Alternativa SteelSeries Arctis 7X+
Kapitan Jack ::
No ta jajca so mi ocitno crknla po tocno enem mescu in pol uporabe. Sicer sem vedno uporabljal stil siris, ampak sedaj so me razocarala. Ma ze od samega zacetka so se skoz neki diskonektala, pa rekonektala, sedaj so cisto mrtve.
Kompjuter jih sicer zazna, ampak v programu pise, da jih moram rekonektati.
To seveda ne pomaga
https://support.steelseries.com/hc/en-u...
Ne da se mi zajebavat, zato rabim neko pametno alternativo v tem razredu.
Kapitan Jack ::
Nihce?
liej465 ::
It's unfortunate to hear about the issues you've experienced with the eggs. Product malfunctions can be frustrating. Regarding your current situation, I suggest prioritizing the assignment of reconnecting the eggs to the program. Promptly addressing this matter will ensure the program recognizes them and resolves the connectivity issue. Once that's resolved, you can explore further troubleshooting or contact customer support for assistance. Remember, effective assignment prioritization can save time and help find suitable solutions. Good luck!
  • predlagal izbris: Ganon ()
Zakaj pa ni AI odgovoril v slovenštini, če je že vprašanje v slovenščini?
mahone ::
Zakaj si pa kupil tastr model v 2023, ko pa imas ze vec mesecev nov model zunaj - Nova?
Alternativi: Logitech, Razer. Imajo kar zadovoljivo ponudbo. Vseeno preberi kakšen review na spletu.
Kapitan Jack ::
mahone je izjavil:
Ker sem ga dobil po akciji za 140€.
Katabrun ::
Preveri malo Turtle Beach
alexander864 ::
Looking for Project Management assignment help? You're in the right place! Our team of experienced professionals is dedicated to providing comprehensive support tailored to your needs. Whether you're grappling with project planning, risk management, or stakeholder communication, we've got the expertise to guide you through every step of your assignment.
Expect well-researched, meticulously crafted solutions that showcase your understanding of key Project Management principles and their practical applications. From case studies to project simulations, we're here to help you excel in your studies.
  • predlagal izbris: kloko ()
Paketne prevare
1511052 (9883) thomas05
c# knjiga
Oddelek: Programiranje
244316 (1128) krneki0001
Win 7?
Oddelek: Operacijski sistemi
92457 (2147) feryz
Javni razpisi iz področja Z&T
4345889 (39898) gzibret
Program za web server?
Oddelek: Omrežja in internet
92863 (2722) Hojne
