Kaj se dogaja z avtomobilsko industrijo?
17 / 18
A tudi vi opažate vedno več kitajskih avtov pri nas?
MG-jev sem že vajen, zadnjič sem v LJ videl prvega Dongfenga.
BYD-jev pa mislim, da v Sloveniji (še) ni (so pa na Madžarskem).
folk je ugotovil, da nerabi precenjene nemske kakce da se voz
redtech je izjavil:
Avtomobili se veliko predragi:
BMW serija 5 iz leta 1995:
The BMW 5 Series 1995 prices range from $4,070 for the basic trim level Sedan 5 Series base to $9,680 for the top of the range Sedan 5
Method Adjusted Price Range
Pre-1983 CPI $11,400 - $27,100
Modern CPI $8,220 - $19,550
Toliko bi danes odštel za BMW 5.
Realnost je pa 5x+ za base model:
The price of the 2025 BMW 5-series starts at $59,875 and goes up to $74,575
Leta 95 je bil avto tehnološko TOP, tudi danes je verjetno podobno.
US
"The annual real median earnings of women working year round, full time declined $337 or 1.5 (? 1.1) percent between 1994 and 1995--going from $22,834 (? $193) to $22,497 (? $225). The earnings for men working year round, full time, $31,496 (? $189), remained unchanged."
Z letno plačo 1995 so Američani kupili 3x BMW5 (top line)
"What is the Average Salary in the US for 2024? In 2024, the average salary in the United States reached $62,027"
Z letno plačo 2024 so Američani lahko postavili na stran 83% za nakup 1 BMW5 (top line).
Kam je izginila ta njihova kupna moč, če se je njihova produktivnost v tem času skoraj podvojila.
Between 1995 and 2024, labor productivity in the U.S. nonfarm business sector increased by approximately 80%. This means that, on average, each hour worked in 2024 produced about 80% more output than in 1995.
Depresija srednjega razreda - kapitalizem(R)
tele cene pa mocno dvomim da drzijo.. Se yugec 10 let prej je bil 4k$, pa je b najcenej avto v US
Also, Stelantis se je spečal s Factorial za solid state baterije in baje že testirajo 375Wh/kg celice. Da vidimo, če bo kaj iz tega ...
@hojnikb
Pravilno, sem dal v chatgpt
In 1995, the BMW 5 Series was part of the E34 generation, which ran from 1988 to 1996. The sale prices varied depending on the specific model and options. Here's a rough breakdown of the base MSRP (Manufacturer's Suggested Retail Price) for the main trims in the U.S. market in 1995:
BMW 525i (2.5L I6, 189 hp) - around $38,000
BMW 530i (3.0L V8, 215 hp) - around $43,000
BMW 540i (4.0L V8, 282 hp) - around $50,000
These prices are approximate and would vary with optional features, location, and dealer fees. Adjusted for inflation, $50,000 in 1995 is roughly equivalent to over $100,000 today--BMWs have always aimed for that premium luxury-performance niche.
Popravek v grobem je Američan v letu 1995 z letno plačo skoraj plačal 1 petko (base model), leta 2024 pa je lahko kupil base model in ostalo mu je nekaj tisočakov. Za večjo produktivnost ni bi dobro nagrajen :)
Kaj pa Slovenec?
Poleg tega 50k leta 1995 niti priblizno ni enako kot danes 100k. Je precej vec. M2 je kaksnih 4x vecji (nisem natancno gledal)
Sem šel na testno vožnje slednjega
7 sedežni U TOUR
Verjetno naš nov avto v bližnji prihodnosti.
codeMonkey ::
Nujno blendaj kakemu BMWju na avtocesti, da pokazes kako imas vecjega :)
Res je velik.
Z vso opremo cca. 29k, nima konkurence.
D3m je izjavil:
Res je velik.
Čak, to dejansko je en model po ceniku 30.500€ in nimaš kaj izbirat? Razen med 4 barvami?
kaj bi pa izbiral, če pa so vse vključili in dali normalen motor?
pri evropskih znamkah izbiramo med zanič motorji in oskubljeno opremo. ko pa prideš na neko normalno opremo in motor pa vidiš da je avto 50% dražji... je to normalno?
delavec44 je izjavil:
D3m je izjavil:
Res je velik.
Čak, to dejansko je en model po ceniku 30.500EUR in nimaš kaj izbirat? Razen med 4 barvami?
Jup.
gruntfürmich je izjavil:
Motor je 1.5 Mitsubishi (130 kW, 285Nm) bencinar.
  • spremenil: D3m ()
Zimonem ::
pegasus je izjavil:
Dolgčas, nimajo proizvodnje, niti renomeja. Nekaj takega kot nordfuck al kaj je bila že una fabrika na skandinavskem.
Normalno je tisto kar večina dela. Se pa strinjam, da to ni dobro.
Kitajc vsaj ponuja polno opremo in soliden motor napram EU ponudbi.
https://forthing.si/wp-content/uploads/...
Specifikacija U TOUR 2024
Dimenzije:
Dolžina, širina in višina: 4850 mm x 1900 mm x 1715 mm
Medosna razdalja: 2900 mm
Motor:
Pogon: 2WD prednji pogon
Znamka motorja: Mitsubishi
Model motorja: 4A95TD
Gibna prostornina (cm3): 1,481
Način dovoda zraka: Turbo polnjenje z vmesnim hlajenjem
Moč motorja (kW): 130
Največji navor (Nm): 285
Tehnologija motorja: DVVT+GDI
Prostornina rezervoarja za gorivo: 55 L
Menjalnik:
Prenos: DCT (dvosklopčni menjalnik)
Število prestav: 7
Karoserija:
Zgradba: S panoramsko sončno streho
Število vrat: 5
Število sedežev: 7 (2+2+3)
Šasija
Vrsta sprednjega vzmetenja: Neodvisno vzmetenje McPherson + prečni stabilizator
Vrsta zadnjega vzmetenja: Neodvisno vzmetenje
Krmilni mehanizem: Električno krmiljenje
Sprednja zavora: Ventilirani disk
Zadnja zavora: Ventilirani disk
Pnevmatike: 215/55 R18
SERIJSKA OPREMA
Varnostna oprema:
Varnostna blazina za voznika in sovoznika spredaj
Stranska varnostna blazina za voznika in sovoznika
Sprednje in zadnje varnostne zavese
Opozorilnik ne pripetih varnostnih pasov spredaj in zadaj
Sistem proti blokiranju koles (ABS)
Sistem elektronske razporeditve zavorne sile (EBD)
Sistem za pomoč pri zaviranju v sili (EBA)
Nadzor zdrsa (ASR/TCS)
Nadzor stabilnosti vozila (ESP/DSC)
Pomoč pri speljevanju na klancu
Spust po strmem pobočju
Samodejno parkiranje
Naprava za nadzor tlaka v pnevmatikah
ISO FIX držalo za otroški sedež
Visoka zavorna luč
Prednji in zadnji parkirni senzor
Kamera za vzvratno vožnjo
360-stopinjska panoramska kamera
Opozorilo za nenamerno menjavo voznega pasu (LDW)
Opozorilo pred trčenjem (FCW)
Prilagodljivi žarometi za kratke in dolge luči
Opozorilnik odprtih vrat (DOW)
Alarm za prečni promet zadaj (RCTA)
Zaznavanje mrtvega kota (BSD)
Pomoč pri menjavi voznega pasu (LCA)
Oprema:
Material volana: Usnje
Večnamenski volan
Samodejni nadzor klimatske naprave
Zadnji klimatski sistem
Dodatni izhodi zraka za drugo in tretjo vrsto
Čiščenje zraka PM2.5
Panoramska sončna streha
Sistem za zagon motorja s pritiskom na gumb
Sistem za dostop brez ključa
Ogrevanje in zložljiva funkcija zunanjih ogledal ?
Električno pomikanje stekel
Funkcija za preprečevanje zatikanja oken
Dvig/zapiranje oken z enim gumbom
Odpiranje oken na daljavo
Električna prtljažna vrata
Mutimedija:
Multimedijski zaslon na sredinski konzoli
Radijski sprejemnik
Instrumentna plošča
Bluetooth povezava
Povezava z mobilnim internetom
Sedeži:
Material sedeža: Usnje
Električno nastavljiv voznikov sedež z 10 načini + prezračevanje in ogrevanje
Električno nastavljiv sovoznikov sedež z 4 načini + prezračevanje in ogrevanje
Drseči in električno nastavljivi sedeži v drugi vrsti + prezračevanje in ogrevanje
Sedeži tretje vrste s prilagodljivimi funkcijami
  • spremenil: D3m ()
Ti si ga vozil. Android auto podpira? Pa DVB-T radio?
Sem. Letnik 2024 ne podpira (tega sem vozil).
Podpira ga model letnik 2025 (glej U TOUR MY2025 model).
  • spremenil: D3m ()
Vidim sedaj ja. Recimo tole https://www.avto.net/Ads/details.asp?id...
Thx.
Avto je idealen za mojo 5 člansko familijo.
Sem pa opazil, da mladi/starejši kupijo raje SUV Forthing T5 EVO MY2025 model.
  • spremenil: D3m ()
D3m je izjavil:
7 sedežni U TOUR
Kaj je to za ena grda kolarnica? Wannabe toyota?
codeMonkey ::
D3m je izjavil:
Ha, sem sel mimo rumenega na Dunaju pred petimi minutami. Ga ne bi drugace opazil, ampak tako na hitro mi je deloval kot Lotus.
Ocitno bo tega vse vec. BYD opazis ze res pogosto tu.
S to masko izgleda, kot kak ameriški avto v živo.
Danes me je sodelavec presenetil, da je dobil naročenega Dongfeng Box-a. :O
Sparkxl ::
Teh kitajcev enoprostorcev sem že videl nekaj na cesti. Za 29k je to verjetno top izbira. Sploh ker so se vsi ostali odločili, da tega razreda več ne delajo in še štancajo samo generične suv kante.
Obstaja servisna mreža za to?
Edina slaba točka je pomoje prodaja. Spušiš verjetno bogato, razen če ga planiraš imeti mnogo let.
Servisna mreža je.
Mazda BTC in Planet avto v LJUBLJANI.
link_up ::
Kako je lahko kitajc za 29k top izbira? A niso to avti za 100e?
In and Out
Top izbira zato, ker so redki, ne pa ker so vredni tega denarja. Pac status in te fore.
link_up je izjavil:
Daj nam konkurenčni link za novega 7 sedežnega minivan-a?
DamijanD ::
Recimo, da ta firma propade - za redno vzdrževanje me ne skrbi, ker rezervni kosi so biznis in se že najde kdo, ki jih dela. Kakšna je pa situacija s kakšnimi serijskimi napakami razni odpoklici ipd.? Osebno sem v tem tednu peljal na servis 15 let starega polota, ker so našli potencialni problem pri voznikovem airbagu in so naredili odpoklic in menjavo (če sem pravilno razumel mojstra, ni bil problem, da se ne bi sprožil, ampak da bi potencialno lahko dobil šrapnel v glavo)...
Po moje bo prej kakšen evropski avto proizvajalec propadel kot pa ti "novi" Kitajci. Renome ne šteje več nič.
D3m je izjavil:
link_up je izjavil:
Jogger. Še ceneje, samo nima kakšnih najnovejših zadev.
ššš ::
Men se zdi da je moj Renault 19 leta 1995 koštal okol 1.8 mio SIT. Tri leta kasnej Opel Astra 3.2 mio SIT. Se mi zdi da so šele bl proti letu 2000 delavske plače prišle na okol 100 jurjev. Se pravi je bil avto srednjega razreda 20 - 30 plač.
Ko bi vedel, koliko kitajskih firm propade.
ššš je izjavil:
A ni ljudska modrost, da se kupuje avto za 4-6 plač?
ššš je izjavil:
Jasno, delavci so si takrat kupovali rabljene za okoli mio, če pa že novo, pa kvečjemu cliota.
pegasus je izjavil:
ššš je izjavil:
Odvisno kolk maš plače:)
IL_DIAVOLO je izjavil:
Normalno, večina jih propade. Skoraj vse, ki delajo EV so ali bodo propadle. Zdaj imamo trenutno morda 8 firm, ki globalno res nekaj pomenijo, če se med te vrinejo samo 2, 3 kitajske (kakšna je itak že), je to že velik pretres za vse ostale.
  • spremenil: Utk ()
Stane2 ::
Magic1 je izjavil:
D3m je izjavil:
link_up je izjavil:
D3m je izjavil:
7 sedežni U TOUR
Serijske napake? Življenjska doba? Servisna mreža? Rezervni deli? ...? Ti avtomobili so čista loterija. 30 tisoč evrov za nekaj, kar ti že v začetku vzbuja dvome in poraja kup vprašanj? Ne, hvala.
Thx.
Še grd je kot smrtni greh. Na zunaj izgleda kot kup cenene plastike.
Stane2 ::
V Evropi je konkurenca tem novih kitajcem, dve leti star Nemc.
Opel Frontera 1.2 GS MHEV Avt. | 7 SEDEŽEV | ODPRTA NAROČILA
  • spremenilo: Stane2 ()
Stane2 je izjavil:
Magic1 je izjavil:
D3m je izjavil:
link_up je izjavil:
7 sedežev na 4,4 metre...še 4 v takem avtu ne sedi strašno na komot. Pa ok, ni treba da ravno 7 odraslih, ampak vseeno, kaj boš s tem? Če moraš kam občasno koga več odpeljat, ok, ampak za družino, v katerih jih je 6, to res ni. Za druge pa tudi ne boš avta kupoval...
Stane2 ::
no ja, 4.8m imaš Peugeota 5008
Za 10 jurjev več imaš marsikaj.
Stane2 ::
Za 30k pač ne kupiš novega 7-seat avta, ampak par let starega v še tovarniški garanciji.
Peugeot 5008 1.2 TURBO GT AVT. - 7 SEDEŽEV + 5 LET JAMSTVO
25.990 €
Bud_Bundy ::
Stane2 je izjavil:
25.990 EUR
Predlagaš mu PSA 1.2 motor z jermenom v olju? To je slabše kot Kitajec :))
Se že ve zakaj so cene rabljenih tako nizke.
A za 5 ljudi se rabi 7 sedežnika?
Gagatronix ::
Kaj pa se dogaja z avto industrijo ? Ljudje pogruntali da ne rabijo pleha ? :)
zodiak ::
D3m je izjavil:
7 sedežni U TOUR
Grdo k satan....
Gagatronix ::
A imas avto zato da se vozis z njim ali zato da poziras pred sosedi ? Yugo GW tudi ni bil visek lepote pa ga je cel kup folka furalo zato ker je bil cenovno dostopen in funkcionalen.
Ganon je izjavil:
D3m je izjavil:
7 sedežni U TOUR
Serijske napake? Življenjska doba? Servisna mreža? Rezervni deli? ...? Ti avtomobili so čista loterija. 30 tisoč evrov za nekaj, kar ti že v začetku vzbuja dvome in poraja kup vprašanj? Ne, hvala. …
To me spominja na čase, ko sem na slepo kupoval poceni e-skiroje (za 300 namesto 800 evrov) in robotske sesalnike (za 300 namesto 600 evrov) iz Kitajske; sicer sem imel srečo in ti produkti (Xiomi, Roborock, takrat loterija, dane uveljavljeni znamki) delajo še danes; pri avtih iz Kitajske je pač sedaj podobno, le za nekaj velikostnih razredov dražje. Morda ti uspe in dobiš dober model veliko ceneje kot bi stal nek konkurenčen model pri nas (npr. za 25k namesto 65k), a obenem seveda tudi tvegaš, da bo čez eno leto totalno crknil.
spaget ::
Mitsubishi 4A95 TD?
A ni to dvajset+ let star mercedesov motor iz colta?
Poleg tega, da je res grd, vsaj na sliki, ima motor res majhen navor.
Cena je pa lepa.
Preizkušena zadeva. Ne vem sicer kako gre čez EURO norme in zakaj recimo morajo Francozi vedno nekaj izumljati in s tem uničevati cele mašine.
Drugače pa AI pravi, da je bil motor razvit 2018.
Gre za nadgradnjo klasičnih 4A9 motorjev z dodatkom turbopolnilnika za boljšo zmogljivost in večji navor pri manjših obratih.
Piše EURO 6.
In 5 zvezdic na N-CAP testu.
EU želi umakniti prepoved prodaje novih bencinskih in dizelskih avtomobilov (strani: 1 2 3 )
11515994 (10390) Mr.B
Padanje prodaje tesel v Evropi se nadaljuje (strani: 1 2 )
Oddelek: Novice / Rezultati
8515571 (10492) c3p0
Zakaj kitajski EV v Evropi nimajo šans? (strani: 1 2 3 4 5 6 )
26357243 (44031) GenZNPC
