started typesense-server.service - Typesense Server.
In tisto, kaj bi oz. bo pripeljalo do rešitve:
To je to.
Faking akcija, top vreme za programirat in regrat nabirat, greeeeemoooo!!!:O
HotBurek ::
Jo.
Zdejel sem ustavil vse write processe in naredil restart. V upanju, da bo po restartu server pokuril pač manj RAM-a. Pa ga ne.
Takole pravijo interneti: The amount of RAM required is completely dependent on the size of the data you index.
Vir: https://typesense.org/docs/guide/system...
Kar pa je fakin... šit.
Neki bo treba naredit.
Za search bi lahko vnesel minimalni dokument (id, name), in potem za najdene id-je naredil search v sql. Ok, to gre.
Ampak autocomlpete, to mi pa nekak ne gre. Pismo, to se more dat rešite nekak na bolj eleganten in lažji način.
Recimo, dejmo rečt, da imamo ime produkta: "Molho Ostra Lee Kum Kee Premium 255g - Yasushi"
Katere vse vrednosti/kombinacije je treba vnes v typesense, če želimo imeti autocomplete funkcijo?
jan_g ::
Zgolj za iskanje po id-ju in imenu. Full text search pa bo pač potrebno poindeksirati celotne dokumente. Za kar rabiš dovolj hitrosti, prostora, spomina. Kako točno boš to rešil, je odvisno od tega, kaj in koliko indeksiraš. Ponavadi je lažje z manj močnimi instancami kot več švoh instancami. Pa daj si gor na serverje nek monitoring in alerting, no.
Ales ::
Mirko tipka na radirko, kaj? :D
Za pastanje večjih floh kode oz. logov obstajajo storitve kot je pastebin. Takole direktno na forumu ni pregledno.
Če želiš kako bolj specifično pomoč, bi moral še navesti specifikacije tvoje virtualke in o kakšni količini podatkov je govora. OOM killer ni lepo videti, da se sproži...
HotBurek ::
Za search bom rešil tako, da typesense najde samo id-je, potem pa gre program s temi id-ji v SQL. Trenutno imam vse potrebne informacije (imena slik, path, price, currency, html lang, itn.) v typesense, in to poveča bazo. Bom naredil, kot rečeno, da najde samo id-je, in potem gre v SQL po vse ostale podatke. Tako sem tudi že imel v preteklosti, in to bo šlo.
Matra me pa autocomplete.
Recimo, da za name "Molho Ostra Lee Kum Kee Premium 255g - Yasushi" zraven vnesem autocomplete text "molho ostra lee kum kee premium 255g yasushi".
Problem, ki je, je ta, da če sedaj v autocomplete vnesem input "m", se bo na output-u izpusal cel string (se pravi "molho ostra lee kum kee premium 255g yasushi").
Trenutno razmišlam, da bi iz typesense-a za input "m" sicer dobil cel string, potem bi ga pa splitt-al po presledkih, dobil "vse" kombinacije (zgolj odstranjevanje besed iz desne proti levi, one pass), in jih vnesel v list, vsako posebej.
Se pravi:
- typesense za input "m" vrne "molho ostra lee kum kee premium 255g yasushi"
- potem pa na serverju naredim split by space in naredim kombinacije:
"molho"
"molho ostra"
"molho ostra lee"
"molho ostra lee kum"
"molho ostra lee kum kee"
"molho ostra lee kum kee premium"
"molho ostra lee kum kee premium 255g"
Te kombinacije dam v list. Potem pa naredim top 10, po dolžini (in/ali po število besed, se pravi število presledkov).
In šele to potem vrnem na client.
VPS: 4 virtualna jedra, 6GB RAM, 400GB SSD.
Trenutno imam 400.000 "search" dokumentov. Ter, 5 miljonov autocomplete kombinacij. A te (autocomplete kombinacije) bom ven vrgel. Celote collection
HotBurek ::
Tole sem sedajle prebral:
https://medium.com/@piyush.neo/a-comple...
In ta omenja točno to: Treba je naredit vse kombinacije (abc postane a, ab, abc). In tega se pol nabere. V SQL je to qul, v (in-memory) typesense pa ne (ker preveč RAM-a požre).
Pa tole:
https://stackoverflow.com/questions/678...
Skupni pointerji:
Trie
Suffix_tree
Radix_tree
Autocomplete sem že imel v SQL u, a mi uporaba Full-Text Search ni bila kul.
Trenutno gledam, če je kakšna opcija... naredit "mal po svoje". Ker, če bi imel gaziljan bytov velik RAM-a, pa ga nimam.
Za autocomplete input "rechargeable 700mah" dobim sledeče string-e:
4.8v 700mah rechargeable ni-cd battery pack for exit sign emergency light
4n700aacwjr 4.8 volt 700mah rechargeable ni-cd battery with jr connector
4n700aacwf 4.8 volt 700mah rechargeable nicd battery pack, with futaba j connector
n700aac-pc 1.2v 700mah rechargeable aa nicd battery with pcb tabs
bp-7 13.2 volt 700mah rechargeable nicd battery for icom
cm-7g aka bp-7, cm-7 13.2 volt 700mah rechargeable ni-cd battery pack
nr4j 4.8 volt 700mah aa rechargeable nicd battery for futaba r/c
5n700aacw 6.0 volt 700mah aa rechargeable nicd battery
nr-4qb 4.8 volt 700mah aa rechargeable nicd battery for futaba r/c
tyco-style 700mah ni-cd rechargeable battery pack and speed charger
3.6v 700mah ni-cd rechargeable battery pack replacement for exit sign emergency light
4.8v 700mah ni-cd rechargeable battery pack replacement for exit sign emergency light
n700aac 1.2v 700mah aa size rechargeable ni-cd battery
5ep700aah 6.0 volt 700mah 2/3aa rechargeable nimh battery for r/c
4ep700aah 4.8 volt 700mah 2/3 aa rechargeable ni-mh battery for r/c
In zdej gledam, kako bi sestavil 10 string-ov, ki bi kolikor toliko dobro predstavlja opcije za autocomplete.
Se pravi, da bi na output-u dobil, glede na zgornji autocomplete input in string-e, neki takega:
rechargeable
rechargeable 700mah
rechargeable aa
rechargeable ni-cd
rechargeable ni-mh
rechargeable nimh
Nenavaden črv napada Linksysove usmerjevalnike
Oddelek: Novice / Varnost
228043 (4724) Daniel
Backup in Virtualc
Oddelek: Operacijski sistemi
187760 (7251) Invictus
Povečanje particije
223417 (3146) solatko
Linux Read only file system ??
91949 (1908) 2g00d4u
freesco
Oddelek: Omrežja in internet
72281 (2107) mile
