Forum » Strojna oprema » gonilnik za kontroler
polozweii ::
https://retrounit.com.au/products/adapt...
Se da še kje dobit gonilnik za kontroler na linku?
Han ::
Sem naložil iz svojega arhiva - KLIK za prenos, poteče čez 7 dni.
- spremenil: Han ()
polozweii ::
polozweii ::
https://ibb.co/39W9jkbc
Po dobljenih informacijah bi moral za kontroler uporabiti 2902 gonilnik označen z rdečim kvadratkom. Ti si poslal 2906.
polozweii ::
kixs ::
Kaj imas to zaeno retro zadevo? Ce nima plata, pa raje kupi SATA kontroler in vse vrzi na njega - dobis HDD in CD-ROM za dzabe.
polozweii ::
To si kaj pogledal?
https://www.savagetaylor.com/2018/02/11...
Sem poskusil ob inštalaciji Win10 in ga ni ga sprejelo.
...čeprav SCSI naj bi delal do Win7 zato poskušam predvsem z Win7.
Han ::
Jaz imam Adaptec AHA-2940AU, ki deluje s šoferji, katere sem delil pred dvema mesecema. V txt datoteki so navodila, kako pripraviti ini datoteko, da bo Windows sprejel in namestil gonilnik za kartico...
This has been tested only with the Adaptec 2906. However, you may be able to adjust the driver to support other 78XX based devices.
Here is how you may get other Adaptec devices to work with this driver since I found that there is a driver for the Adaptec 7870 chip included in Vista 64, which is done through emulation. The driver name is "djsvs.sys"
1. Search Vista for both "djsvs.ini" and djsvs.sys" and copy them to a folder called "Adaptec 2906"
2. Under Device Manager, Look at the SCSI Controller that is missing the drivers. Right click on it and go to Properties, then click on the "Details" tab and finally selected the "Hardware ID" property.
From there, find the appropriate ID for your Adaptec card (in my case):
PCI\VEN_9004&DEV_5078&SUBSYS_78509004
3. Open the file "djsvs.ini" with notepad.exe and locate the entry:
[ADAPTEC.NTamd64]
%PCI\VEN_9004&DEV_7078&SUBSYS_70781414.DeviceDesc% = aic78xx_Inst, PCI\VEN_9004&DEV_7078&SUBSYS_70781414
Copy and paste the line and then change the Device ID for your device as shown below.
[ADAPTEC.NTamd64]
%PCI\VEN_9004&DEV_5078&SUBSYS_78509004.DeviceDesc% = aic78xx_Inst, PCI\VEN_9004&DEV_5078&SUBSYS_78509004
Do the same at the end of the file:
FLOPPY_DESCRIPTION="ADAPTEC SCSI Adapters - Microsoft Disk"
PCI\VEN_9004&DEV_7078&SUBSYS_70781414.DeviceDesc = "Adaptec AIC-7870 PCI SCSI Controller (Emulated)"
PCI\VEN_9004&DEV_5078&SUBSYS_78509004.DeviceDesc = "Adaptec AIC-7850 PCI SCSI Controller (Emulated)"
Save the file and close
4. Now from the Device Manager, right click on the SCSI controller that is missing the drivers and hit update driver. Select the lower option to locate the driver manually. Browse to the folder "Adaptec 2906" or whicever name you chose and select the driver from there. You will get a screen telling you that Windows cannot verify the publisher of the driver. Just keep the appropriate button to continue and install.
5. Reboot your computer to make sure it will boot up correctly. If it fails to boot and you have driver issues, you will need to select the option to boot "Last Known Good configuration".
I take no responsibility for anything that may happen to your computer by using this method. Enjoy it if it works, go buy a new supported card if it does not.
Če zgoraj opisan postopek ne deluje, lahko poskusiš še tole:
In device manager select the SCSI adapter, click "Update driver", "Browse my computer for driver software", "let me pick from a list of device drivers on my computer", uncheck "show compatible hardware", and select "Adaptec" as Manufacturer and "Adaptec AIC-7870 PCI SCSI Controller (emulated)"
[ADAPTEC.NTamd64]
[ADAPTEC.NTamd64]
- spremenil: Han ()
Han ::
| » | Slipstream Sata gonilnikov v XP inštalacijski CDOddelek: Operacijski sistemi | 1895 (1706) | -Jani- |
| » | kje dobit ata na s-ata konverterOddelek: Kaj kupiti | 1586 (1225) | -Jani- |
| » | Linux na SCSI diskihOddelek: Operacijski sistemi | 1916 (1692) | civic_ |
| » | Lag pri filmčkih v špilihOddelek: Igre | 3088 (2950) | Matev |
| » | gentoo,grub čaka minuto ob zagonuOddelek: Operacijski sistemi | 1375 (1308) | potepuh |
