Forum » Igre » AMD frame generation
globoko grlo ::
Novi drijverji (23.10.2) nej bi omogočil ta famozni frame generation na 6x kartah.
Zdej klele https://www.youtube.com/shorts/mOoIjYY8...
se lepo vidi AMD fluid motion frames, sam pr men tega ne vidim, zdej pa ne vem kaj narobe delam.
tnx
tnx
AMD Fluid Motion Frames (AFMF)
AFMF may be enabled for any DirectX(R) 11 and 12 title such as Cyberpunk 2077 using the per-app settings within AMD Software: Adrenalin Edition™.
AFMF can be automatically enabled using HYPR-RX or using the Global Graphics Settings toggle for these select titles;
AFMF can introduce additional latency in games and is recommended to be combined with AMD Radeon™ Anti-Lag/Anti-Lag+ for the optimal experience.
As AFMF may introduce additional latency in games, AFMF may not offer the optimal experience in fast-paced competitive titles.
The AFMF technical preview currently requires the game to be played in fullscreen mode with HDR disabled and VSYNC disabled.
For the optimal experience, AFMF is recommended to be used on AMD FreeSync™ displays.
Users are recommended to disable HDR in Windows Display Settings, or disable HDR in the game (as well as Auto-HDR).
AFMF features an activity monitor similar to AMD Radeon Super Resolution to confirm the frame generation status using AMD Software: Adrenalin Edition™'s in-game overlay (use the default hotkey of Alt-R for the fullscreen overlay, or Alt-Z for the sidebar overlay)
AFMF is recommended to be enabled for games running at a minimum fps of 55 FPS for 1080p displays, and 70 FPS for 1440p or above displays.
AFMF adds frame generation technology to boost FPS outside of the game's engine. To see the resulting FPS, use the AMD Software Performance Metrics Overlay. Support for third-party performance monitoring tools is not available at this moment.
https://www.station-drivers.com/index.p...
Poskusi pod "Gaming" in klikni na ikono igre. Če tam ni na voljo, potem bo neka splošna driver zadeva zgleda.
Tako izgleda pod "Global Graphics":
- spremenil: Jarno ()
DirkDiggler ::
Sem preveril pa še vedno ni. Sem sprobal tudi z DDU odstranit in ponovno naložit nove driverje pa še vedno ne deluje. Mogoče je kje drugje trik...
Našel sem to, morda se potrebuje "custom driver".
https://overclock3d.net/news/gpu-displa...
Driver:
https://www.amd.com/en/support/kb/relea...
In 2024, AMD expects to officially add their AFMF technology to their Radeon drivers. Until then, gamers will be able to enjoy AMD's "Technical Preview" with a custom Radeon driver. This allows gamers to try out AMD's frame generation technology early, and give AMD access to early feedback.
Driver:
globoko grlo ::
Jest nč ne najdem.
Za custom driver se je govoril ene 2 tedna nazaj, sam teli ta novi nej bi pa to official podpiral.
Nč, grem šparat za 4090
Hmm, mislim, da te razumem, ker si mislil/pomešal s FSR 3.0, ki pa mora biti specifično podprt v igri sami.
AFMF je nekaj drugega in se da načeloma uporabljati v poljubni DX11/12 igri, trenutno pa je na voljo samo skozi prilagojene gonilnike.
globoko grlo ::
Rabš ene custom driverje za 6x gen.
| » | Dishonored 2: Darkness of Tyvia (strani: 1 2 3 )Oddelek: Igre | 27044 (16948) | ahac |
| » | AMD (ATI) Catalyst™ (strani: 1 2 3 4 … 15 16 17 18 )Oddelek: Zvok in slika | 154145 (64624) | ferdo |
| » | DX10 Benchmarks - Call Of JuarezOddelek: Navijanje | 4924 (3647) | Tilen |
| » | CATALYST 3.6Oddelek: Programska oprema | 8969 (8454) | freejack |
