42. Trapping Rain Water
HotBurek ::
Dobro jutro.
Evo, fatnje in dekline. Da ne bo danes aktualna samo politika in pripadajoči kurberaj...
Na internetih sem našel sledečo nalogo:
https://leetcode.com/problems/trapping-...
Ker sem bil pri reševanju naloge neuspešen, sem šel iskat po internetih in našel rešitev (prvi primer) na sledeči strani:
https://www.geeksforgeeks.org/trapping-...
Pogledal sem si primer, napisan v programskem jeziku Python, in napisal praktično isti primer "malo po moje":
height_elements = [0, 1, 0, 2, 1, 0, 1, 3, 2, 1, 2, 1];
# height_elements = [0, 1, 0, 2];
# height_elements = [2 ,1, 0, 1, 2];
# height_elements = [2, 1, 5, 3, 1, 0, 4];
total = 0;
res = 0
print(height_elements);
for i in range(1, len(height_elements) - 1):
    left_elements = height_elements[0 : i];
    right_elements = height_elements[i + 1:];
    print(str(left_elements) + " " + str(height_elements[i]) + " " + str(right_elements) + " ", end="");
    max_left = max(left_elements);
    max_rigth = max(right_elements);
    sum = (min(max_left, max_rigth) - height_elements[i]);
    if sum > -1:
        print("sum = " + str(sum), end="");
    else:
        print("sum =" + str(sum), end="");
    res += (min(max_left, max_rigth) - height_elements[i]);
    if res > -1:
        print(" res = " + str(res), end="");
    else:
        print(" res =" + str(res), end="");
    if sum > 0:
        total = total + sum;
    print(" total = " + str(total));
print("res = " + str(res));
print("total = " + str(total));
Output:
[0] 1 [0, 2, 1, 0, 1, 3, 2, 1, 2, 1] sum =-1 res =-1 total = 0
[0, 1] 0 [2, 1, 0, 1, 3, 2, 1, 2, 1] sum = 1 res = 0 total = 1
[0, 1, 0] 2 [1, 0, 1, 3, 2, 1, 2, 1] sum =-1 res =-1 total = 1
[0, 1, 0, 2] 1 [0, 1, 3, 2, 1, 2, 1] sum = 1 res = 0 total = 2
[0, 1, 0, 2, 1] 0 [1, 3, 2, 1, 2, 1] sum = 2 res = 2 total = 4
[0, 1, 0, 2, 1, 0] 1 [3, 2, 1, 2, 1] sum = 1 res = 3 total = 5
[0, 1, 0, 2, 1, 0, 1] 3 [2, 1, 2, 1] sum =-1 res = 2 total = 5
[0, 1, 0, 2, 1, 0, 1, 3] 2 [1, 2, 1] sum = 0 res = 2 total = 5
[0, 1, 0, 2, 1, 0, 1, 3, 2] 1 [2, 1] sum = 1 res = 3 total = 6
[0, 1, 0, 2, 1, 0, 1, 3, 2, 1] 2 [1] sum =-1 res = 2 total = 6
res = 2
total = 6
Tisti, kar mi zaenkrat še ne gre v račun, je ukaz (njihov primer) na liniji 18 in 19:
# Update the maximum water
res += (min(left, right) - arr[i])
Pri meni ne deluje, ker prišteva tudi negativne številke. Kar pa naj ne bi počel. To sedaj iščem, kaj je drugače.
UPDATE
Zgleda sem rešil. Popravil sem, kaj predstavlja left in right array. Kot kaže, moreta ta dva array-a poleg tistega, kar je levo ali desno od trenutne pozicije, vsebovati tudi element na sami poziciji.
Se pravi, če je array [1, 2, 3, 4, 5] in smo na sredini (na 3-ki), je left array [1, 2, 3], right array pa [3, 4, 5].
left_elements = height_elements[0 : i + 1];
right_elements = height_elements[i:];
As always... well done.
root@debian:/# iptraf-ng
Please resize your window
  • spremenilo: HotBurek ()
Hard problemi niso za vsakega
Ena boljših razlag
NC včasih mi ravno vsem razumljiv
Če te zanimajo lc dsa problemi, tale tudi zelo razumljivo razlaga
https://www.youtube.com/@nikoo28/videos
  • spremenilo: sbawe64 ()
Kako napisat SQL query?
Oddelek: Programiranje
131643 (849) HotBurek
Algoritem za razbitje seznama in kasnejše združevanje nazaj
151547 (956) Spura
[SQL] Pohitritev izpisa
253979 (2878) kuall
Verjetnost pri kroglicah
Oddelek: Šola
62092 (1789) Math Freak
Python iskanje podvojenih vrednosti
181827 (1540) BlueRunner
