Megan šipka za merjenje olja
BRBR ::
 giklui
giklui
Nekaj takega, z eno plastično bunko. Kaj je ta ? Max ? Nekje spodaj sta dve zarezi za min in opt predvidevam.
Kajpak pogledat se brez dvoma ne da ker gre okoli ovinka in se olje zbriše in je na eni strani ploščate šipke nekaj na drugi pa nekaj drugega.
Never underestimate the power of idiots in large groups.
  • spremenil: BRBR ()
133780 ::
mogoče nekakšen čepek, če na trdo vstaviš, da ne potisne olja ven?
Blinder ::
napiše se megane, ne megan
BRBR ::
Blinder je izjavil:
Zelo verjetno.
BRBR ::
133780 je izjavil:
Mogoče, ima pa spodaj, pod tem samo 2 zarezi v kovino. Po logiki bi morale biti 3, če ni 'čepek' max.
133780 ::
ne, možno, da imaš prav, čeprav nujno ni. v prvem najdenem priročniku (272/370) piše tako s samo dvema črticama
ENGINE OIL LEVEL: general information
It is normal for an engine to use oil for
lubrication and cooling of moving parts
and it is normal to top up the level between oil changes.
However, contact your approved
Dealer if more than 0.5 litres is being
consumed every 600 miles (1,000 km)
after the running in period.
Oil change frequency: check the oil
level from time to time and certainly
before any long journey to avoid the
risk of damaging your engine.
Reading the oil level
The oil level should be read with the vehicle on level ground, after the engine
has been switched off for some time.
The dipstick must be used to read
the exact oil level and make sure
that the maximum level has not been
exceeded (risk of engine damage).
Refer to the following pages.
The instrument panel display only
alerts the driver when the oil level is at
its minimum.
- remove the dipstick and wipe with a
clean, lint-free cloth;
- push the dipstick in as far as it will
go (for vehicles equipped with a captype dipstick C, screw the cap in as
far as it will go);
- take out the dipstick again;
- read the level: it should never fall
below minimum mark A or exceed
maximum mark B.
Once the operation has been completed, ensure that the dipstick is
pushed in as far as it will go or that
the "cap-type dipstick" is completely
screwed in.
kixs ::
Imas samo dve zarezi. Spodnja, ki kaze min nivo in zgornjo, ki kaze max nivo. Nivo mora biti nekje vmes, ampak bolj proti max.
Ko gres merit, naj bo avto na ravni podlagi vsaj 2-3 ure, da se olje stece v karter. Najboljse cez noc in zjutraj pomeris, ce ne pozabis :lol:
mancini ::
To je od megane 1 ali kateri ima takšno
Dizel - olje nizko, ko je motor vroč
Oddelek: Na cesti
303877 (2406) tony1
uradni Renault servis mi naredil napako? (strani: 1 2 )
Oddelek: Na cesti
7213144 (10898) Xserces
Nakup rabljenega avta do 10.000 EUR
Oddelek: Na cesti
397614 (6398) Buggy
Rabljen karavan (2013+) do 22k€ (strani: 1 2 3 4 )
Oddelek: Na cesti
17349712 (42778) Superboyy
Clio menjava olja (strani: 1 2 )
Oddelek: Na cesti
5925861 (21425) iloveboobz
